rebuilt engine running terrible
Old Aug 3, 2001 | 09:19 PM
88MARO's Avatar
I finally fixed my exhaust problems, so i took the car out for a ride to see how the new engine runs. well it ran like crap. im thinking that it was the rockers adjusted wrong. What would happen if they were? the car has no power at all. what should i check out first?? thanks
88 Camaro
Rebuilt 2.8
T-TOPS
Flowmaster 80 series
Custom stereo system
Old Aug 4, 2001 | 12:33 AM
WaynesRS's Avatar
I could be wrong about this dude , but its just a thought . I have a 88 camaro 2.8 , and the same thing happend to me , I got a rebuilt engine , took it out and it ran sooo slow . I brought it back to the shop and it needed a new EGR valve. When the engine is cold , (cus you dont want to burn your hand like I almost did , stick your hand under the round thingy and see if that little plastic plate can be moved up easy , if its real hard to move up , you prabably need a new one .It takes a little effort to move it up , but it should not be real hard to move up , goodluck dude ....But don't hold me to this because it could be something else ,Im no mechanic lol .goodluck , and let me know how things go , Wayne
Old Aug 4, 2001 | 12:58 AM
elevario's Avatar
Car: 1992 RS
Engine: 3.1L V6
I'm no mechanic either but I have heard that you have to kind of break in the engine. You got to go easy on it a while until everything is running good or something.....
1992 RS 3.1L Bone Stock
"Yeah, it's a V6 SO WHAT!?"
Old Aug 4, 2001 | 01:08 PM
88MARO's Avatar
I have heard that it takes a while to break in the engine, i just thought it would run better than it is. It revs really high in first gear and it seems like it takes a while to shift out of first. There are no exhaust leaks, but it is still very loud. I didnt think my flowmaster would be that loud. Thanks for the help, ill check out the egr valve next.
Old Aug 5, 2001 | 12:03 AM
WaynesRS's Avatar
maybe the timing is off ? ..goodluck man , I'm feelin your pain bro , I know how it is to get your car back and be all excited cus it will run so great cus you have a new motor , well rebuilt , then it does not run as good as you wanted it to .
Old Aug 9, 2001 | 11:16 PM
KED85's Avatar
Timing-
If the timing is off, either it will not run or run rough.
Loosen the distb. and twist until the engine is smooth, then back off, ever so slightly.
Tighten down and take it for a ride.
How are all the vacuum manifold leaks?
Are there none?
How is the compression per cylinder? That will inform you of a lot of things! And how well the valves are adjusted! Higher per cylinder reading, better the valve/head sealing
Could be a tranny cable fix, too.
Did you move the tranny cable from the air inlet housing, when ya did this rebuild?
I have heard that 2.8 rebuilds do not equal the effort put out. That's why I went with the 3.4 swap. For the same effort, so much better rewards and the same cost.
Problem search and solve! Use a code scanner, maybe the answer is there.
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Aug 10, 2001 | 07:52 AM
WideOpenVTwin's Avatar
Car: 1992 Camaro RS
Engine: 355
Axle/Gears: 3.73:1
Timing is a good bet, when I rebuilt my 2.8L it ran like complete crap, found out my initial timing was 18* BTDC Needless to say, fixing that made a world of difference.
Check out your vaccume lines as well as intake (throttle body) gaskets to make sure there are no vaccuume leaks. Good luck
Old Aug 11, 2001 | 07:58 AM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
The tranny issue could be your TV cable.. it been adjusted lately?
'86 Camaro SC, black /w silver racing stripes
2.8l MPFI/700r4 /w special 2nd gear delete option
In search of new v8 engine & transmission, now contemplating t5 swap to get me out of this mess.
Misc Mods: Cut air box, '83 Firebird spoiler.
Performance Parts: MSD coil, Accel 8mm wires, SplitFire plugs, Gabriel hijackers.
Audio Mods: Pioneer DEH-P3000, two 12" Optimus Pro Audio subs in hand-made enclosure each powered by a 260 watt Optimus amp. Working on shaving the box for weight.
My Homepage, with pics.
Old Aug 11, 2001 | 09:06 AM
KED85's Avatar
Did you rebuild your distributor?
That's the best extra work you can do!
IS there still an exhaust clog?
Like a bad CC
Chat Soon,
KED85
Karl
Old Aug 11, 2001 | 11:08 AM
88MARO's Avatar
Well i fixed the timing and that made a huge difference. The timing was way off. Its running much stronger now. It still doesnt seem right, but its much better now. I did the rebuild about 3 weeks ago. I started rebuilding my distributer and found out that i needed a new one. It was impossible to move, you couldnt turn it at all no matter what. The guy i bought the new one from was amazed that it wouldnt move. i'm going to check my compression next. thanks guys.
Old Aug 11, 2001 | 11:15 AM
WaynesRS's Avatar
glad to hear
Old Aug 11, 2001 | 08:08 PM
KED85's Avatar
Excellent
Chat Soon,
KED85
Karl
Vintageracer
Jan 10, 2020 05:33 PM
theshackle
Mar 5, 2017 06:37 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
camaroken83
Aug 10, 2015 11:35 AM
