Smog pump trouble searched everywhere
Old Mar 17, 2012 | 04:57 PM
PopCycl's Avatar
My EGR fell apart but not before using it's large exhaust leak to melt a lot of damage onto the engine. The main problem part is the black plastic thingamajig mounted to the back of the smog pump. From what I can tell it is either the AIR Diverter Valve or the AIR Management Valve. Either way I can't find one anywhere so I am not sure I am looking for the right thing. Does this part come on the smog pump if I buy a new one? Mine pump seems to be fine but the plastic part is toasted.
Please help identify this part and let me know where I can get one if possible.
Thanks,
Steve
91 Camaro RS 3.1 V6
Old Mar 17, 2012 | 06:17 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Re: Smog pump trouble searched everywhere
Thanks,
Steve
91 Camaro RS 3.1 V6
Im not sure if it comes off of the air pump but it it does, i have one that would work for you. I dont use my a.i.r system. Ill go look really quick
Old Mar 17, 2012 | 06:38 PM
fasteddi's Avatar
Car: 1991 Camaro RS
You mean this part?? Pm me and ill take this one off, works fine, Im only useing the air pump for a cheep mans idler pully for the time being
Old Mar 18, 2012 | 12:44 AM
RS90CAMARO's Avatar
A little pricy but it seperated from the air pump by 2 bolts on the back.
http://www.oreillyauto.com/site/c/de...2126&ppt=C0018
Old Mar 18, 2012 | 08:12 AM
PopCycl's Avatar
Thanks guys for your replies. fasteddi, I sent you a PM. RS90CAMARO, I searched all of the auto parts houses but could not find the part you listed. I am glad you found it but yes, it is very pricey. This whole mess from an exhaust leak is turning into a real PITA.
Old Mar 18, 2012 | 08:53 AM
fasteddi's Avatar
Car: 1991 Camaro RS
K, PM sent
Old Mar 18, 2012 | 07:14 PM
RS90CAMARO's Avatar
OK I did some searching and it looks like this part is no longer made so only option would be a wrecking yard or online. I did find that one from a s10 2.8l is still made and will bolt up to the air pump but would have to be modified one hose connection is straight while the one on the camaro is bent at a 90 degree angle this is the hose that hooks to the exhaust manifold. One on the left is camaro, one on the right is s10
Attached Thumbnails Smog pump trouble searched everywhere-ec5050_1.jpg   Smog pump trouble searched everywhere-ec1326_1.jpg
Old Mar 19, 2012 | 05:16 PM
PopCycl's Avatar
Thanks for digging around. fasteddi had a used one I could buy so I should be up and running soon. Thanks, guys.
Old Mar 19, 2012 | 06:24 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Its on its way, i shipped it early this morning!
italiano67
Dec 11, 2016 09:21 AM
Juneb1022
Firebirds Wanted
Oct 12, 2015 08:12 PM
backtothe80s
Sep 5, 2015 12:39 AM
formula_novice
Aug 18, 2015 08:48 PM
hokis
Aug 9, 2015 03:57 PM
