tempeture change
Old Jun 28, 2001 | 04:08 PM
syxx's Avatar
tempeture change
OK guys, here is another one for the board.. My normal operating temp(no air) is about 210-200. But lately, i've been running my air and it's running 240-250.. I have water wetter in the coolant, and actually the radiator is about a year old, so there isn't a blockage. Once the weather quits i'm going to flush out the radiator and coolant..
My questions is, Do any of you guys have this, or am i over reacting to the temp change when I run my air..
Syxx
Old Jun 28, 2001 | 09:36 PM
Brian K's Avatar
Sounds to drastic of a CHANGE...My car never reaches that temp with the air on... Is your fan running correctly? What color is your fliud? Your pump spinning correctly? How old and what temp is your thermo?
Old Jun 29, 2001 | 08:29 AM
Brian K's Avatar
Any more symptoms, what does it run at usually?
Old Jun 29, 2001 | 08:56 AM
KED85's Avatar
That temp is WAY TO HOT!!!
You have bad air flow somehow.
Missing spoilers or air dams?
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Jun 29, 2001 | 11:24 AM
syxx's Avatar
All the air dams and everything are there. when i don't run the air, it's usually runs at about 200-220(depends on traffic). SO any one have any more ideas..
Old Jun 29, 2001 | 12:12 PM
KED85's Avatar
Are you loosing water? or AntiFreeze?
Loose belts?
Worn water pump?
Poor quality hoses?
You "system" is being taxed using the AC, sure, but, your engine is cooking the oil, I'll bet.
You are running way hot.
Way hot.
Even when my S-10 Blazer ran the AC & hot days (like you in LA), I NEVER got that hot.
How about the fan clutch? Is that still good?
Sorry forgot you're electric fan
Chat Soon,
KED85
Karl
[This message has been edited by KED85 (edited June 29, 2001).]
Old Jun 29, 2001 | 02:13 PM
REZN8R's Avatar
Car: '96 M3
Engine: 3.2L V-6
Transmission: 5-sp
My '91 RS was running at about 200-220 in heavy traffic too. I had to install a manual fan switch. I never use the AC (T-tops baby ).
'91 RS
SFC's & Poly bushings so far.
Quote "If you can't beat them, arrange to have them beaten."
- George Carlin
Old Jun 29, 2001 | 05:57 PM
Brian K's Avatar
Syxx if you can't look at it you may want to take it in.. That could be part of your noticeable power loss you have talked about in the past.. It could also be part of that poor running conditions you have been getting...
Old Jul 1, 2001 | 04:59 PM
Brian K's Avatar
Well what have ya found out?
Old Jul 1, 2001 | 08:27 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
exact some thing for me that REZN8R just said
should i install a fan switch??
how much did it help???
Old Jul 1, 2001 | 09:14 PM
Brian K's Avatar
I know Syxx hasa fan switch, but he must be missing something to be gettin that hot.. It has to be the Pump... Would this be urgent to repair or is runin that hot okay?
Old Jul 2, 2001 | 02:34 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Here's something nobody mentioned- is the factory gauge telling you the 240-250 degrees? I hear the factory gauges can be inaccurate; you might really be running at normal temps.
You could also lean the radiator back (remove the upper rad support plate) and check for leaves & bags & crap between the radiator and air conditioning condensor. (The condensor looks like a radiator, but it's thinner, and sandwiched against your normal radiator.)
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Jul 2, 2001 | 02:57 PM
syxx's Avatar
My radiator is fine, actually it's less than a year old. The gauge isn't stock it's a digital dash so that gauge is telling me i'm running 240-250..
I think with all of the littel things screwy about my engine, i think it may be time for a rebuild..
Syxx
Old Jul 2, 2001 | 08:13 PM
Brian K's Avatar
A rebuild should have nothing to do with engine temp.. A water pump would.. You mentioned before you thought yours might be going... Now minght be the time..
Old Jul 5, 2001 | 08:46 AM
Brian K's Avatar
Well Syxx?
Old Jul 5, 2001 | 09:20 AM
KED85's Avatar
NOT TRUE.
A worn down engine can EASILY run hot.
WHY,
It's inefficent & takes more effort to do, what it once did, easily.
Uses MORE GAS for the exact same reason.
Chat Soon,
KED85
Karl
Old Jul 5, 2001 | 10:07 AM
syxx's Avatar
Right now it looks like the water pump and maybe even the timing belt will be changed ... Hopefully that will help.
Syxx
Old Jul 5, 2001 | 03:23 PM
KED85's Avatar
800-831-0884
Northern Auto Parts
For chain/pump/gasket set about $65 total, including delivery.
Chat Soon,
KED85
Karl
billybob6110
Feb 11, 2016 10:41 AM
64goatman
Sep 9, 2015 01:09 PM
IROCtometal
Sep 9, 2015 10:01 AM
FormulasOnly
Sep 6, 2015 10:42 AM
luvofjah
Sep 3, 2015 07:08 PM
