Severe oil leak
Old Aug 28, 2022 | 03:24 PM
KITT87's Avatar
Car: ‘87 Base Firebird
Engine: 2.8 V6
Severe oil leak
For some context, I installed a new oil pressure sensor on my car (1987 Firebird base trim with the 2.8l v6) with no problems. However, when I turned the car on, it sprayed oil everywhere under the car and all over the bay around the filter. Turns out there was a small crack where the sensor screwed in. I’m stumped on how to handle this. Any advice on what to do next?
Old Aug 28, 2022 | 03:32 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Severe oil leak
That piece is bolted onto the engine, and is not a cast in part of the block. It can be unbolted and replaced.
Old Aug 28, 2022 | 04:23 PM
KITT87's Avatar
Engine: 2.8 V6
Re: Severe oil leak
Oh that’s good news, probably would’ve been the end of the project for me if I managed to blow the block. What’s a good name for the part when I’m searching for a replacement?
Old Aug 28, 2022 | 04:29 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Severe oil leak
Generally it's called the "oil filter adapter" or "oil filter housing" and there is one for sale right now on EBay for $50.
The general disclaimer applies, I have no affiliation with the EBay item whatsoever, it's just the first one that fits that turned up in my search........
https://www.ebay.com/itm/374082426806
Old Aug 28, 2022 | 04:33 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Severe oil leak
PS, Rock Auto does sell the gasket your gonna need to install it.....
Old Aug 28, 2022 | 05:17 PM
KITT87's Avatar
Engine: 2.8 V6
Re: Severe oil leak
Thanks so much! I’m gonna continue looking around but this has definitely put me on the right track. I also stumbled across this eBay listing by JC Whitney, do you think this is an option too? Doesn’t look the same to me: https://www.ebay.com/itm/12427530585...mis&media=COPY
Also I have attached some pictures of the problem area.
Old Aug 28, 2022 | 05:29 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Severe oil leak
Your welcome, and no, the one you found won't fit, that one is for the front wheel drive 3.8 engine and is not the same as your 2.8 RWD.....
Old Aug 28, 2022 | 06:59 PM
KITT87's Avatar
Engine: 2.8 V6
Re: Severe oil leak
Alright sweet, you are a lifesaver man! I’ll be ordering the parts once I have everything accounted for.
NerveKiller
Jan 11, 2016 01:07 AM
90Firebird.V6
Feb 12, 2012 08:00 PM
t-topsavage
Pacific Northwest Region
Jan 18, 2011 05:44 PM
JeffroZ
Jul 28, 2008 05:53 PM
