Checklist
Old Mar 29, 2002 | 09:06 AM
WaynesRS's Avatar
Checklist
Saturday I will start with my fuel injector swap .Here's my to buy list .
1. gaskets
2.some kind of sealent to put gaskets back on .
3.carb cleaner
I know I am missing one or two things , what am I missing guys ? Thanx !
Old Mar 29, 2002 | 09:30 AM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
No sillicone Wayne!!!! Just put the gaskets on and bolt it together. Do you have new o-rings??? Also, if you rub a little bit of oil on the o-rings before you put the rail back in your life will be 100 times easier.
Old Mar 29, 2002 | 10:44 AM
Drew's Avatar
Gaskets and gasket sealer are a waste of money.
Just be carefull when you pull it apart that you don't shred the gaskets, and make sure they aren't cracked or damaged.
replacing the injector Orings won't hurt, but again if they're in good shape when you pull it apart dont worry about em.
There's no reason to spend money to replace parts that function as they were designed.
Old Mar 29, 2002 | 06:39 PM
KED85's Avatar
Both tips from Dan & Drew are very correct.
IF you really want to buy gaskets, have them on hand.
BUT you should not have to break any gaskets.
Best tip I can give is to tape your fuel injector wires to identify them.
I went passenger front, Driver front, etc.
Then the wire harness literally fell back into place.
Just observe what ya doing, it is kinda easy.
Detailed, but easy!
Have fun with hoses.
5/16" windshield wiper hose is what you should have on hand to repair any cracked vacuum lines.
YOu'll do great!!
Old Mar 29, 2002 | 07:37 PM
WaynesRS's Avatar
I feel like a kid . Im so excited about doing this tommorrow ! I LOVE working on a car !!!! Thanx for all the great advice Karl , Dan , Drew . I feel a whole lot more confident approching this !
Old Mar 29, 2002 | 07:39 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Dammit, I can't remember the part # - oh, wait, yes I can!! Standard SK-10, I believe, is the part # for the fuel injector o-ring kit. I'm trying to picture the box, I think it says SK-10 on it. Why can't I remember things like this for exams??
I wouldn't re-use the gaskets unless you have to...
If you search this forum, a while ago, I posted the colors for the fuel injector connectors. When I swapped my injectors, I used white-out to label each connector for each cylinder # (cyl 1 is front passenger side, NOT front drivers side)
Old Mar 29, 2002 | 07:54 PM
WaynesRS's Avatar
cool , Thanx Tom !
Old Mar 30, 2002 | 04:59 PM
Engine: LH0 3.1L
Hey Wayne!!!!!!!! Aren't you done yet?????
Old Mar 30, 2002 | 06:15 PM
Drew's Avatar
hehehe anyone else familar with the acronym K.I.S.S.? As in keep it simple, stupid. The more complicated you make a project the more likely it is to get screwed up. Replacing gaskets certainly won't hurt anything, but then again I had my 3.1 apart to change injectors 4 times. If I'd bought new gaskets everytime I had it apart I would have had to sell the car after the second swap.
BTW no need to lable the injector wires. There are two banks, so you've got 3 or one color and 3 of another, they all fire at the same time, so no matter how you hook them up they're still going to work the same. Not to mention the harness will have been cooked enough that you could disconnect the harness bend it out of the way and tuck it under something, for three weeks and as soon as you release it it'd pop back into place...
I've had two TPI 350's apart without replacing the gaskets also, both cars run fine. Of course I'm refering only to intank manifold and throttle body gaskets, if you're dealing with gaskets that seal oil, water, etc then replace them. The beauty of L98's, LB9's, LH0's, and LB8's is that the gaskets are easy to get to, if you have a problem afterwards and you think its gasket related, it'd take less than 5 minutes to swap the gaskets out.
Old Mar 30, 2002 | 06:39 PM
Engine: LH0 3.1L
True, the first time I took my upper plenum off, the TB gasket broke so I replaced it. The plenum gaskets were fine.
Today when I swapped injectors, both TB and plenum gaskets were fine so I didn't need either. It's an easy job too. Had the injectors out in 15 minutes...had the car back together and running in about 1hr and 10 minutes.
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
When I did mine I got 2 swithched around on the same side and the car ran like a pile of crap?I was like wtf is up, so I swaped the two connectors around and the motor ran perfect again.Everyone I had asked at work"lots of mechanics there" said they fired in a batch system at the same time. Did gm change the way the 2.8 and 3.1 injectors fired?
Old Mar 30, 2002 | 08:42 PM
Engine: LH0 3.1L
Nope, 2.8 and 3.1 did use the batch fire system where every injector would simultaneously fire 1/2 the required fuel needed, then the other 1/2 of the total fuel.
The 3.4 got sequential fuel injection where each injector fires the full amount seperately. This allows the ECM to adjust fuel trim sooner. Of course, if you put a 3.4 in a 3rdgen harness, it will use the batch fire system.
Old Mar 30, 2002 | 10:51 PM
WaynesRS's Avatar
Im almost done ! . This has been fun ! No it didn't take me an hour like Dan . It only took me 5 min .hehe yeah , No , Ive been working on it half the day , but I haven't been steady at it . I worked some , stopped and went in and got some more tools , talked to Mom some , then went out worked some more . Then ate crawfish and potatoes for supper ! Im putting it all back together now .The fuel line on the drivers side , I can't get that SOB back in ! , its like it wants to go back in then slides back out , you know there is like a big nutter on it with the line going threw it .how the hell do i get this **** screwed in ?
Old Mar 30, 2002 | 11:15 PM
WaynesRS's Avatar
I FINALLY GOT THAT DAMN NUT , only been working on that damn nut for 30 mins !!!!!!!!
Old Mar 31, 2002 | 12:55 AM
WaynesRS's Avatar
HOT DAMN !!!!!!!!!!! It's 1:15 am and Im psyched up guys ! I made a career out of those injectors today , I had so much fun !!!!! Im READY TO BOOGIE NOW ! Come on guys !! It's ONLY 1:15 am , come on over Dan and lets get that 3.4 swapped in !!!!! I LOVE WORKING ON A CAR !!!!!!! :rockon: :rockon: :rockon:
Old Mar 31, 2002 | 05:11 AM
KED85's Avatar
CRAWFISH!!
I WANNA BE INVITED TO YOUR DINNER TABLE!!!!!
Blessed thing about some 6 cylinders, easy to work on.
Hope this works as well as it should.
Old Mar 31, 2002 | 09:47 AM
WaynesRS's Avatar
Originally posted by KED85
CRAWFISH!!
Come on over ! Better bring your pero ! I woke up this morning and it was raining so hard the water was about to come in the front door . I had to go un-clog the drain in the front yard ! I think Karl has some Louisiana in him ! Usually people say ewww crawfish , gross ! ....Crawfish is my favorite food !!!!
Old Mar 31, 2002 | 01:11 PM
KED85's Avatar
I had crawfish over christmas holiday.
Had about 15 or so.
Put me in the room with a Southern Belle & I'm a puddle
89fast5oh
Aug 30, 2013 10:21 PM
Dirk Edgewoode
Dec 13, 2010 02:22 PM
_87TA_
Apr 26, 2010 10:04 PM
GuitarJunki17
Jul 6, 2006 12:52 AM
1991tealRSt-topGuy
Feb 29, 2004 10:44 PM
