Trueleo intake
Old Feb 21, 2016 | 08:17 PM
Wafflestomp's Avatar
Car: 1987 Camaro, 1984 Camaro Berlinetta
Engine: cammed 2.8, turbo 3.1 hybrid
Axle/Gears: 3.42 one tire fire
Trueleo intake
Any one know where I can get a Trueleo intake I know they aren't made anymore I'm building a twin turbo set up on my 2.8 and wanted to upgrade to a better flowing plenum the SR14 (short runner)
Old Feb 21, 2016 | 08:45 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: Trueleo intake
From what I've seen the Trueleo intake was not an improvement over stock.
Old Feb 22, 2016 | 09:03 AM
C2YT's Avatar
Car: 1991 Camaro RS
Engine: 4.8l LS
Transmission: TH350
Re: Trueleo intake
You are probably going to be very hard pressed to find one, I would check eBay or some fiero forums. Why twins?
Old Feb 22, 2016 | 04:47 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Re: Trueleo intake
What he said. Twins are just for show really imo when it comes to what we are planning to accomplish with our engines.
Old Feb 22, 2016 | 06:34 PM
Re: Trueleo intake
I don't know just want twins I guess, If I can't find a Trueleo I'll build a dual throttle body intake, one turbo per 3 cylinders... thanks to the replys though
Old Feb 22, 2016 | 07:31 PM
C2YT's Avatar
Car: 1991 Camaro RS
Engine: 4.8l LS
Transmission: TH350
Re: Trueleo intake
Honestly, twins complicate things to much. It costs more money, takes more time, and involves more work. But if that is what you want, then go for it man. Post up some pictures when you start, I'm sure all of us would love to see it.
Old Feb 22, 2016 | 08:28 PM
Re: Trueleo intake
Will do I hope to start the build this summer
Old Feb 23, 2016 | 03:40 PM
broke91firebird's Avatar
Car: 1991 Pontiac Firebird convertible
Engine: 3.1 soon to be 3.4/3100
Axle/Gears: original gears, for now
Re: Trueleo intake
I second what C2YT said. I want to see some pictures when you are building and once you are done. I had a similar plan for my 3.1 but I have decided on a single t3/t4 for ease.
My intake plan is to go with something similar to the one below, although much cleaner looking.
Old Feb 23, 2016 | 03:48 PM
C2YT's Avatar
Car: 1991 Camaro RS
Engine: 4.8l LS
Transmission: TH350
Re: Trueleo intake
Post up some pictures of your project in a new thread man! Always love to see different builds.
Old Feb 24, 2016 | 06:05 AM
Re: Trueleo intake
Those pictures aren't mine. I will be doing chronicling the build when I make mine.
Old Feb 24, 2016 | 12:46 PM
hotrodhonda02's Avatar
Re: Trueleo intake
Ha ha ha there were only like 3 ever made for our cars, my old one, and two others.... all indicated 35hp improvement over stock setups to the rear wheels. Mine was the only one built to use a 65mm throttlebody, and with the cam I had, u saw more than the 35hp increase...
Old Feb 25, 2016 | 11:02 PM
Re: Trueleo intake
Very close to what I'm doing however I'm gonna try replicating TLGs design for the intake however if it deems too difficult I was gonna switch to that design you posted... also have you figure out whether you need and how to run if you do 2maf sensors since there will be 2 throttle bodies??
Old Feb 25, 2016 | 11:16 PM
Re: Trueleo intake
Mines a map set up so I don't have the maf issue, but there are several issues I'm still trying to figure out. Mainly with whether or not I can split the tps feed and still have it ready right . I'll start posting again to my thread here:
https://www.thirdgen.org/forums/v6/7...um-intake.html
Keep us posted as i'm always intrigued to see new things. Good luck!
Old Feb 26, 2016 | 12:20 AM
Re: Trueleo intake
You only need a single TPS, since both throttle bodies will be opening at the same rate, or at least should be with the split intake design.
Old Feb 26, 2016 | 07:46 AM
Re: Trueleo intake
Ok thank you
Mattkovitch
Apr 1, 2016 04:08 PM
BOTTLEDZ28
Brakes
Feb 21, 2016 11:44 AM
Mark Stanley
Feb 21, 2016 12:58 AM
LeeCross
Feb 19, 2016 02:45 PM
66_C10_TPI
Feb 16, 2016 04:24 PM
