fourth gen wheels
Old Nov 27, 2001 | 06:59 PM
87_irocz's Avatar
fourth gen wheels
i just traded my 82 z28 straight across for a 87 iroc
the wheels have curb marks all over them
i was wondering if the stock fourth gen five spokes would fit
i really need new ones and i like those
Old Nov 28, 2001 | 07:55 AM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
You need spacers/Wheel adapters. Get them from www.skulte.com or www.vettebrakes.com
Need 2.25" in front 1.25" in rear
1985 ASCD Ram Air Trans Am 350/5spd Pro Action heads, Comp cams XR282, Edelbrock Air Gap, if it can be changed it has Readers Ride at https://www.thirdgen.org/rides/index...ew&rideid=1067
-=ICON Motorsports=-
Old Nov 28, 2001 | 06:57 PM
87_irocz's Avatar
thank you
Old Nov 29, 2001 | 11:12 AM
VampireHunterC's Avatar
Even with spacers, they're gonna rub in fron when you turn to lock, and the parking brake cable will rub in the back. Also, you will need to use flat weights on the inside for balance, especially in the front, cause the regular weights will beat the **** out of the tie rods.
Old Nov 29, 2001 | 01:13 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
This message is from Andris at SPD Skulte Performance Designs. This is in response to the last post. I hope this helps.
The answer is "it depends". First on which rims you are adapting.
17x9.5
is the largest you'll get in the front. At full lock, I had to heat the
inside fenderwell plastic with a hot air gun, and remold it (just
propped
it between the tire and plastic with a 2x4 while it cooled). I haven't
had
any problems of parking brake cables rubbing. That's a matter of
ziptie'ing them in place to clear. No one has mentioned this to me
before. The inside wheel weights were a non-issue, since I always use
the
flat stick-on weights, with some clear tape over them to prevent losing
them. Some wide wheels (17x9.5 ROH ZS's w/ 0mm offset) have tight
clearances between the tie-rod balljoints. Most will clear, but Dan
Burk
did have to file a little from his aftermarket (non-GM) piece to get
proper clearance. The last issue is with 17x9.5's and lowered
suspension. I had to roll the inside fender lip for clearance, but now
it
doesn't rub at all. We've probably helped 150 people put 17x9's or
17x9.5 4th gen/Corvette rims on their third-gens, and haven't had
anyone
get stumped yet. Feel free to fwd this to the thirdgen.org msg board if
you like. I'm running the 17x11/9.5 ZR1 wheel combo right now, and
previously had the 84-87 C4 16x9.5's on all four corners. I hope this
helps clarify a few things!"
Old Nov 29, 2001 | 01:35 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
I have 17" WS6 wheels on my TA. 255/40/17 in front, 275/40/17 in back. I have no rubbing issues at all. none. Perhaps that may change when the car is lowered in spring, but at stock height I have none.
Old Nov 29, 2001 | 04:24 PM
87_irocz's Avatar
i am not putting on the 17" wheels
i'm talking about the a set off a 95 camaro
with the 16X8 wheels
Old Dec 2, 2001 | 10:12 AM
irocluke's Avatar
Instead of using spacers in the back you could also get a rear out of a newer fbody.
88 Iroc 5.7
Many Mods
Happiness in a bottle
www.irocluke.freeservers.com
1992rs/ss
16
Jan 28, 2016 09:58 PM
Omega
Oct 1, 2015 02:20 PM
InfinityShade
Aug 22, 2015 08:00 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
