Installed!!!
Old Feb 27, 2002 | 11:33 AM
Couldbeone's Avatar
Installed!!!
Installed a new Oil Pressure sender unit last night. Even had it delivered by the local Chevy dealer. Who ever said this job could be completed from the top with a crescent wrench must have used a small one. I had to complete the job starting under the car. However, I was sucessful! The pressure reads about 60 when warm and there are no leaks. I should have bought the socket that was suggested.
Old Feb 27, 2002 | 12:13 PM
WaynesRS's Avatar
good job !
Old Feb 27, 2002 | 02:59 PM
BitchinRS's Avatar
Cool! Yeah I don't know anyone changes it from the top. My arm is to big to get to it at a good angle. The socket does make life a little easier.
Old Feb 27, 2002 | 06:54 PM
Setzer's Avatar
My arms are small, I changed it from the top.
~Josh~
Old Feb 27, 2002 | 08:11 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
my arms are big but i changed it from the top
i had to fanangle it quite a bit...............
Old Mar 1, 2002 | 02:04 AM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
Wow, i must be lucky. Mine magically unscrewed itself when idling one day and i didnt have to screw with the old one...
Old Mar 1, 2002 | 10:28 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I had to do mine from below, too... but mine didn't break... I was putting in a mechanical oil pressure gauge. I was "blessed" with an idiot-light dashboard... oh well. I really like the "that guy added gauges to his car" look!
Old Mar 1, 2002 | 12:42 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
I took mine out from the top also. Not having things in the way like heads, fuel lines, etc help out. the other (small 2-prong)connector is for the fuel pump cut off is it not? it looks like the oil pressure unit for non-guage clusters
Old Mar 1, 2002 | 01:02 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
It's the fuel pump, yeah, but it's not a cut-off. It's a "fuel pump safety switch". If your fuel pump relay takes a $hit, and your engine's running, since oil pressure is up, the safety switch will keep the motor running. I assume it's there so we don't get killed if the pump dies when we try to merge onto a highway. The car will run & start fine with that connector unplugged, but you'll have no backup in case the relay dies.
The later model 2.8/3.1's use a "combo" sensor. Instead of 2 oil pressure sensors (gauge/light and pump), it's one big sucker that runs both, with a combined electrical connector. I had thought this started in '87, but I recently saw an '87 with the two sensors... so this must've started in 1988.
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Apr 25, 2017 07:14 AM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
gixxer92
Sep 1, 2015 04:32 PM
86IROC112
Aug 17, 2015 07:57 PM
