2.8 VSS conect to 3.1 ECM
Old Jul 23, 2012 | 03:25 PM
Reni-Camaro's Avatar
Car: Camaro 1988
Engine: 305 14.5s 1/4mile
Axle/Gears: 2.73 LSD
I have camaro 88.
I swap 3.1 engine&ECM
I need conect my VSS(in speedometr) to 3.1 ECM.
Old Jul 23, 2012 | 06:06 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: 2.8 VSS conect to 3.1 ECM
Better off staying with the 2.8 system... It's more reliable, for starters, and second, you would need to get a Dakota Digital adapter for your cable and run a signal to the ECM. You can't connect the IP VSS to the ECM because the 3.1 ECM takes its speed signal straight from the VSS in the transmission and sends it to the instruments, not the other way around.
Old Jul 26, 2012 | 11:58 AM
Car: Camaro 1988
I did not understand exactly what to do?
Old Jul 26, 2012 | 02:26 PM
Engine: 2.7L V6
Axle/Gears: 4.41
You simply connect everything up on the 3.1 as it was on the 2.8, with the exception of leaving the knock sensor by the starter disconnected and replace the oil pressure sender by the starter (if necessary) to connect to the existing harness. It runs fine, I promise... My 3.1 ran on a 2.8 system for 6 years.
Old Jul 26, 2012 | 05:09 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
You can get the optical VSS to work with the 3.1 ECM (1227730, which I prefer over any MAF system), but requires programming the chip to do so. Most GM codes/bins have the ability to "flip a bit" and use a different type of VSS.
I've done this with both codes $59 and $8D, I haven't played with $88 enough to know where that setting is.
Old Jul 26, 2012 | 05:11 PM
Engine: 2.7L V6
Axle/Gears: 4.41
... If he can get his hands on a programmer and chips... And where would the optical output connect to the 730 anyways? A reversal on the Speedo OUT line?
Old Jul 26, 2012 | 08:47 PM
No, it's a different pin.
C6, according to a pinout I just looked up. Like I said, the bin needs to be programmed to look at that input though.
Old Jul 28, 2012 | 04:04 PM
Car: Camaro 1988
I can connect VSS(2.8 in my instr. panel) to my ECM (3.1)
I have full 3.1 electronic and sensor.
But i want old style console (true)
Old Jul 28, 2012 | 04:31 PM
Engine: 2.7L V6
Axle/Gears: 4.41
The question is, how easily can you get your hands on an IC progammer, chips, and parts to replace the chip in the 3.1 MEMCAL? And do you know how to use it? If the answer is not very cheaply or easily or you don't know how to use it, stay with the 2.8 stuff... It's already there and works fine with the 3.1.
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
usafirebird
Sep 29, 2015 11:58 PM
