Ok this may be a stupid question, But
Old Jan 14, 2002 | 03:36 PM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Ok this may be a stupid question but, where is the ECM located in our cars?
I have a 91 3.1 RS Camaro.
Old Jan 14, 2002 | 04:22 PM
CanadianCamaro's Avatar
Car: 1992 Camaro RS
Engine: 5.7 V8 TPI
Transmission: T-5 5-Speed Manual
I'd assume that it would be the same as the 2.8's... up under the passenger side dash. You'll recognize it right away cause its got a whole **** load of wires going into it
Old Jan 14, 2002 | 04:32 PM
Camaro_hunter_d's Avatar
or it could be like mine and be laying on the passanger floor.... LOL but yes it is tucked up into the right hand side behind the plastic ducting.
Old Jan 14, 2002 | 04:47 PM
Kj Rockz's Avatar
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Kewl, thanks..
I'm thinkin that's whats fu*king up my car.
Guess we will see...
Old Jan 14, 2002 | 04:57 PM
Originally posted by Kj Rockz
Kewl, thanks..
it SHOULD pop a code if the self diag function of the ECM fails. I forget the # right now. But anyway it may be the prob as the ECM may not be powering up all the way. Go to www.car-parts.com and check the prices on that. Probly cheaper then anywhere else. Its a nation wide parts search.
Old Jan 14, 2002 | 05:05 PM
Kj Rockz's Avatar
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Thanks Hunter
Old Jan 14, 2002 | 05:09 PM
No Prob thats what I'm here for! LOL
EDIT if the link does not work frop the s from parts. www.car-part.com
I just did a quick search and already below $50 bucks. Minus prom REUSE your old one. The CHIP itslef is probly not bad but a part of the circuit board. And if the chip is bad get the ECM for like 20(I'm sure its that low and get a hypertec or something from autozone for 99 bucks. ECM and Chip for 130ish is not bad.
Old Jan 14, 2002 | 05:23 PM
Kj Rockz's Avatar
Car: 91 Camaro 77K
Engine: 3.1 Vslick
What is the Prom?
Old Jan 14, 2002 | 05:29 PM
Kj Rockz's Avatar
Car: 91 Camaro 77K
Engine: 3.1 Vslick
So You would suggest replacing the chip also?
Old Jan 14, 2002 | 05:54 PM
The Prom is the chip. You should call(You will have to anyway to order the ECM) To see if it DOES include the PROM/Chip. It more then likely will. BUT if the new ECM does not work either take it ahve both tested. YOU MAY find that the Chip is gone/Burned out. Then get the aftermarket chip.
Old Jan 14, 2002 | 06:00 PM
Kj Rockz's Avatar
Car: 91 Camaro 77K
Engine: 3.1 Vslick
kewl, Got ya
Old Jan 14, 2002 | 06:04 PM
Been watchin like a hawk I see.....LOL Sometimes I do too when I need an answer.
Old Jan 14, 2002 | 08:06 PM
Kj Rockz's Avatar
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Any Idea if a ECM from a 97 3.1 cutlass supreme would work?
Old Jan 14, 2002 | 08:10 PM
Do you have the 3.1? and if the systems, Speed density(ON 3.1) versus MAF(On 2.8) are compatible I would think so. So make sure both cars have the same sensors, and measuring systems (Speed denisty) (MAF) there should be no probs. KEY WORD SHOULD. But if nothing else get one for the right year make model and you KNOW it's the same.
Old Jan 14, 2002 | 08:20 PM
Kj Rockz's Avatar
Car: 91 Camaro 77K
Engine: 3.1 Vslick
I'm just wondering, cause we have a Cutlass at home.
All the the places I could get the ECM from are closed when I get out of work.
So I will have to wait till saturday, thats too long.
Well I will try, and see waht happens...
Old Jan 14, 2002 | 09:35 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
sometimes if the ecm is not working, it will not throw any codes.
Old Jan 14, 2002 | 09:44 PM
BitchinRS's Avatar
Yup. That happened to me. It was kinda flaky. It would chose when it didn't want to start. As a last resort I replaced the ECM and bingo no more no start problems.
Old Jan 14, 2002 | 10:58 PM
Kj Rockz's Avatar
Car: 91 Camaro 77K
Engine: 3.1 Vslick
I'm guessing it is the culprit
Old Jan 15, 2002 | 03:20 PM
Kj Rockz's Avatar
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Nope, the Computer from the Cuttlass wont work. Different configuration.
Guess I will have to wait for Saturday to get the part form the Bone Yard...
Old Jan 15, 2002 | 09:38 PM
KED85's Avatar
Doesn't your car have some type of VATS starting system?
Tell us you have played with a test light for the coil to distributor power?
And then test light on the modular?
Old Jan 16, 2002 | 12:32 AM
Kj Rockz's Avatar
Car: 91 Camaro 77K
Engine: 3.1 Vslick
What kind of test light.
To check and see if there is power?
Old Jan 16, 2002 | 08:40 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Good point, Karl! I'm so glad my car doesn't have that damn VATS system in it!
Old Jan 16, 2002 | 09:59 AM
The VATS can be disabled. you have to find the VATS wire that goes to(NOT FROM) the comp and measure the current it sends. Then get a Low voltage wire supply to match that current and patch it in and cut the original. OR find where the wire runs in the column and cut it there at the source, then go through the wiring system to find exactly where it interceeds into the ignition system and remove that junction and splice the wires back togeather.
Old Jan 16, 2002 | 10:12 AM
KED85's Avatar
Go to parts store and ask.
They go for as low as $5.
As simple as a a bulb with two ends on the wire, to test current. Just touch to ends and check current, not amount of current.
I PROMISE, WHEN YOU HAVE CURRENT AND YOU TOUCH IT IN THE IGNITION SYSTEM, YOU KNOW IT!!
Right Tom?
Your VATS must be screwed up.
Seems like you didn't know about it?
How are the rainbows?
I MISS THEM
Happy hunting!
Old Jan 16, 2002 | 12:16 PM
Kj Rockz's Avatar
Car: 91 Camaro 77K
Engine: 3.1 Vslick
But dosent the VATS disable the vehical so that it cant even turn over?
Old Jan 16, 2002 | 10:02 PM
BitchinRS's Avatar
I belive it just ineterupts the fuel flow and ignition system.
Cleotiz
Jan 6, 2018 08:56 PM
3.8TransAM
Sep 3, 2015 06:38 PM
masonta
Sep 1, 2015 06:40 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
