how much power will these be worth?
Old Apr 22, 2001 | 09:20 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
i am planning:
complete rebuild of engine
crane CompuCam
crane rockers
slp air induction kit
march pulley kit
MSD ignition
forged pistons
PROM chip
flowmaster exhaust
and if Vic makes the headers those 2
how much power will all this stuff be worth??
what else can i do?? and don't say get an 8!!!!!
i have a goal to improve my 6 banger greatly
Old Apr 22, 2001 | 09:22 PM
Camaro_hunter_d's Avatar
you might get 30 ponies maybe 40..dont get the pullies they are not worth the problems they create. Your alt output goes down and your water pump gets slower...
Old Apr 22, 2001 | 09:31 PM
how do you figure only 30-40 ponies?
i figured much higher like 60-70
figure like 10 for the ram air
about 5 for the rebuild with the pistons
say 10 for the exhaust
about 15 for the cam
about 15 for the rockers
figure like 10 for the chip
please correct me if i am wrong
Old Apr 22, 2001 | 09:32 PM
and oh yeah
i heard about 15 for the pulleys
Old Apr 22, 2001 | 09:47 PM
vortecfcar's Avatar
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
pulleys are definately not worth 15....and you cant just add horsepower like that. Its all about the combination.
91 RS W/carbed 350, Vortec heads, performer rpm, Comp cams Xtreme energy 224/230 duration and .477/.480 lift. BFG Drag radials. 3.42 posi,Corvette servoed 700r4, 3000 stallconverter. Edelbrock TES, 3inch cat, flowmaster with single 2.5 inch exit.
Best time yet to come
12's?? :crossthumbs:
This is a Pic of my car in race trim www.tbns.net/billyjay/camero.jpg
Yes I know how to spell camaro- so dont ask. I didnt make the link
Old Apr 23, 2001 | 03:17 AM
bub's Avatar
bub
also get bigger injectors if you get a bigger cam it makes sense that youll need bigger injectors.you can use underdrive pulleys just drive at around 1500 rpms. to keep your charge on the battery. i think you should get 45-60 hp out of that and maybe do some porting and polishing.
Old Apr 23, 2001 | 06:35 AM
Brian K's Avatar
complete rebuild of engine (10HP is Stock)
crane CompuCam (10-12HP)
crane rockers(3-5HP)
slp air induction kit (1-5HP)
march pulley kit (1-3HP)
MSD ignition (0-1HP)
forged pistons(0HP)
PROM chip (1-7HP)
flowmaster exhaust (1-9HP)
Worst case 27HP Gain, Best case 52 so an average would be: 39.5 HP not a ponnie more if you Dyno it I would bet. Then loose so much on the way to the wheels and so on.
GET NITROUS, Shave the heads 1000th to boost compression, port the heads, port the plenum, ect..
Old Apr 23, 2001 | 10:43 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Dont' forget too, depending on the wear of your engine, it could be drastically down on HP due to age. Say your engine's only doing 120 HP now; a normal rebuild would bring the 3.1 up to 140, and the performance parts add more onto that, so...
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Apr 23, 2001 | 11:36 AM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
if you are gonna get forged pistons they will probably have to be custom built so you might as well use those to boost compression.
i've heard mixed reviews about milling 60* heads. some say it can't be done, others say the intake manifold would have to be machined as well. since you're getting the pistons anyway, you can boost compression up to around 9.5:1 with the iron heads. if you want to shell out about $600-$700 for aluminum heads you can also run higher compression.
Old Apr 23, 2001 | 09:53 PM
porting sounds like a GREAT idea, but
1. how much will that run me?
2. where can i get it done?
Old Apr 24, 2001 | 09:09 PM
<font face="Verdana, Arial" size="2">Originally posted by 1991tealRSt-topGuy:
</font>
OK I will go down the numbers with you.
1. ram air. unless you have an 8 under the hood where do you get 10 ponies?..try 3-4 at most(and high speed to get it).
2. the rebuild is...unpredictable, sometmes it does yeild more power but mostly with the small displacement maybe 3-5.
3. 10 for the exhaust huh?..try another 3-5 again unless you have an 8 do not expect 10.
4. Cam with rockers(full roller type) may get you 20-25 TOGEATHER.
5. the chip again is unpredictable but I have heard 10-15 even with the small displacement engines.
The point of this is the numbers that K&N, Flowmaster and the mass of other "power adder" companies ALWAYS publish V8 numbers. Why..simple they benefit the most and show the most gain. I have a K&N, and by no means do I feel the 15-20 ponies they advertise. I feel a difference yes but not THAT much. Before buying the "power adder" big numbers take into account that all of them use V8 numbers unless they are V6 SPECIFIC PARTS. Have you heard the tale "don't beleive everything you hear" it DEFFINATELY GOES FOR AFTERMARKET PARTS MAKERS.
[This message has been edited by Camaro_hunter_d (edited April 24, 2001).]
Old Apr 24, 2001 | 09:19 PM
mulot30th's Avatar
<font face="Verdana, Arial" size="2">how do you figure only 30-40 ponies?
please correct me if i am wrong </font>
Are you kidding?
1999 30th anniv. TransAm #877
** BESTS:60ft=1.935 1/4 ET=13.08 MPH=111.8 **
(Only 3.5K miles)
T-TOP,6M-Hurst,12cd, TCS
!EGR * !MAF Screen * ported and polished MAF * !silencer baffles * ! lid baffles * ported and polished TB * removed primary and secundary baffles * sealed ram-air * 9.4k timing-tricker * !CAGS * Mobil 1 * Lou's short stick * BMR panhard rod * BMR poly/poly LCAs * !DRL * Polished SLP resonator catback * 2 Ractive mufflers * 3x3 'fernco' mod * K&N * TB stop grind * Grotyohann headers * offroad Y-pipe* Power pedals * 19+ coats Zaino * WHITE gauges cluster * blue door TA badges * pontiac windshield decal * Polished momo shift **** * 4.5" brosal exhaust tips
Ordered:
Kenny Brown DD SFC
Polished:
Calipers * Hood struts * Air tubes * Valve covers,Heat shields , etc.
Later:Cam + spring + pushrods swap + stage II heads
2000 Black Z-71 K1500 5.3l
ext.cab * !intake baffle * !MAF screen * !EGR mod
Old Apr 29, 2001 | 09:11 PM
well Mr. Kentucky Waterfall (Mulot)
i was going by manufacturer's claims
i'm sorta new to this stuff
whats your opinion???
jhawkeye
May 25, 2022 06:33 PM
Streetstuff
Sep 7, 2015 09:23 AM
sailtexas186548
Aug 24, 2015 10:11 PM
neekolzun
Aug 24, 2015 04:59 PM
355tpipickup
Aug 13, 2015 07:35 AM
