s10 to camaro
Old Jan 10, 2014 | 07:15 AM
tj19985's Avatar
s10 to camaro
i know this isnt strictly camaro related but my question is will a 1984 s10 motor and tranny fit and bolt up without any mods to a 84 sport coupe. since they both have a 2.8 v6
Old Jan 10, 2014 | 07:24 AM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
Re: s10 to camaro
think twice before transplanting a pre-85 2.8. they are infamous for being terrible motors
that being said, the block will transplant, the transmission will not. the s10 t5 was a different body, and the shifter will not line up
Old Jan 10, 2014 | 07:26 AM
tj19985's Avatar
Re: s10 to camaro
i just wanted to take the tranny out of the s10 and put it behind my camaro 2.8. could it be modded to work?
Old Jan 10, 2014 | 07:29 AM
58mark's Avatar
Re: s10 to camaro
you would have to modify your car, like getting rid of your center console and cutting a hole in a different part of your floor pan.
Sure it's worth it?
Old Jan 10, 2014 | 08:14 AM
OrangeBird's Avatar
Car: 1989 Firebird
Re: s10 to camaro
Sure it's worth it?
58mark has given you some great advice , and here's one more little snafu ...
Your 84 sport coup has a torque arm that connects from the rear axle to the transmission's tailshaft . Only a third gen transmission will have the appropriate mount on it's tailshaft for the torque arm ......
Sure , there ARE special conversion mounts out there for putting non third gen transmissions into our camaros and firebirds , but is it really worth all that to you , rather than just getting the right transmission to fit ? When you talk customization , hell yea , ANYTHING is possible . But !!! When ya talk getting the car back on the road as quickly and as cheaply as possible , only direct fit components are gonna accheive that .....
Good Luck with it ...
Old Jan 10, 2014 | 11:26 AM
bigal55's Avatar
Car: 88 convertible
Engine: 5.7L
Transmission: 4+3 maual
Axle/Gears: 3.07
Re: s10 to camaro
You can use the S-10 transmission IF you swap tail housings and shafts (speedo gear placement). All parts from your camaro trans will swap right over to the s-10 trans. You can skip the shaft swap if you move the speedo gear to the appropriate location on the s-10 shaft and epoxy it in place. Do a search on t-5 transmissions and you will be able to make your own informed decision! Good Luck which ever way you decide to go.
P.S. swapping the tail housing will take care of all the camaro trans idiosyncrasies, the canted trans mount and the torque arm mount.
Old Jan 10, 2014 | 12:15 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: s10 to camaro
If it's a T5 being swapped, it's the bellhousing that tilts the transmission. If it's a 700R4, then the only thing that should be needed is swapping the tail housing for the torque arm mount.
Old Jan 13, 2014 | 01:56 PM
bigal55's Avatar
Car: 88 convertible
Engine: 5.7L
Axle/Gears: 3.07
Re: s10 to camaro
Yes, the op said t5 from s-10 to camaro. You are correct in saying the bell housing cants the trans, which, besides shifter location and angle, is the reason you need to swap the tail housing. The tail housing contains the shifter and shift rails (which need to be swapped also) and the correct trans mount angle for the crossmember and has the torque arm mount. So, for about an hours worth of work, you can easily swap the necessary parts and virtually have a camaro t5. Check the input shaft spline to be sure it matches with the "new" trans input shaft. If it does, this is cake!
Old Jan 13, 2014 | 05:04 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: s10 to camaro
Um, it's not as simple as just swapping the tail housing...
The entire shift rail needs to be swapped. The one in the S10 trans is TOO SHORT because the shifter is very close to the main case whereas the one in the F-body trans is at the end of the tail housing.
And that means that the main case has to be opened because the shift rail/fork assemblies are in the main case cover. The tail housing encloses the shift rail, but the parts are assembled in the case cover.
If you're going to do all of that, you might as well just rebuild the trans while you're at it, since you'd already be halfway there...
Again, for the small journal crank and all of the work that would be needed to convert the S10 trans over to F-body parts, you're just better off getting the better engine and proper trans in the first place. Especially due to costs. Most people are selling the transmissions whole and not in parts.
Old Jan 17, 2014 | 10:22 AM
bigal55's Avatar
Car: 88 convertible
Engine: 5.7L
Axle/Gears: 3.07
Re: s10 to camaro
Seeing how the op asked if it could be modded to work, the simple answer is yes. Do people actually READ the whole thread, or do they just jump in with answers that do not answer the question. The op has the s-10 tranny to swap the parts from, so what real cost involved? A little time will yield some great experience and a useable trans for his camaro.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
BADNBLK
Nov 16, 2016 09:12 AM
porkenstein
Convertibles
Aug 31, 2015 12:54 PM
