Feiro v6 will it fit and work
Old Apr 4, 2013 | 02:13 PM
Wayme's Avatar
Will a 2.8 v6 from a 85-86 pontiac Feiro fit and work in a camaro
Attached Thumbnails Feiro v6 will it fit and work-3149.jpg   Feiro v6 will it fit and work-emily-new-car-2.jpg
Old Apr 4, 2013 | 02:27 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Re: Feiro v6 will it fit and work
Basically the same motor. Why?
Old Apr 4, 2013 | 03:17 PM
Wayme's Avatar
Thanks, my 13 year old daughter runs a camaro for a dirt track car and we need to change the motor and i came across the feiro motor from a 85-86, just need to change intake to carb setup if it is the same motor.
Old Apr 4, 2013 | 03:41 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
It will work, but is not a direct bolt in.
The Fiero uses a FWD equivalent (transverse mounted) and therefore the starter is on the wrong side and the RWD (longitudinal) starter pad is usually modified to fit around the transmission, especially if it's bolted to an automatic, though IIRC all transverse mounted blocks were made this way.
One of the bellhousing bolts is not threaded, it's the one that is above the RWD starter pad.
I don't recall how the engine mounts pads are in the Fiero, whether they are RWD mount pads or FWD mount pads.
Old Apr 4, 2013 | 03:43 PM
bl85c's Avatar
Car: '85 maro
Well there's a few differences that may hamper installation like the starter on the opposite side and it's a transverse engine. Might just look for a camaro/firebird motor for direct swap.
Edit- Do'h 6 shooter got to it.
Old Apr 4, 2013 | 05:17 PM
Wayme's Avatar
Thanks, for the help
Old Apr 4, 2013 | 05:27 PM
Wayme's Avatar
What vehicles can i find a carburated 2.8 for her camaro? or even if i need to change intake a throttle body or injected engine
Old Apr 4, 2013 | 06:11 PM
project89's Avatar
get a fuel injected engine out of any camaro or firebird and put ur carb intake on it , the fuel injected engines will make 20-30 more hp over the carbed engines and they are much more durable the 2.8/3.1/3.4 engines out of the f-body will all bolt in
look for engines in the 89-94 year range , be aware all these engines are internally balanced so u will need the correct flexplate/flywheel
Old Apr 4, 2013 | 06:16 PM
Wayme's Avatar
ok, thanks.....v8 are soooo much easier but the class she races in requires no bigger then a v6
Old Apr 4, 2013 | 06:28 PM
project89's Avatar
are u allowed engine mods? with a head swap and cam change u can make around 300 hp
turbos superchargers prolly arent allowed right
the fuel injected engines have better cyl heads with larger valves otherwise they are the same as the carb engines so swaping one of those in place of the carb engine will give u a power increase
swapping to a 93-94 3.4 will be about a 60hp increase over the 2.8
Old Apr 4, 2013 | 07:09 PM
Wayme's Avatar
The rules say no mods, no turbos or such.. The max is 3.1 for a GM and i want the carb setup because all the wiring is gone and it would be simplar to maintain and when she moves up she will be used to carbs and such. I think as long as they dont run numbers we could be ok. Don't need to get DQed,lol
Old Apr 4, 2013 | 07:58 PM
project89's Avatar
the 3.1 is a 2.8 with a longer stroke crank , and thats actually the only way to tell them apart , so a 90-92 engine will be the 3.1 and offer a good hp increase even once u ditch the fuel injection intake for the carb but the 3.1 is a class legal engine for u anyways
while im not one to fudge the rules really the 3.4 block is identical to the 2.8/3.1 and under visual inspection noone would know the difference
all engines use the same cyl head with the exception of the carbed engines which have heads with crappier ports and smaller valves then the fuel injected heads
on a side note if u get a 3.1 u can take a 2.8 piston flycut it and end up with a 10.2-1 cr engine , but without any other engine mods it really wouldnt be worth it
Old Apr 4, 2013 | 08:06 PM
Wayme's Avatar
might try and find a 3.1 and just change the intake to carb, she is racing against cavaleirs and couple other f bodys and mustangs little extra wont hurt,lol
Old Apr 4, 2013 | 08:24 PM
project89's Avatar
5 speed car? im not sure what gears are in it now should be 3:42's ,atleast thats what all the fuel injected 2.8 cars got , but a set of 4:10's would wake the thing up
Old Apr 4, 2013 | 08:29 PM
Wayme's Avatar
It is an auto, and no locked rears or posi. not sure on gear either no tag on rearend
Old Apr 4, 2013 | 10:31 PM
jensen73110's Avatar
Car: 1991 Firebird
Engine: 3.1L +bolt ons
Axle/Gears: Moser forged, 3.73, SLP posi
Got any more pics? Under hood maybe?
Old Apr 4, 2013 | 11:16 PM
Wayme's Avatar
Sorry i dont have any under the hood
Old Apr 4, 2013 | 11:29 PM
Wayme's Avatar
Here are a couple of pics when we first got the car
Attached Thumbnails Feiro v6 will it fit and work-camero-race-car.jpg   Feiro v6 will it fit and work-new-car.jpg
Old Apr 5, 2013 | 06:50 AM
Cadaver_Puncher's Avatar
Car: 92 Camaro rs ( mostly stock for now
Engine: 3.1 v6
Transmission: 700r4 with a b&m megashifter.
Axle/Gears: whatever came stock. wanna posi tho
Do a 3.4 ( looks the same) and put 1.6 rockers on it.
Rules and bones were created for people to break.lol
Old Apr 6, 2013 | 05:24 PM
K-slice's Avatar
Car: 91' Firebird
Engine: 3.1 LH0 V6
Transmission: Auto 700R4
Axle/Gears: 3.23 limited slip
A 3.1/3.4 with roller rockers and FWD heads would be a monster (in V6 terms that is...)
Old Apr 6, 2013 | 08:48 PM
caffeine's Avatar
Car: 89 Firebird Formula
Engine: 3500T
Axle/Gears: 9 bolt/4.11
This guy made 250+ WHP with a 2.8 and carb:
http://60degreev6.com/forum/showthre...ith-2-8/page25
Old Apr 6, 2013 | 08:55 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
S-trucks are another possible source for RWD 60*
Old Apr 8, 2013 | 01:05 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
and jeeps
Old Apr 8, 2013 | 09:27 PM
Wayme's Avatar
A JEEP??????
Originally Posted by Project: 85 2.8 bird
and jeeps
Old Apr 8, 2013 | 10:03 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
used in the small wagoneers ~1984-86 3.1 can be found in early '90s isuzu trooper.
Old Apr 8, 2013 | 10:12 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
I had a 2.8 out of a 93 s10 in my car before I shoved my 350 in.
Old Apr 9, 2013 | 04:07 AM
Yes, but it would have the same issues as using a transverse mounted engine, from the Trooper, anyway. I don't recall teh details of the earlier Wagoneer V6. I would think it would be easier to find an S-series or F-body V6 than a Wagoneer though.
AnotherfastIROC
Nov 10, 2011 01:22 PM
Dale
Dec 14, 2005 11:05 AM
mars22
Aftermarket Product Review
39
Jun 5, 2005 10:19 PM
Red91Bird
Mar 8, 2001 07:45 AM
