v6 tuner pro help
Old Mar 2, 2012 | 06:52 PM
sick92rs's Avatar
Car: 92 camaro rs
Engine: built 3.1
Transmission: built 700r4
v6 tuner pro help
i have a 92 rs with 7730 azty ecm and a cable i purchased from aldlcable.com, i have checked comports and so on and from looks of it every thing should be running but... it doesnt lol so ant help would be nice just wanna log data for now but even do that!!! help please! lol
Old Mar 2, 2012 | 07:49 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: v6 tuner pro help
Have you loaded the correct ADS or ADX?
Old Mar 2, 2012 | 07:51 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Heres the Stock Bin, ADF, and ADX if you dont have them. ADX is for tunerpro version 5
All the files are in the zip folder.
File Type: zip
Old Mar 2, 2012 | 08:33 PM
sick92rs's Avatar
Car: 92 camaro rs
Engine: built 3.1
okay i did not have the right adx which im sure didnt help lol now i just cant get the program to bring up and live data
Old Mar 2, 2012 | 08:41 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Is it tunerproRT V5??
When you start, make sure you have the cable connected to the car and the car ignition off. Or just connect the cable to the laptop, it doesnt need to be connected to the car. Do this before you open the tunerpro program up.
Then go to the TOOLS tab, go to the bottom and click PREFRENCES, then click the far right tab that says DATA ACQ/EMULATION, then click the CONFIGURE PLUG IN COMPONET then look at the com ports and swich if needed to so that when you click the TEST FOR VALID USER INTERFACE USER SETTINGS, that is shows the cable is properly working.
Do that first to make sure the com ports are right and the cable is connected to tunerpro....
Old Mar 2, 2012 | 08:58 PM
sick92rs's Avatar
Car: 92 camaro rs
Engine: built 3.1
if i do it that way it will not recognize the cable is plugged in .... haha why cant stuff be simple?
Old Mar 2, 2012 | 09:17 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Try changing the com port on tuner pro.. under the (check for cable/TEST FOR VALID USER INTERFACE USER SETTINGS ) See if that helps
Old Mar 2, 2012 | 09:48 PM
sick92rs's Avatar
Car: 92 camaro rs
Engine: built 3.1
Alright man thank you for all the help I will take a look in the morning and post with results
tmellott89
Oct 14, 2015 02:06 PM
djmarch
Oct 2, 2015 10:41 PM
MitcherNeaf
Sep 24, 2015 09:23 PM
rubyred88
Sep 17, 2015 02:19 PM
85Special
Sep 3, 2015 04:21 PM
