Ideas ?
Old Jul 5, 2001 | 04:10 PM
Brian K's Avatar
Ideas ?
FACTS:
New Cap, Rotor, Plugs, Wires, Charged Battery, no apparent gasket leaks. Power Brakes do not work the pedal goes all the way mushy... I have checked the brakes, no leaks and pads are fine and everything is connected.
Problem:
No Idle... Runs like it is missing, but at High RPM it is fine.
Okay, so my car will start, but runs like crap. It has no idle and I have to run it at 1500 or higher to keep it running. It sat for a year and now it is time to make it come back to life. I need it running soon and I need it to be able to drive around the block at this point. The brakes are not my first concern at this time. I just want it running so I can pull it in and out of the garage until I can afford to have it back on the road in August.
It is a 1986 Camaro Coupe
2.8 V6
Many mods and sub 16 sec ¼ when it ran
www.geocities.com/overlift
Old Jul 5, 2001 | 04:13 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
i would still pull off the intake and check those gaskets, i didnt think i had a vacuum leak, but i did. same symptoms as you
1989 Firebird
2.8 v6, t5 swapped in
Ram Hi-po clutch, Cold Air, 1.6 rockers,Lakewood LCA's, Lakewood Lift bars, Wonder Bar, 3" y-pipe, Random Tech Cat, 3" I-pipe, Flowmasters, MSd 6a, MSD Coil, Accel 8.8 wires, Auto Meter Gauges (Water, Clock, Fuel Pressure, and 5" Sport Comp Tach)TB Bypass, 4th Gen Seats
Coming for my v6:
Panhard Bar, 4thgen front seats, Nitrous, Line Lock, Posi, Spohn Torque Arm & Subframe connnectors
"I'd rather run last in a full out race, than to NOT have run at all"
#3 Forever
Old Jul 5, 2001 | 05:05 PM
Camaro_hunter_d's Avatar
High RPM stable, low is junk... try checking the timing. I would almost bet it is out some.
Old Jul 5, 2001 | 09:58 PM
KED85's Avatar
Here's what ya did.
At the base of the distributor (driver side of the engine, looking at it) is a hose, that goes to the power brake booster & the PCV valve area.
You broke the rubber hose.
It's about a slight bit less than 1/2". You need to pull off all the hose down there, clean the area with carb cleaner & wrap the fitting with black electrical tape, to take up difference.
That should do ya ok.
Double check all th hoses. You'll have a fun day. MOST of the hoses can be fixed with 5/16" windshield wiper hose rubber, to repair broken sections.
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Jul 6, 2001 | 08:40 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I'd actually say to remove the brakes from the problem altogether; remove the vacuum line from the intake to the brake booster, and plug the vacuum port up on the engine. If your brakes still act up, your master cylinder's probably leaking internally. If the car runs better, your booster is probably leaking vacuum.
How old is the fuel?
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Jul 6, 2001 | 09:16 AM
Brian K's Avatar
Around noon Flordia time I will remove the vaccum from the boster and add new fuel. Then I will atmpt to start it and see what occurs. I will keep you all updated. If that doen not work I will replace the plenum gaskets and Fuel Injection O rings since I have the kit sitting here.
Old Jul 6, 2001 | 04:30 PM
Xenodrgn's Avatar
It's 5:30, how'd it go?
1985 Camaro SC - 2.8L, auto.
http://www.xenodrgn.f2s.com/Frontright.jpg
Old Jul 6, 2001 | 05:34 PM
Brian K's Avatar
Well the woamn had me run to Home Depot and get paint and paint the darn ceiling first.. So I just got back from the GYM and just for you will walk out and take a look....
Old Jul 6, 2001 | 09:35 PM
Brian K's Avatar
No broken hoses and runs like CRAP.... Has to be something big.. It ran perfect before I stored it..
Old Jul 7, 2001 | 12:06 AM
Ryan_Alswede's Avatar
Car: 1992 Camaro RS & 1992 Camaro RS
Engine: 3.1 L v6 & 305 (5.0L) v8
Transmission: 4L60 Auto
GET A NEW MASTER CYLINDER, thats your whole problem.
Old Jul 7, 2001 | 08:28 AM
Brian K's Avatar
But it is not leaking and all my fluid is still in the resorvior...
gta892000
Aug 11, 2019 11:16 AM
Fox118
Sep 12, 2015 09:29 PM
Nick McCardle
Sep 10, 2015 08:36 PM
Djmathis123
Sep 8, 2015 08:42 PM
