Car 101 4-dummies
Old Apr 2, 2002 | 10:12 AM
confucius101's Avatar
Car 101 4-dummies
CAR 101 4-DUMMIES
ok what is all this stuff and what will it do for me????
-crowler, crane or ari cam
-roller rockers
-Ported and polished heads and intake.
-Headers that Camaro_hunter_d is making
-Better exhaust
-Forced induction Turbo, SC
-K&N filter ram air setups
-TB bypass
better ignition
Old Apr 2, 2002 | 10:17 AM
Joe_L's Avatar
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
Reposted it here in case you didn't see it on the other one.
just basics. Others feel free to go into more detail.
--crowler, crane or ari cam -- By increasing the flow of gasoline and air into your cylinders you will gain hp
--roller rockers-- Creates less friction in the valve train of your car and create more hp. There are sever types you can get. Stock ate 1.52:1 while you can get 1.6:1.
--Ported and polished heads and intake. Smoothing out all the rough textures of the metal in the heads and air intake make the engine breath better.
--Headers that Camaro_hunter_d is making Flow the exhaust out of the car quicker. The faster the exhaust fumes leave the combustion chamber the better.
--Better exhaust (this should be the second upgrade, recommended by everyone.) This is jst obvious
--Forced induction Turbo, SC. Turbo runs off you exhaust, SC runs off you engines belts. What they do is the force into the engine.
(simular to how a leaf blower blows air out. )
-There there are all sorts of little mods that people do. K&N filter ram air setups, TB bypass, better ignition etc. There are other mods than can be found on the homepage. K&N flows more air, TB bypass makes the throttle body cooler, better ignition makes hotter and better spark to the engine.
Old Apr 2, 2002 | 11:01 AM
ok i just tried the links you game me earlier but i still can not get thourgh........
so i'm going to start off with a full tune up as per the tech page your reffered (if i can ever find it LOL)
and while it's in the shop i'll add the new exhaust and the chip
can you recomend any?????
i'm going to try and get most of the small stuff done in one shot my brother told me to just buy whatever i want for it and he'll have his guy's put it together for me but i'm running out of time
Old Apr 2, 2002 | 11:54 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
First, let me send you to this link: http://www.howstuffworks.com Looks like they've added a ton of automotive stuff since I was last there.
Avoid a chip- they don't do much, except for drain your checking account of $70-$300. Save a chip for last, when you've run out of other mods. I ran an ADS chip for a while, I put back my stock one (because of other member's reports of the ADS chip doing nothing), and sure enough, I noticed no difference.
I'd also say to forget about a supercharger or turbo, at least for now. Nothing is made explicitly for our engines. They'll involve a ton of fabrication, and it'll be a lot of work. A v8 could be swapped in for less time & effort (and probably, less cash)- and they sell prepackaged supercharger kits for those.
Next- "while it's in the shop"??? Are you having a shop do this work?? Just curious- why?
Old Apr 2, 2002 | 12:09 PM
lol yes i'll be putting it in the shop of the most part of this
b/c i do not really know anything about any of this........
my brother runs a small shop and said he'll (and his guy's) will walk me through most of it just so i get the feel of it....
i really do not know anything about cars
hell i'm 30 and my wife had to show me how to change a flat
NOW WITH THAT BEING SAID HELP!!!!!!!!!!!!!!!
Old Apr 2, 2002 | 02:34 PM
Crazy Firebird Kid's Avatar
Car: 84 Trans Am
ouch man, and I thought I knew nothing about cars oh well, we all gotta start somewhere. I am 20 and just started learning about all this stuff a few months ago. A lot of the guys on here have been working on cars since they were like 10.
Old Apr 2, 2002 | 02:41 PM
lmao
Old Apr 2, 2002 | 04:38 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
All you need, for real, is the $15 Haynes 82-92 Camaro (or 82-92 Firebird) manual. I bought mine at Pep Boys, or you can get them thru http://www.haynes.com or http://www.jcwhitney.com (I think you have to call their phone #). It'll show you how to do it all. For a tuneup, you just need a $50 Craftsman (or $10 Walmart, but cheap tools break and then you have to buy replacement tools) socket set, a plastic $10 oil drain bucket, $30 wheel ramps (otherwise an oil change will be a bitch), and an oil filter wrench.
Tip for putting the car on wheel ramps- hang an old vanity mirror out of the driver's side window while you pull onto the ramps. This way, you know when to stop. It's better than relying on a friend to yell "stop"! (Usually by then it's too late)
Old Apr 3, 2002 | 12:12 PM
coolrimsatleast's Avatar
Car: 89 f-bird and some others
Engine: 3.4
Don't feel too bad. I once saw a guy trying to put lugnuts on backwards, someone else turning the lugwrench back and forth because he couldn't comprehend that it didn't work like a ratchet, and heard about another dude that couldn't figure out how to lower the floorjack, so when he asked someone else they said,"well if the jack goes up when you push down, try pushing up instead and maybe it'll go down." and he actually tried it.
Old Apr 3, 2002 | 01:27 PM
Camaro_hunter_d's Avatar
LMFAS(Laughing My F****** A** OFF)
Old Apr 3, 2002 | 04:35 PM
Joe_L's Avatar
Car: 1995 Z28
coolrimsatleast Don't feel too bad. I once saw a guy trying to put lugnuts on backwards, someone else turning the lugwrench back and forth because he couldn't comprehend that it didn't work like a ratchet,
When I was 5, my uncle was putting the wheel back on his car, and he told my father to get me away from the car cause I kept putting the lug nuts on backwards, well dad walked over and said which ones did I do... guess who had them on backwards lol.
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
