V6 mini starter?? Where?? Read first post BEFORE you respond.
Old Jun 1, 2015 | 06:39 PM
willexoIX's Avatar
Car: 89 Camaro RS running MS2X
Engine: .48/.60AR T3/T4 2.8L V6
Transmission: Rebuilt 700R4 2500 stall
Axle/Gears: Next to break...
Searched and all I found were dead links and he said she said....
What mini starters will Definitively work with our 2.8/3.1/3.4? 148 tooth flywheel. 2.8 starter has STAGGERED mounting bolt holes.
DO NOT RESPOND IF YOU DO NOT KNOW THE FACTS.
NO OPINIONS.
Old Jun 1, 2015 | 07:21 PM
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
Re: V6 mini starter?? Where??
Buy some to test them. If they don't work give them to me.
Old Jun 1, 2015 | 08:33 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
2000+ GM FWD cars used a permenant magnet, gear reduction mini starter on the 3100 and 3400 engines. Might be able to adapt one onto your application.
For my stuff I grab them off the 4.3 S10s and Astro vans in the junkyard for my older 350s and they bolt right on as long as you are running the correct flywheel or flexplate.
Old Jun 1, 2015 | 08:39 PM
willexoIX's Avatar
350's bolt holes are directly across from one another IIRC, the 2.8/3.1/3.4 have staggered bolt holes so no.
I'm not looking to adapt anything. If you don't have pertinent information on a direct bolt in, don't add an opinion, add facts please.
No offense.
Old Jun 1, 2015 | 08:47 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
No offense.
Good luck!! I wasn't saying to use the 4.3 starter rather used it as an example of interchangeability. I said look at the newer FWD V6s as I have messed with them and they look like they might work.
FWIW small blocks can have the starter bolt holes straight across or offset.
Old Jun 1, 2015 | 09:06 PM
willexoIX's Avatar
I had figured that was the case, but all the ones I came across had them in line.
Just looking to find one quick that may have been used before, cause I can't use the ball flange with the stock starter on the turbo headers.
If not I have to make the headers where the one side is very difficult to remove. Before they were just difficult with the 3 bolt collectors. LOL
Old Jun 1, 2015 | 11:19 PM
willexoIX's Avatar
This looks to be close. Thoughts?
http://www.ebay.com/itm/New-Starter-Chevy-3-High-Performance-High-Torque-Mini-168-Tooth-9000899-6449-/271168669682?hash=item3f22e987f2&vxp=mtr
Old Jun 2, 2015 | 12:45 AM
jakemussman's Avatar
Car: 1990 Camaro RS
Axle/Gears: 10 bolt, 3.73 Ratio, Torsen LSD
Just get one for a 350 that says it will fit a 168 tooth ring gear. Many performance mini starters will work for either 168 or 153.
Old Jun 2, 2015 | 05:17 AM
willexoIX's Avatar
Will this fit the 148 tooth 2.8 flywheel? That is neither 168 nor 153.... Do you have a 2.8/3.1/3.4 with one of these starters on it to make sure it works? I want facts here.
Old Jun 2, 2015 | 08:34 AM
Car: 1989 Camaro RS
Engine: LH6
You could try it. I highly doubt many if anyone has tried a mini-starter on a 60*6 in a F-Body. I'll take a look at my 327 and see where the bolts line up. If they are staggered like that ebay link I'll buy it and let you test it.
Old Jun 2, 2015 | 09:09 AM
willexoIX's Avatar
I appreciate that, I just dont have the funds to toss around to test a bunch of them.
Old Jun 2, 2015 | 10:10 AM
project89's Avatar
Re: V6 mini starter?? Where?? Read first post BEFORE you respond.
willie i recall somone using either a 4th gen f-body starter which was the smaller type or a late model 3100/3400 starter , ill see if i cant dig up the info for you
i do recall it being a bolt in deal
Old Jun 2, 2015 | 10:52 AM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Fact of the matter is that there are no off the shelf "mini-starters" for the RWD V6.
Anything posted will be speculation, maybe even fairly educated speculation.
If you don't want help, even if it's not 100% known to be exactly what you want, don't create a thread that will be filled with possibilities. Do you own research then, using search engines and existing posts.
Creating threads with these directives only serves to waste peoples time, and frustrate others.
Frozer!!!
Jan 19, 2024 04:55 PM
mhatfield 14
Oct 24, 2015 07:48 AM
Wesly_66
Aug 26, 2015 09:55 PM
Dialed_In
Aug 20, 2015 01:45 PM
milk
Aug 10, 2015 06:26 PM
