so I have been looking around. And just about ready to start swapping parts. What I can't find is a direct 302 to 730 wiring. Maybe I have not looked in the right spot. What I have found here is some info for 302 to 165, 165 to 730. This leaves room for error and making a mistake. Like I said, maybe I have not been where I need to be for this info, but I don't want the chance of failure from swapping to one then the other. It will be hard to track down what I did wrong if I do it like that. Im boosted and need to get away from the maf, I have a three bar on the way and will start on the program tonight. I post in the sixer side, as I am 2.8 at this time. I figured some one here knows.
I would appreciate any help, or steering in the right direction. Thanks!
I'll be making some changes to this I think. I also have notes that I need to check. I'll add colors too. I have to look at a few more things and double check. Feel free to look over my work so far. And if anyone sees any adjustments that need to be made, feel free to say i f'ed it up. I plan to make an adapter harness this weekend. Should take and hour or two. Hopefully running this week.
7730 c1 blk - '302 connector pinout
A4 5 volt to map. - new wire
a5-c14 5v to tps
a6-a6 ingition
a8-a8 aldl on ‘730 pin a9 for code $59 but also works with stock memcal
a11-a1 fuel pump relay
a12- a12 sys gnd
d1-d1 system gnd
D6 - d6 O2 low gnd wire to the body
d7 - sys gnd. Wire to the body
d8-b5 dist ref pulse high
d9-b9 dist ref pulse low
d12-c9 ac pressure switch
d13-b9 psps power steering
d14-c8 top gear fourth clutch imput
D16-b10 park neutral imput
c1-c1? atg.org has listed as cruse module but c1 on 302 connector pin says not used you have to check on this. I didn’t have this pin.
c7-d5 est bypass
c8-b4 est control
c9-a2 a/c on input
c11-d14 d16 fuel inj control I used d14
c12-c15 d15 fuel inj control I used d15
c16-c16 battery
c3 blk '302 connector pin
f1-b8 upshift indicator manual
f2 there was something up with this. I’ll check my notes.
f4-C2 air diverter valve check on this with code $59
f6-a7 tcc auto check on this code $59
f7-a3 canister purge solenoid
f9- knock
f10- vats
f14 -WIDEBAND
f13-c13 c12 tps imput
f15-b6? map imput (i may just run map wires from the ecm)
f16-a11 mat
e3-c5 iac A high
e4-c6 iac A low
e5-c4 iac B high
e6-c3 iac B low
e7-a5 ses (check engine)
e8-d2 coolant fan
e9-a4 egr control
e12-a9 diagnostic test control
e13-b2 fuel pump control
e14-d7 o2 sensor input narrow band
e15-d6 o2 sensor gnd ? just a straight
I think there was an issue with this. I need to look at my notes again.
e16-c10 cts imput
Well. I came up with this spaghetti on the weekend. Dropped a program in the chip. Car was not exactly happy and ran rich. Have a few bugs to work out. But it ran. What a difference from MAF! Even running dirty it ran differently! So far happy with the progreso soup. I may eventually just repin the car, but this works for now as it don't put me down till I have it all worked out.
I went with $59. I had started from scratch, and got it running, but was like screw it. I am running and driving around week #two. I was going to pull the old chip and replace it (302 ecu), but when I pulled the pins out the tracks were shot. This may have led to some of my issues that I had been having with the car. Idk. But I would have never found it otherwise. it could be fixed, but I am doing fine so for, so I'll keep going the way I am. the car feels good, only at five psi still. Maybe I'll drop the other spring back in on the weekend. 36lb injectors from a super charged olds. With going down on the ecu, it was all in time, and at lest it didnt take to long to get them swapped out.
I really wanted to try the other program, but there are some things that still need worked out with it. And I am not sure I want to be the one to do it. I dont have time. I didnt get any response so I left it be.
I found my emulator, which made a huge difference, and I need to hook up the wideband. I am not over rich, nor over lean. But some where in the middle. Everytime I have a go again it gets better. And I am enjoying my car again.
I will post bin when I get closer.
So. It's been a while, but I have updated the list as I went on and verified stuff. I've had a fuel issue. I will also be going to srt injectors. So she has been sitting and I'm starting again on the new engine. This weekend I decided I had enough, I missed my car. I fixed the broke line drove it around the block and did a burn out. On this kick I decided to actually repin the car. Here is what I found since my quest starting all this.
d6 is O2 gnd add wires
d7 IS a main gnd add wires
d6 and d7 had no where to go on my harness. Sort of. I used a ground block and I powered on different systems in the cars computer originally, so I know they worked and I have to change the list again. Just ground these to the body if you don't have the wires. I have since added those wires. Also I had a map gnd wire on that block at one time, it worked okay. But was better when it was not in the harness or on the block. So just run right off the ecu. Don't even repin off the maf for the map.
there are some wiring wrong with the other chart from the 302/165/730/749 swap thread. No one ever says what it is, or what they did. I used it when I could not find d6 and I could not get it to work. Looking at the other list C10 is also wrong. It should be c11 bank 1, c12 bank 2, for the injectors. I am on c11 c12, my buddy is on the '749 setup with his '730 but different injectors. He was c11 c10 and the injectors would not fire there was a lot of grief there. There are other things on the list not plugged in. I plugged all mine in originally, and it works as it should. I have not hooked up something to the vss yet that was on the loom and it is coughing and spitting while driving now. I had wondered if it was correct.
I had loaned it out (ecu) so I think I had not disabled the check sum and forgot, I also never loaded a new bin on the emulator to try that. Thinking on this now it would have saved me some grief as I could not get any data or anything from the ses, and the light would just stay on. I knew for sure it worked before. Some of this stuff is on loan to someone doing this in a camaro and he is working out his wiring bugs. So I drop a unmolested mem in and I have ses function and aldl port. Go figure. I thought I repin it wrong.
I am using the '749 a9 aldl pin. It also works with stock code mem. Interesting. I will also look at the f4 for tcc. I don't think it was working before. But it was in a different code for sure with this schematic. Software change hardware I guess.
Hopefully I get the laptop back soon and I'll get to work again. I never got the chance for auto tune and I was petty close.
Oh. The wiring colors are damn near identical.
Yes sir I do. The 2.8 is on 15lbs at this time. I had bought a 5lb spring and I got to say it did it’s job. If I started getting back pressure it would open with out a vacuum line. It worked great to keep me under.
Yeah. I don't think I did one. I have some threads I should update.This winter the car is getting blown apart. A re-spray. A swap.
I think there are photos out and about. Let's see...
