Poor poor little v6
Old Feb 27, 2013 | 06:02 PM
confucius101's Avatar
Poor poor little v6
If these little engine are so bad way the are rebuild transmissions so expensive I just don't get it lol
Old Feb 27, 2013 | 06:11 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: Poor poor little v6
don't believe what everyone else says,
people on this forum think a T5 is to weak for even a V6, but go to a chevy truck board, daily people buy T5's from 3rd gen's to put in their straight6 and V8 pick up trucks, hauling boats, trailers, 30tons of stone and they hold up fine, but a 3rd gen camaro with a stock 305 with 2 cylinders missing will trash one so you better spend 2,500 on a T56 swap............
Old Feb 27, 2013 | 06:26 PM
Lol
Man I just spent the day calling around for a rebuild on my 700r4
Because I need the car running in the next few weeks but man these prices out here are crazy
Old Feb 27, 2013 | 08:21 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
The only way I'd use a T5 is if it was already installed in the vehicle. They are not a very good transmission, from a performance perspective. They seem to be ok when used in a vehicle that is used for just transportation purposes, where slow shifting, and low RPMs are maintained.
While I have not "broken" one, meaning catastrophic failure, I have gone through a couple in my V6 S-10, one was with the original carbed 2.8, but to be fair it seemed to be having issues when I bought it (noisy). The other was bolted to the back of my turbo 3.2L. It lasted about 8 months before it too was whining while it worked.
I'm seriously considering swapping a Nissan 5 speed trans in place of my T5 in my Jimmy, when I put it back together. Shifting is so much smoother, and I've put it through hard usage and it works amazingly.
Originally Posted by confucius101
Lol
Automatic transmissions are expensive to rebuild regardless of what the original engine application was. Around here they are usually $1200+ for stock rebuilds. I did get a SMOKING deal on a trans rebuild of a 4L60E recently through a friend of a friend, so I was spared from the outrageous expense there.
Old Feb 27, 2013 | 08:32 PM
Yeah they are asking between 1200 &1600 around here
I just can't see spending that much lol
Old Feb 27, 2013 | 08:36 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
a good 2-3 people daily doing the swap into their truck over here,
67-72chevytrucks.com They can't get enough T5s out of 3rd gens to buy.
Even funnier part is how everyone always said the shifter is to far back to use one in a truck so it has to be from a S10, thats 100% wrong. not even close to a problem, not even an after thought in a T5 swap into a truck. It fits.
Old Feb 27, 2013 | 08:38 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
To spend any less they will be cutting corners, like a $5-700 bench build, where they just take it apart and put in a kit, not checking anything or replacing parts not in a rebuild kit. dice roll
Old Feb 27, 2013 | 09:57 PM
jakemussman's Avatar
Car: 1990 Camaro RS
Axle/Gears: 10 bolt, 3.73 Ratio, Torsen LSD
When I rebuilt my 4l60e it was around $1000 to do it myself. That was going through everything in it and replacing most parts with performance components.
Old Feb 27, 2013 | 10:37 PM
danclemts's Avatar
Car: 1985 Volvo turbodiesel
Engine: 1989 305 TPI in the Volvo
Transmission: 1990 700r4
Axle/Gears: 3.73 Dana 30
I went through this a couple of years ago, Wasn't in a big hurry and kept looking, found a low mileage rebuilt 700 on ebay. Guy spent big bucks rebuilding it, upgraded parts, After a few hundred miles, decided he'd rather have a manual in his Vette, I got it for 600.00 , It's a lot of work to correctly rebuild one of these, either do it your self or find a good used unit to swap in.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
ALIENhumanoid
Members Camaros
80
Apr 23, 2016 11:35 PM
kairles
Oct 26, 2015 09:13 PM
shanelique22
Sep 24, 2015 06:30 PM
Skwisgaar
Mid-West Region
Sep 1, 2015 08:41 AM
