3.1 - no turn over help please!!!!!
Old Jun 7, 2011 | 05:58 PM
91rsV8maroon's Avatar
Car: 91 rs
Engine: 3.1
Axle/Gears: crippled
hey guys i have a 3.1 that i just put a cam in. now im usally very good with figureing engines out but not this one. I put it all back together perfect. It ran decent and when i went to time it i noticed the pcv wanst plugged in, so i hooked it up and now it wont fire but will crank. It ran without it plugged on though. But today it wont turn over at all, no click or anything. And i noticed the fuel pump wasnt kicking on. Ive checked all the fuses in the car and i am stumped big time!!! anyone have any ideas??
Old Jun 7, 2011 | 07:39 PM
CgMcKinney's Avatar
Car: 1990 Camaro RS
Engine: Stock 3.1 v6
Re: 3.1 - no turn over help please!!!!!
Not trying to be condescending... but did the battery die?
Old Jun 7, 2011 | 07:56 PM
K-slice's Avatar
Car: 91' Firebird
Engine: 3.1 LH0 V6
Transmission: Auto 700R4
Axle/Gears: 3.23 limited slip
K.I.S.S.
Do other electronics work, lights radio, etc? No turnover, no power to the pump must be a problem pretty close to the battery, if not the batt itself.
Old Jun 9, 2011 | 01:14 PM
Car: 91 rs
Engine: 3.1
batt. is good, i had the jump box hooked up. Light and acc. come on there is power to the starter. Is there a fuseable like somewhere im missing?
Old Jun 9, 2011 | 01:17 PM
Car: 91 rs
Engine: 3.1
I forgot to mention i was try to get it to fire by cranking it and i stopped and when i trid it again is when nothing happened.
Old Jun 9, 2011 | 05:32 PM
CgMcKinney's Avatar
Car: 1990 Camaro RS
Does your security light stay on? Could be a VATS issue.
Old Jun 10, 2011 | 01:04 AM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Well if nothing electrical comes on then its clearly an electrical issue, and batteries dont die overnight(unless you leave the lights on or something, should double check that you didnt before doing anything else) and even if it was a dead battery, the starter should still make a click noise in effort to turn over, but if all electronics are dead and you didn't run the battery down(which if you cranked enough you could btw), probably have a bad wire or blew a fusible link, if all the electrics work but the starter wont do anything, possibly starter solenoid.
Would really help to have more info, ie. did it get slower cranking before it stopped, do any of the electrical components work, and if so which ones.
Old Jun 10, 2011 | 03:50 AM
jeff_blake's Avatar
Car: 86 Iroc + 83 Firebird
Engine: Iroc 305 TPI, Firebird 305 4bbl
Transmission: 700r4 in both.
Axle/Gears: Iroc 3.27 Firebird 3.23
not always true. i went out and fired up the iroc tuesday evening and let it run for a bit, didnt drive it so no lights ect ect were on. went out wednesday and it barely had juice. seatbelts light were dim, stereo wouldnt turn on, ect ect. charged it up, and fired right back up. not to sure about the 3.1's, it may have a fuel pump inline fuse near the battery, its an orange wire one.
Old Jun 12, 2011 | 12:01 PM
Car: 91 rs
Engine: 3.1
i know for a fact the battery is good. i think i have a blown fuseable link somewhere, where should i look? Ive searched high and low. What would make the car no turn over at all. it dosent click or anything. It cranking fine and when i stopped and tried it again, nothing. and the acc. work gauges, radio, lights.
Old Jun 12, 2011 | 02:05 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
should be a fuseable link on the pass side next to the radiator. that one went out on me one time.
Old Jun 13, 2011 | 12:09 AM
Engine: 3.8, 3.4
Theres also 2 right by the starter motor and solenoid.
Old Jun 14, 2011 | 05:50 PM
Car: 91 rs
Engine: 3.1
i found out if you ground the wire that goes from the pass key to the relay it will start. Is there a way to bypass the pass key besides prom burning?
83 Crossfire TA
Jan 3, 2016 01:26 PM
bbsr72
Sep 27, 2015 05:55 AM
greenyone
Sep 8, 2015 08:41 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
