got two more questions for yall
Old Jun 28, 2001 | 10:06 PM
mAjInRS's Avatar
I think i figured out why the hell my car keeps dying but i need yall's opinions on it, ok..when i changed my starter i broke the stupid ESC(electronic spark control)sensor and it wouldnt plug back into the block so i left it for a few days till i could buy a new one, so those few days i was driving around without the ESC plugged in it wouldnt want to die after the engine warmed up, for the people who dont know the ESC is what retards the spark and what not, so i'm thinking i have a bunk ESC or something, i couldnt find the little plug in part at any junkyards or auto parts stores so i have to go to a chevy dealership and get the part there, $20 for that stupid part...geez! So i install it and from then on my car still wants to die, does anybody think there could be something wrong with my ESC/knock sensor. Thats the first problem, the second one is about my tranny, does anybody know what it means when your trans. wont shift after about 2nd or 3rd, it shifts to that then it just wont shift anymore and revs up to about 4.5k RPM's and thats while im in overdrive, drive is completely gone, it just relines, same thing happens as OD if i put it in 1st or 2nd manually. Any insight is appreciated. TIA
91 Blue RS with ASCD SS hood w/hood pins, Flowmaster 80 series w/3 inch dual exhaust, K&N, Hypertech Power Chip, Bosch Platinum wires and plugs
[This message has been edited by mAjInRS (edited June 28, 2001).]
Old Jun 29, 2001 | 02:27 AM
mAjInRS's Avatar
ttt
Old Jun 29, 2001 | 02:49 AM
AntiVTEC's Avatar
To start with, have you checked your timing lately? Whats the condition on the motor? Best thing to do is do a major tune up first of all, make sure everything is in spec and stuff. Also, our v6's didnt come with a knock sensor and the ESC wouldnt be one of the first things on the list. As for your tranny, check the condition of the fluid first. Is it burnt? Low level? Bring that back up to speed, and if the tranny is still doing weird things like that, it might mean a rebuild. Good luck!
85 2.8L Sport Coupe 5-speed.
Mods: Hpertech chip and powerstat, MSD 6A-L, Crane fireball coil, Accel Cap and Rotor, Dynomax hi-flow cat and catback system with a dynomax magnum race bullet muffler on the i-pipe, K&N filterchargers, Gutter Air Boxes, 8mm Wires, Eibach Sportlines and Tokiko springs/shocks setup, Global west sub frames, Suspension techniqs front and rear sway bars, and good ole 88 IROC wheels with Kumo Ecstas on em!
"It's not the ricers, it's those damn V8's!"
Wins: 2000 V6 Accord, 69 302 Mustang, 2000 Auto VR6 Jetta, 89 Toyota MR2, 90 Civic Si, 76 350 Camaro.
Old Jun 29, 2001 | 07:09 AM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
After you replaced the ESC did you reset the computer?
Old Jun 29, 2001 | 08:54 AM
KED85's Avatar
You are now going to be rebuilding the transmission.
Sorry, it's the truth.
No magic potion or pills or answers will work as well as rebuilding the tranny.
Mine does the same thing.
I'm having it rebuilt.
DON'T CHANGE FLUID, tranny'll get worse.
Promise. I made that mistake.
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Jun 29, 2001 | 02:11 PM
Horst's Avatar
Car: Firebird
Engine: 3.1 L
Transmission: auto
to point 2:
I think you have to adjust you TV-cable.
www.marion-becker-nidda.de
91 Firebird 3.1
Modsynomax ultra flow stainless steel -americanracing rims (ar26) rear 15x8 255/60
front 15x7 235/60
www.members.aol.com/tramphorst/pontiacpics
Old Jun 29, 2001 | 06:28 PM
mAjInRS's Avatar
yes the 3.1's did come with knock sensors, i should know, i broke the damn thing, its a beotch to replace. I've already realized i'm going to have to replace or rebuild the tranny but since it cost hella money to rebuild i was wondering how much i could get one for from a junkyard and just replace it. I dont have a whole lot of money to throw around and its my only car so if my car is out of commision so am i, so i need the cheapest fastest way.
Old Jun 29, 2001 | 09:20 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
knock sensors are soo much fun to change... lol i had to replace mine the same day i did my coolant temp sensor and all my sensors were bad but in realty it was the computer. But did u reset the computer??? Wow the fire is almsot out **** burned 285 acres and if it went down the hill another 1/4 mile i would of been able to walk out front and put my hand in it its only 10 percent contained
Old Jun 29, 2001 | 09:52 PM
KED85's Avatar
You're that close to the fire?
Hope the weeds are gone
Chat Soon,
KED85
Karl
Old Jun 30, 2001 | 05:25 PM
mAjInRS's Avatar
i've reset my computer so many times its not funny, i unplugged the sensor yesterday and reset the conputer again and now it runs fine except for the whole tranny thing, doesnt want to die or anything, does anybody know why this is????
pwdbychevy
Apr 16, 2023 07:27 AM
Fox118
Members Firebirds
111
Jan 26, 2016 07:17 PM
Drone358
Aug 27, 2015 11:15 AM
transamgta1Khp
Aug 17, 2015 12:18 PM
redmaroz
Aug 16, 2015 11:40 PM
