Belt routing
Old Mar 12, 2018 | 02:57 PM
HellHound's Avatar
Car: I drive trans am. Duh
Engine: Yes, I have one in the trans am
Transmission: I have one of those too In trans am
Axle/Gears: In the rear of trans am
Belt routing
Okay I have a v6 2.8. No ac no smog pump. Routing The serpentine belt, am I doing this right? The belt is a dayco 5060825 from autozone but it is really close to the water pump. I lost a new belt this morning and just put a new one on. I don't want to lose another being they are 27 bucks each.
Old Mar 13, 2018 | 10:58 AM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Belt routing
Your close , but to be routed 100% correctly you have to have the belt going over the idler pulley , which will have the effect of lifting the tensioner pully just enough to keep the belt from rubbing at the water pump .
Old Mar 13, 2018 | 12:20 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
Re: Belt routing
Mine never had the idler pulley, it was routed exactly how yours is and I never had any issues with it rubbing on the water pump. I do agree with OrangeBird though, using the idler will put more tension on the belt, and lift it slightly more.
How did you lose a belt? You put a new one on and it came off while the engine was running? That would make me think either you didn't have it completely on all the pulleys, or you have a pulley that is loose or not lined up with the rest of them.
Old Mar 13, 2018 | 05:39 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Belt routing
IIRC, the power steering pump gets moved a little higher when there isn't A/C. I don't recall the details but try a search here for more info.
RBob.
Old Mar 13, 2018 | 10:14 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Belt routing
I had also wondered about the A/C , if the car was originally equipped with it and the compressor was removed without using non A/C power steering pump brackets , that could very well account for why the belt is rubbing . If the PS pump was higher as RBob said , and if the idler pulley was used like drdave88 and I think would help , it may just get the belt high enough to not rub .
Old Mar 14, 2018 | 07:30 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Belt routing
P/S pump relocation for A/C delete:
https://www.thirdgen.org/forums/v6/6...ml#post5674602
RBob.
Old Mar 26, 2018 | 03:40 PM
HellHound's Avatar
Re: Belt routing
Thank you guys. I'll get on moving the pump. I think the belt just touches enough and causes it to come off.
sflthndrckn
May 15, 2019 02:10 PM
88blkiroc
Aug 11, 2011 08:12 PM
InDa12's
Feb 23, 2002 11:40 PM
wizard
Aug 29, 2001 08:53 AM
Nitro Don
Apr 27, 2001 08:24 AM
