need help now, almost out of my mind...
Old Aug 13, 2001 | 08:01 PM
Purple Monkey's Avatar
Car: 1990 Eagle Talon TSi AWD
Engine: 4G63T
Transmission: 5 speed
how do you get the power steering pump off of this motor, really need to change water pump, aaaarrrgggghhhhh!!!!!!!!
1989 Firebird 2.8L
Dynomax Cat back
Home made cold air
Bosch +4s
Serious attitude problem.
"There is something cool about going 115 in a car with less displacement than some pop bottles."
Kills: '68 VW bug, 1995 eclipse convertible, some datsun (i swear it was james bond with that smokescreen), 86 pontiac 6000, 84 chevy van, my 84 camaro z/28( with blown trans)
Losses
2002 Viper RT/10 (More like me watching him disappear as i'm waiting for my car to start moving)
Old Aug 13, 2001 | 08:19 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
It's easy dood.
Remove the bolt that goes through the power steering bracket and into the water pump.
Remove the 2 or 3 bolts that go through the PS pump bracket AND through the A/C bracket.(Remember where they go, They aren't all the same size)
Now, remove the 2 nuts on the back side of the PS pump.
Remove pump and wedge it somewhere where it doesn't fall.
-Dan
-1990 3.1L RS
-Mods? no
-Slow? yes
Old Aug 13, 2001 | 11:15 PM
KED85's Avatar
Dan has the 100% correct tip.
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Aug 13, 2001 | 11:20 PM
Engine: 4G63T
Oh, I got it, duhhh *smacks head with oversized crack pipe*
thank man..
Old Aug 18, 2001 | 09:37 AM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
uhm... I just replaced my water pump, and the only major accessory I had to yank was the alternator... there a difference between '86 and '89 that makes the PS pump a problem?
'86 Camaro SC, black /w silver racing stripes
2.8l MPFI/700r4 /w special 2nd gear delete option
In search of new v8 engine & transmission, now contemplating t5 swap to get me out of this mess.
Misc Mods: Cut air box, '83 Firebird spoiler.
Performance Parts: MSD coil, Accel 8mm wires, SplitFire plugs, Gabriel hijackers.
Audio Mods: Pioneer DEH-P3000, two 12" Optimus Pro Audio subs in hand-made enclosure each powered by a 260 watt Optimus amp. Working on shaving the box for weight.
My Homepage, with pics.
Old Aug 18, 2001 | 10:40 AM
KED85's Avatar
Yeah, there COULD BE!
When I swapped the 3.4 into my 1985, I really wanted to keep swapping stuff down to minimum.
BUT using the 1985 mounting assembly on that 1995 block, was the only answer/solution I could arrived at.
IT SEEMS GM changed the "stuff" little by little to make assembly line installation quicker, thus exting more cars to sell.
In my solution, I took everything from the timing chain cover on the engine block and used it on the 1995 block. My old accessory stuff worked/bolted on perfect.
I've even heard usage of torx head bolts for attaching some stuff. Yet, when I played with my swap, I DO NOT RECALL any torx head bolts.
But......
Yeah, there certainly can be a difference, no matter how little, that can change many answers here.
IT ALSO DEPENDS ON BUBBA THE GREAT MECHAINC THAT WORKED ON YOUR CAR PRIOR TO YOUR OWNERSHIP.
Or as I call it POS (Previous Owner Syndrome). You discover this the first time you fix a previous problem you just bought on your car.
Corvette have this problem all the time.
Bubba worked on my Wife's/Son's 1968 Camaro, ALOT. THE Jerk.
Chat Soon,
KED85
Karl
[This message has been edited by KED85 (edited August 18, 2001).]
Old Aug 18, 2001 | 11:13 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I came across this on the '89 2.8/'86 2.8 swap. The '89 2.8 uses Torx bolts to hold the water pump to the block... the '86 uses normal bolts.
On the '89 water pump, there's an additional bolt hole. The hole is located above the water pump's lower radiator hose outlet, and it's "centered" above the two bolts by the lower hose. The power steering bracket has a matching hole in it. A bolt goes through the larger power steering bracket and into the water pump- it's an extra bolt for the p/s bracket. In fact, the p/s bracket is larger; it covers that lower-hose area on the water pump.
When we put the '86 block into the '89 car, we didn't switch water pumps. I thought all 85-92 water pumps were the same, and never noticed that extra hole in the '89 pump. When we went to put the power steering pump onto the '86 block, we saw the hole in the bracket, and had an extra small bolt left over. (I think the extra bolt is a 7mm? It looked very small.) We checked the '89 block, and saw the raised mounting boss on it's '89 water pump.
So, we left the silly bolt off altogether. The bracket appears to have enough strength (and other mounting bolts) to not require the "extra" '89 bolt. This "extra" bolt might be present on all serpentine-belt equipped 2.8/3.1's, as in, '87-'92.
So, Karl & Techsmurf, that's why PurpleM's p/s pump was in the way for him, and not for us. Odd sht, eh?
-Tom P (Hot rodded 1986 Firebird 2.8l)
Old Aug 18, 2001 | 11:40 AM
KED85's Avatar
Yeah Tom, I agree 100%.
When GM does things....... Some days ya just wanna scream
Chat Soon,
KED85
Karl
ULTM8Z
Dec 5, 2014 02:33 PM
mav75
Dec 1, 2011 02:30 AM
SRRF
Sep 24, 2011 04:56 PM
insanity213
Aug 6, 2009 06:23 PM
