Graeme.....or any who have done the 700 to T5 swap
Engine: LH0 3.1L
I have some questions for ya.
- When you did your T5 swap, how did you hook up the neutral safety switch?
-I noticed that the reverse light sensor on the 700r4 had 4 pins but the sensor on the T5 has 2 pins...what did you do?
-When you installed the pedals, did you lower the steering column or did you remove the whole thing?
-When you installed the T5, did you put the bellhousing on separately, or did you did you just put the whole tranny in at once?
Thanks guys.
-Dan
-1990 3.1L RS
-Mods? no
-Slow? yes
Thanks guys.
-Dan
-1990 3.1L RS
-Mods? no
-Slow? yes
1. The safety switch can just be jumped with a wire and left jumped all the time, but it is better to use the switch on the pedal and hook up the purple and yellow wires to it (they should just be hanging under the dash). If your pedal doesn't have a switch like mine did then you will have to make one out of brake pedal switch parts. I recommend the pedal switch because the safety switch is important for some computer functions.
2. I think you are looking at the wrong connector. The four pin square conn. on the 700R4 is for the torque converter lock-up witch can be disconnected and ignored(no codes will be thrown). The reverse wires are plugged into the shifter in the console. They are the blue and green wires in the connector that also houses a second set of neutral safety switch wires(yellow and purple).
3. I just removed the 2(?) bolts that hold it up and it dropped just enough to make it a bit easier. The pedals and clutch hydraulics are the worst part of swap. Have Fun.
4. Put the bellhousing on first, then the tranny. If you try to do both at the same time, it will take forever to get the input shaft lined up through the clutch plate and into the pilot bearing.
Also, are you going to switch to a manual computer chip? If you don't your idle will be strange and you might encounter oddities in your power brakes.
Hope this helps!
Dale
1986 FireBird
2.8L MPFI
Gutted Cat, No muffler (Sweet Sound)
Was 700-R4 --> Now T5
Hope this helps!
Dale
1986 FireBird
2.8L MPFI
Engine: LH0 3.1L
Dale,
Thanks, i just realized today that i was looking at the TCC switch.
About the chip, i took out the computer from the donor car and removed the little panel and there were 2 chips, 1 big and 1 small. I took them both. Do i need both??
And the Neutral switch, i'll take another look under the dash....maybe i missed something.
Thanks alot!
-Dan
-1990 3.1L RS
-Mods? no
-Slow? yes
[This message has been edited by CaliCamaroRS (edited August 13, 2001).]
Thanks alot!
-Dan
-1990 3.1L RS
-Mods? no
-Slow? yes
Engine: LH0 3.1L
Ok, I found a connector under my dash that has 1 purple wire, 1 yellow, and 2 black. BUT it doesn't fit the NSS connector.
I got the pedals/switches from an 85-87 firebird. Maybe they changed the design?? I guess i'll just order a 1990 NSS and see if it matches up.
-Dan
-1990 3.1L RS
-Mods? no
-Slow? yes
I got the pedals/switches from an 85-87 firebird. Maybe they changed the design?? I guess i'll just order a 1990 NSS and see if it matches up.------------------
-Dan
-1990 3.1L RS
-Mods? no
-Slow? yes
From: First one out of liberty city, burn it to the ground
I dont have reverse lights
I left the steering column totally alone... i didnt remove it unbolt it, u just worked around it. I put in the bellhousing seperate
1989 Firebird
2.8 v6, t5 swapped in
Performance Mods:
Ram Hi-po clutch, Cold Air, 1.6 rockers,Lakewood LCA's, Lakewood Lift bars, Wonder Bar, 3" y-pipe, Random Tech Cat, 3" I-pipe, Flowmasters, MSd 6a, MSD Coil, Accel 8.8 wires, Auto Meter Gauges (Water, Clock, Fuel Pressure, and 5" Sport Comp Tach)TB Bypass, 4th Gen Seats
Car Stereo:
Blaupunkt head, Monster Cable wiring, MTX Thunder 6000 12" inverted in a personally made box with a 350*1 Amp pushing it, MTX 6x9 in the back with hopes for components in front
Coming for my v6:
Panhard Bar, 4thgen front seats, Nitrous, Line Lock, Posi, Spohn Torque Arm & Subframe connnectors
"I'd rather run last in a full out race, than to NOT have run at all"
#3 Forever
My Site:
Click Here to see my car!
I left the steering column totally alone... i didnt remove it unbolt it, u just worked around it. I put in the bellhousing seperate------------------
1989 Firebird
Performance Mods:
Car Stereo:
Coming for my v6:
#3 Forever
My Site:
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Uhh.. don't put that chip in your car. If it's from that 85-87 it's 100% incompatable.
'86 Camaro SC, black /w silver racing stripes
2.8l MPFI/700r4 /w special 2nd gear delete option
In search of new v8 engine & transmission, now contemplating t5 swap to get me out of this mess.
Misc Mods: Cut air box, '83 Firebird spoiler.
Performance Parts: MSD coil, Accel 8mm wires, SplitFire plugs, Gabriel hijackers.
Audio Mods: Pioneer DEH-P3000, two 12" Optimus Pro Audio subs in hand-made enclosure each powered by a 260 watt Optimus amp. Working on shaving the box for weight.
My Homepage, with pics.
To give yourself a good starting point, you should go to a dealer and get the chip for a manual for your year. It is not the cheapest way to go but it is the safest and most reliable.
The earlier years cars used a completely different style computer so if the chip is not from your type it will not work at all. I don't know the switch over years but 87 sounds about right.
Dale
Dale
1992 Trans Am
Aug 8, 2015 08:16 PM
Jim85IROC
Aug 23, 2001 10:02 PM
