New Injector Locking Clip
Old Sep 8, 2019 | 02:59 PM
Travis11394's Avatar
Car: 1991 Camaro RS
Engine: 3.1
Just got these 17lb injectors from Southbay and went to put them in and noticed the ring for the locking clip doesn’t line up with the existing injector. The way the new injector fits in, it looks like the clip should go into the bottom ring, but it doesn’t fit on there. When using the top ring, the injector feels too loose on the fuel rail.
When removing the old injectors, one of the clips broke so I only have 5/6 now anyways. Will it make a difference if I use the clips at all once the fuel rail is tightened down to the lower intake manifold? What have others done when replacing injectors other than stock?
Old Sep 8, 2019 | 03:08 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: New Injector Locking Clip
Post 23
https://www.thirdgen.org/forums/tpi/...ing-clips.html
Old Sep 8, 2019 | 03:09 PM
Engine: Lb9
Transmission: M20
Ask southbay08 but I don’t think they are needed
Old Sep 12, 2019 | 10:55 AM
southbay08's Avatar
Sorry for the delayed reply...you do not need them. The pressure from the fuel rail will hold them in place
decked
Oct 2, 2016 08:16 PM
AGDrake57
Jul 30, 2004 12:43 PM
RED92BIRD305
Aug 14, 2003 02:45 PM
ryn28
May 19, 2002 11:05 AM
Kenwood
Mar 24, 2002 02:56 PM
