bad gas mileage
Old Jul 15, 2001 | 12:24 AM
nothingssafe's Avatar
Car: 86 TA
bad gas mileage
since i bought my car in april, i have never gotten better than 20 mpg. my last 2.8 in my beretta had 225,000 miles on it without a rebuild and it still got 26-28 mpg. any suggestions. alos, what type and brand of oil should i use? i have 145,000 miles on my car and i live in arizona.
1988 Camaro
2.8 with T5
Stock for now
http://www.nothingssafe.com
Old Jul 15, 2001 | 09:28 PM
KED85's Avatar
If ya not buring any oil, try this.
3- 5/30,
1- 10/40 weight.
Any oil brand (cheaper the better!)
AC Oil Filter.
I just finished rebuilding my 1985 S-10 Blazer, 2.8 top end.
MY ENGINE IS SPOTLESS INSIDE!
Only cylinder bore slop (from the milage, NO SCORING PISTON WALLS), but I got 211,500 miles on that engine.
My head gasket finally went, I swapped on left over MPFI Heads onto the 211,500 block.
My compression is about 80-100 all cylinders.
That is exactly what I have always done to my truck, since 1989 (starting at 70,000 miles of ownership).
Run the crap outta that engine. Anythign ya do to make it stronger, makes them last longer!
Except overheating!
Change radiator fluid, every year, too!!!
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Jul 16, 2001 | 02:13 AM
Camaro_hunter_d's Avatar
well ked I agree with everything but the "any oil, cheaper is better" comment. I will not use anything but full synthetic in my ar now after seeing and feel the results of this. Better MPG about 2 overall and alot easier starting and more stable pressure at all RPM's.
Poor milage huh.. look at the plugs, wires, cap and rotor. check cylinder pressure and check for vacuum leaks. If ya have a comp controlling the mix check the Ox sensor. Check exhaust back pressure at the oc fitting too... it'll show if you have a clogged cat. ANOTHER BIG THING TO CHECK IS TIRE PRESSURE!. It does make a differance. It may not hurt to run a can or 2 of Sea Foam(it's a name brand) cleaner in your gas to clean the lines and injectors. And might as well buy another couple cans and hook them to the small vacuum line on the throttle body and suck them through your intake and clean it out some. Umm... can't think of anything else off hand right now it's almost 2 AM and I am tired.
Old Jul 16, 2001 | 02:15 AM
And I forgot to say that I get over 30MPG with my car. I go around 325-350 Miles per tank. On straight Highway for a good distance(like 300 plus miles) I get over 40. 92 RS 3.1 with 115k
Old Jul 16, 2001 | 12:15 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Well, I just got back from Ocean City, Maryland, and I'll see if I can work those mileage #'s out tonight. They're not 100% highway... the trip down also included "local" mileage, and the trip back includes 2 hours of stopped traffic.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Jul 17, 2001 | 12:40 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Well, I still haven't fueled up after coming back from Maryland, so I don't know what the mileage on the return trip is- it's probably down to 8 or so with the traffic we hit coming back, and all the local driving I've done since Sunday!
But, mileage from Central NJ to Ocean City, MD was 211.4. I drove 34.1 miles inside Ocean City. I filled up with gas when I left NJ and when I left MD.. the fillup in MD was 10.736 gallons (of 93 octane, for $19). That gives me a MPG of 22.9 ... not too shabby!
Old Sep 11, 2006 | 11:19 PM
bonestockfbird's Avatar
i know this thread is old but it reminded me of my youth. I remember when 93 Octance was only $1.75/gallon. *sighs*
Old Sep 13, 2006 | 03:29 PM
pizza_guy's Avatar
Car: 84 Z28 H.O. w/Megasquirt II
Engine: semi-stock L69
Transmission: T-5 non W/C
Axle/Gears: 3.73 open
$1.75
I'm only 23 and I remeber when gas was below a dollar a gallon. Unfortunatly, I didn't get a license until it was $1.25.
Old Sep 14, 2006 | 04:25 PM
adie's Avatar
Car: Pontiac Firebird
Engine: 2.8 v6
Transmission: auto
I wish our petrol prices were as low as yours, in england we currently pay 87.9 pence per litre,it was around 99.9 pence per litre until recently,hence only having a 2.8 v6 although I hear from some people the v8's are not much worse.
Old Sep 16, 2006 | 09:01 PM
coolrimsatleast's Avatar
Car: 89 f-bird and some others
Engine: 3.4
I must say I'm jealous. I get 360-380 miles per tank, but it comes out to about 29mpg for me.
chazman
Aug 28, 2018 03:25 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
InfinityShade
Aug 22, 2015 08:00 PM
Bradsaundry
Aug 12, 2015 12:34 AM
