Place to out the air box sensor.
Old Nov 21, 2001 | 08:07 PM
c-5invalid's Avatar
if your air box is that single filter,(air can thing is to the right side) and if you took off that botom air filter bucket,
you may have had the problem of where to put that air sensor. so you try and let it sit in the coolest spot, (to trick the computer into giving that v6 more fuel) well i found a nice place to put it! if you look close under the air can and you should see 2 circle cut holes that lead to the tire well...(mine does) so i just put the o2 sensor kind of in the hole and the air is much cooler inside the tire well...
is this a good idea?
only thing i worry about is dirt and rock and water ohh my!
[This message has been edited by c-5invalid (edited November 21, 2001).]
Old Nov 22, 2001 | 02:38 AM
BitchinRS's Avatar
Well if you removed the bottom wouldn't you still suck dirt in from the bottom of the air filter?
As for were to puth the sensor. why not tap a hole in the top of the air tubiing and put it there. that way the computer isn't trick into thinking the air is cold then what it is and adjust for conditions that are not happening. You want the computer to adjust for the conditions that are there and not false conditions.
Old Nov 22, 2001 | 11:46 AM
c-5invalid's Avatar
no the hole is in the body fender well... not inside the airbox...
Old Nov 22, 2001 | 04:49 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
I put a resistor on mine so my computer thinks its running at 35 degrees hehe i cant remeber what the ohms are on it. ill try to fin the site that shows how many ohms equal how many degrees
Old Nov 22, 2001 | 07:31 PM
Camaro_hunter_d's Avatar
I just removed the "Case" and have my K&N sitting in open area. I put the sensor under the bottom sticking inside the K&N opening. So it still gets accurate readings.
Old Nov 23, 2001 | 09:43 PM
SAEspinz80's Avatar
heres what i did with mine
used and 11/16" paddle bit and screwed right in
1990 Firebird 3.1
- Auto Trans, TA Body Kit
- Home Made C.A.I. (KNN-RE-0810)
- ASP Underdrive Pulleys
- MSD 8.5mm Superconducter Wires (custom-cut)
- MSD GM Blaster Coil (8226)
- AC Delco Cap & Rotor
- Bosh Platinum +4 plugs
- Mobil 1 Synthetic Fluids
- 2.5" Hooker Aero-Chamber Cat-back (27121)
- 2.5" Hooker Elite Stainless Extension Tips (31503)
- GTS Blackouts (stickers removed - #GT034)
- TB Bypass
KILLS = Dodge Daytona, 2000 Toyota 4 Runner 4WD,
1999ish Explorer XLT, "older" Jeep Cherokee, 68ish Mustang (died completely when the light went green )
LOSSES = 300zx (took me in 2nd )
"The racing dice added 5hp...I SWEAR!"
[This message has been edited by SAEspinz80 (edited November 23, 2001).]
Old Nov 24, 2001 | 10:16 AM
KED85's Avatar
I went to a Cruise Night to meet up w/Graeme.
We missed each other.
I but I saw a bitchin' trick set up.
On an Impala (Last ones the SS), the guy built an air box outta clear plexiglass.
Try building that air box to block yours off and adjust the the hood rubber bump stop, so the hood stays open a bit more at that corner.
May prove to be quite effective.
Thanks for showing the pic!
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
[This message has been edited by KED85 (edited November 24, 2001).]
Old Nov 24, 2001 | 07:17 PM
SAEspinz80's Avatar
thats sounds like a real good idea, and must look great!!
TomP and I were talking about mine once and he was suggesting to cover it up like you said, and I have been thinking about it since. finally saved up some pizza boxes to use as templates.....mmmmm, pizza. anyway, i like the plexiglass idea, that way you can still see inside. it'll be more expensive, but definately like it. thanks for the input, if i get a chance to do it over winter i will post some pics after too. thanks for the input...
1992rs/ss
Jan 31, 2025 05:10 PM
Caspar
Jun 19, 2016 11:19 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Dialed_In
Aug 20, 2015 01:45 PM
bryan623
Aug 10, 2015 11:33 AM
