'8746 ECU file
Old Oct 17, 2000 | 08:34 PM
gnt_5000's Avatar
'8746 ECU file
Anyone got a ECU definition file for a 1228746 ECM, ('89 305 TBI LO3)? (for Winbin or promedit)
I've searched the web and diy-efi ftp site and I can't seem to find anything...
TIA,
Mark
Old Oct 18, 2000 | 10:14 AM
gnt_5000's Avatar
I'm sure someone is running a 1228764 ECM. What are you using? (winbin,promedit, tunercar, other)
thks
Old Oct 18, 2000 | 10:54 AM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
I started making one (there arent any out there)
if you like i can give you all the addresses and such and you can finish the job but since i swapped to a 7747 I dont need it
Old Oct 18, 2000 | 11:59 AM
gnt_5000's Avatar
Sure, thanks! I started to look at mine and only began finding the spark table (I think ) with WinHex and Excel. If you got the addresses figured out, than it'll make the job easier and a ECU file for the 8746 is finally going to be available.
thanks Pablo,
Mark
[This message has been edited by gnt_5000 (edited October 18, 2000).]
Old Oct 19, 2000 | 04:10 PM
gnt_5000's Avatar
Pablo?...
Old Oct 19, 2000 | 07:18 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
sorry i havent had a chance
ill see if i can get to it tonight
Old Oct 19, 2000 | 07:21 PM
gnt_5000's Avatar
no problem, thanks.
Old Oct 21, 2000 | 12:43 PM
gnt_5000's Avatar
Pablo, if it can help things, you can send it through my e-mail (chevy89 at usa.net)
thansk again for the help,
Mark
I'm eager to finally start burning...
[This message has been edited by gnt_5000 (edited October 21, 2000).]
Old Oct 22, 2000 | 09:30 PM
gnt_5000's Avatar
everything ok?...
Old Oct 23, 2000 | 12:53 AM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
you just emailed me right? if so, check your email
Old Oct 23, 2000 | 03:17 PM
UnderDogRS's Avatar
Pablo could you email this stuff to me also?
amnewman (at) mpinet.net
thanks,
RS
(A.K.A FireBird88)
AOL SN: Zander0710
1992 Camaro RS 25th anniversary edition Adopted Feb,14 2000
Mods:
14x3 Open element w/ K&N filter, MSD GM blaster Coil and 8.5 SC wires, AFPR, 60psi. Fuel Pressure gauge, 3-Row Al rad. , 180* t-stat, Hooker 1 5/8 headers, 3" Catco cat, 3" Hooker Aero Chamber cat-back, "Ultimate TBI" mods
Old Oct 29, 2000 | 01:14 PM
UnderDogRS's Avatar
has anybody got any other info on this ECM that might make things a little more easy on us newbies.
TIA,
RS
Old Oct 29, 2000 | 02:21 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Guys,
If you are serious about burning your own chips and you have the 746 ECM then I would seriously recommend that you consider swapping this ECM for the 747 unit. The 747 Unit is well known on the internet and it has been hacked to pieces in terms of the code. The .ecu file is readily available and TunerCat comes with the calibration file for this ECM. It is very well known and, as I understand it, its a pretty easy swap to complete.
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.244 @ 112.51mph (1.778 60' / 7.819@88.32mph in the 1/8)
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels.
Gunning for NA 11's after installing Hooker LT Headers and reducing weight.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
Old Apr 21, 2001 | 04:34 AM
JPrevost's Avatar
Car: 91 Red Sled
Why swap ECMs? Pablo talked me out of it because I was thinking about doing it. I understand that the 8746 has an IAT sensor while the 7747 doesn't. I don't know if this is very important but it is an extra sensor for the chip to use. I understand that the MAP sensor is the more important but still, why spend even MORE money on an ECM?
, Jon (350 TBI! it's trenuous and efficacious while getting 23mpg highway with off the shelf eprom)
91 Red RS w/grey int, sq stereo (Alpine v12, kicker solo, MB quart premium etc)AIM: JPrevost
  • Holley 670 TB unit w/ 1/2" spacer/adapter
  • Edelbrock RPM vortec intake
  • 350ho 330hp vortec crate motor
  • 8" harm. balancer
  • Stewart stage 2 water pump w/160 thermo
  • SLP tri-y headers to full 3"
  • Rebuilt trans w/ SLP shift kit
  • Centerline 16x8's all around
  • 36/24 mm sway bars
  • Full poly bushings, even motor mounts
  • SLP LCA and panhard
  • Alston SFCs
  • Edelbrock 3 point STB
  • Global west steering brace aka wonderbar
  • Eibach pro kit springs
  • Bilstien high perf. struts and shocks
  • All this and I still have AC
My websiteAny questions?
Old Apr 22, 2001 | 12:44 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
when trax posted that there was no hac out there for the 746 ecm
but now that there is you ahve no real reason to swap being that you know where everything is now
Old Apr 22, 2001 | 04:08 PM
TRAXION's Avatar
Amen Pablo. Good point.
Tim
Gunning for NA 11's with bigger cam, bigger stall, and bigger exhaust.
InfernalVortex
Apr 20, 2021 11:31 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
Jerzyperson
Carburetors
Nov 13, 2015 01:07 AM
KO1
16
Oct 15, 2015 05:00 PM
MitcherNeaf
Sep 24, 2015 09:23 PM
