which wire for setting timing ?
Old May 18, 2015 | 05:15 AM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Hi, I looked before but cannot work out which wire I need to disconect to set my base timing, all the wire colours I read dont seem to match up so heres a pic can some one just point it out to me, very grateful thanks !
Old May 18, 2015 | 11:16 AM
camaroyoungster's Avatar
Car: 1985 Camaro Sport Coupe
Engine: Chevy 3.1
Re: which wire for setting timing ?
I'm pretty sure it is this one.
Attached Thumbnails which wire for setting timing ?-80-img_20150518_110358_9456c493c1b90931dbc564335801302de4abf1e7.jpg
Old May 18, 2015 | 12:09 PM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Thanks man !
Old May 18, 2015 | 12:12 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
It's neither of those.
The wire you want to disconnect is a tan w/ black stripe wire. I believe the connector is nearer the heater fan, it may be tucked into the loom.
On S10s it's above the passenger side foot well, so if you can't find it in teh engine compartment look near the ECM, in the passenger compartment.
Old May 18, 2015 | 12:44 PM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Aw man see where my confusion comes from, I was always told its around there hanging out like that but the colours never match what I got !
Ill have a look thanks
Old May 18, 2015 | 02:36 PM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Got it thanks every one !
Old May 18, 2015 | 03:06 PM
Engine: Chevy 3.1
Haha they both look the same. I remember I couldn't find that wire when I needed to set the timing. Searched for days.
Old May 18, 2015 | 04:15 PM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Its strange theyve got all these conectors half way through the loom, now I wonder what the other two are used for . Anyways at least I can check my timing now.
Old May 19, 2015 | 08:28 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The single white wire connector is for the dash tachometer. Note how it comes from the ignition coil.
The red wire looks to be power for something, what I don't know.
RBob.
Old May 30, 2015 | 06:08 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Clarifying:
Red wire is direct power feed for high speed blower relay... Not used in later harnesses as this wire is in the 4 (2) wire connector next to it with the blue and black wires in it...
Old May 31, 2015 | 03:41 AM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Excellent info thanks mav and others .
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
ZsTransAm
Aug 11, 2015 07:30 PM
