FPR definitely done for?
Old Jan 9, 2012 | 12:53 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
I'm sure I know the answer but wanted to get confirmation before putting my hand in my pocket. Again. On my '91 Firebird 3.1 there is a vacuum line from the TB that tees off to the fuel pressure regulator and goes down to the AIR pump. When I pulled the vac line off the AIR pump some gas dripped out. Is there any way that's not the FPR diaphragm that's leaking? On Rockauto they have one for $54 and one for $184. That's a huge diff. and they have different oem part numbers. Any opinions on why two different ones and which one to go with? What do you get for the extra $130? Would this be a time to go with an adjustable? does it replace the existing FPR and is there one that works with the 3.1 and is easy to install? Any pics of one installed?
Old Jan 9, 2012 | 01:52 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Re: FPR definitely done for?
No one?
Old Jan 9, 2012 | 02:36 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Sounds like a bad FPR to me. Although I'd also check the charcoal canister line at the canister and at the TB. Make sure that there isn't fuel being pulled through the CCP system.
RBob.
Old Jan 9, 2012 | 03:53 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Just pulled it and the diaphragm is pretty badly cracked. There was gas above it in the cap and it was running into the vac line that goes down to the AIR pump. I suspect the gas may have messed up the AIR pump as well. Any idea why the two regs on Rockauto are $130 different in price? I looked again and it's the same pic used for both!
Old Jan 9, 2012 | 05:28 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Im guessing because one is ac delco and the other is a standard motor products?? Jezz you could get a adjustable one for less then that ac deco one... 184 bucks!! Wow thats alot of cash!
Old Jan 9, 2012 | 06:10 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Guess which I'll be going for? But the same picture for both?
Old Jan 9, 2012 | 06:16 PM
fasteddi's Avatar
Car: 1991 Camaro RS
yea thats weird. IDk though, mabey the diaphrams better in one compared to the other, you could always look at getting and adjustable on, they come with a guage to read the pressure too, I got one for 50 bucks and plan to put it on the day mine goes out, or when i get some time to play with the engine itself.
Old Jan 9, 2012 | 06:47 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
What make is it? What does it look like? Where does it fit? etc. etc. Adjustable sounds good but I want to be up and running as soon as possible.
Old Jan 9, 2012 | 07:27 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Yea you might just want the stock stuff, if you want it up and running asap.
Old Jan 9, 2012 | 07:34 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Get it up and running so im not the only newbe on the DYI tuning area...
92-Formula
Dec 12, 2015 10:34 PM
mike22115
Sep 28, 2015 04:49 AM
Lmancha96
Sep 25, 2015 08:11 PM
Strick1
Sep 4, 2015 07:11 AM
wayshegoes
Aug 17, 2015 12:00 PM
