Need help running heater hoses
Old Nov 19, 2025 | 02:14 PM
1990FirebirdV6's Avatar
I have a 1990 firebird 3.1L V6 and Im having trouble finding the heater hose diagram/routing. The previous owner removed the heater hoses and valve to bypass the heater core. I am in the middle of replacing the heater core and adding a heater valve. Can someone please provide a hose diagram or photos where everything goes. Im pretty sure the connections are different from that of the V8 engines. Thanks.
Old Nov 20, 2025 | 02:23 PM
badtenant's Avatar
Car: 92 RS
Transmission: TKX
Re: Need help running heater hoses
Do you have hardline heater tubes or were they removed? They would be attached to the passenger side frame rail. There are several different routing options.
Old Nov 20, 2025 | 03:10 PM
They were removed. I've seen in some photos online that the heater valve is just below the alternator (between passenger wheel well and alternator) I would want to run in pretty much in the same factory location. The lines were removed from heater core. I was looking for a 3.1L V6 hose diagram online but couldn't find one.
Old Nov 20, 2025 | 03:21 PM
badtenant's Avatar
Car: 92 RS
Transmission: TKX
Is this the one you saw? This is from 92 Camaro manual but I assume it is similar...
Old Nov 20, 2025 | 03:45 PM
Its close but it's missing the heater control valve near the alternator. I have the vacuum line that comes from the interior heater control switch secured where the original heater valve is supposed to be located.
Old Nov 20, 2025 | 04:28 PM
badtenant's Avatar
Car: 92 RS
Transmission: TKX
Here is another pipe stup which is probably what was there...
The diverter attaches right above the 3 way pipe section there.
Old Nov 20, 2025 | 04:34 PM
badtenant's Avatar
Car: 92 RS
Transmission: TKX
Old Nov 20, 2025 | 07:57 PM
That's it. Thank you for your help
bbsr72
Sep 12, 2011 01:07 AM
whitez406
Mar 12, 2005 10:33 PM
305tpiz28
Dec 7, 2003 06:13 PM
breathment
Mar 18, 2002 02:45 PM
