Smoking Engine Please Help
Old May 22, 2011 | 02:55 PM
travisgold's Avatar
Car: 1984 Camaro Z28
My camaro wouldn't start last night it would run for 2 seconds then sputter out i left it over night it didn't turn over first try second try it did and it was sputtering again so i gave her gas got her up to 3000 - 4000 rpm cold start then stopped i could tell she was sputtering kinda but it was going away and i popped the hood and held down the throttle and she started smoking whit smoke out the side of the engine where the oil goes in. I didn't blow a head gasket because i checked if there was any bubbles on the oil dipstick no bubbles what else could it be maybe cause i cold started her?
Old May 22, 2011 | 03:23 PM
firebird904's Avatar
Car: 1988 camaro
Engine: cammed 3.1
Axle/Gears: 10 bolt 3.42
Re: Smoking Engine Please Help
You don't check for bubbles at the oil dipstick, you check with the radiator cap off. DO NOT open it with the engine at operating temperatures or you will severely burn yourself. With the engine cool, take off the radiator cap and start the car and check to see if your getting water bubbles in the radiator. Also a sure sign but not always present is milky colored oil.
Old May 22, 2011 | 03:29 PM
88TransAmGuy's Avatar
Car: 88' White-Black Trans Am
Engine: Trying to find a motor
Yes what @firebird904 said
also on my car, when that happened i found out i had spilled some oil on the back of the motor from the last time i put oil in. So the smoking part could just be something simple like that. And the part about it sputtering, check the coolant like 904 said. Also like he said,see if the oil is milky. When my car did the same thing, it ended up being that it wasnt getting enough gas, and that it had major build up. SO we got new gasline and put in some seafoam and that helped a bit.
Old May 22, 2011 | 03:37 PM
travisgold's Avatar
I checked to see if the oil is milky not the problem i ran out of gas 2 days ago thats when the sputtering was happening yesterday it would start sputter turn off everytime i tried to do anything thats what happened i put mor gas in yesterday sputtering still happened today started it sputtered once started it again sputtered gave it lots of gas stopped sputtering poped the hood manually held down the throttle and then i noticed a bit of smoke occuring then i turned off the car.
Old May 22, 2011 | 04:46 PM
travisgold's Avatar
so the smoke is coming for the drivers side underneath the engine block
Red iroc-z 305
Sep 30, 2015 05:22 PM
Fronzizzle
Aug 17, 2015 02:52 PM
86White_T/A305
Aug 17, 2015 12:16 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
squiggy2
Aug 9, 2015 09:30 PM
