SLP's response about a wider zr1- 3rd gen wheel
Old Aug 12, 2004 | 08:16 PM
RICHRAD's Avatar
Thank you for your interest in SLP Performance Parts.
The decision to offer the new ZR-1 wheel in a 17 x 8" size grew out of our
desire to make the wheel a direct bolt-on for as many applications as
possible. Based on customer feedback, however, it would appear that there
may be a viable market for larger sizes as well. As a result, we are looking
into the feasibility of offering the wheel in a 9.5" width. It will likely
be some time, however, before such a wheel becomes available.
Be sure to sign up for our electronic mailing list
(http://www.slponline.com/iss/signup.asp) for all the latest product
information.
Thanks again for your interest.
Regards,
Team SLP PP
Old Aug 12, 2004 | 09:49 PM
rdj89gta's Avatar
Car: 89 gta
Engine: 5.7
Transmission: TCI 700r4
To little to late. I wanted 9.5 x 17, 5 on 4.75. Center Line, Eagle, American Racing and all others said sure, you betcha, in two months. Vintage Wheel said one week, took them two. I now have their V 40 wheel with BFG G-force 275r40x17 at all four corners and I am a happy customer.
Richard
Old Aug 13, 2004 | 12:53 AM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Richard
got any pic's of these new rims on your gta?
Old Aug 13, 2004 | 08:21 AM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
I called up and e-mailed SLP the day I saw their ad in CHP... gave me the same exact answer. They are probably as bureaucratic as GM.....
Old Aug 13, 2004 | 09:20 AM
87F383's Avatar
Car: 87 Formula 350
Engine: LS1 in Progress
Axle/Gears: 3.70 9 bolt
That's the same answer they have given my friend over the past 6 months 3 times.... so don't hold your breath...
Old Aug 27, 2004 | 07:27 AM
ColinOpseth's Avatar
Car: 1987 Camaro IROC-Z
Engine: 305TPI
What offset are you guys looking for? I carry the ZR1 in 17x9.5 and 17x11 sizes..
later,
colin
Old Aug 28, 2004 | 09:06 AM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
slp rims are a direct fit for thridgen's no spacers required. not sure what spacing that is though. i also like the rim wish it was a bit wider.
Jeff
Old Sep 2, 2004 | 10:17 PM
rdj89gta's Avatar
Car: 89 gta
Engine: 5.7
I have Vintage Wheels V-40, 9.5" x 17" with 5.5" backspace. My 89 GTA has 4 wheel disc brakes. 89 rear brakes are differant from 88 and before. The wheels just clear with about a 1/8"gap on the front, no problems with rear parking or hydraulic lines. The 275/40/17 BFG G-Force KDWS tires do not rub. The tires stick out just a bit more than stock from the fender . My only complant is that the low profile, wide front tires follow road grooves and cracks that can jurk you around alot. With sub frame connectors, lower control arms, adj. panhard rod, strut tower brace the ride is firm and positive. The wheels seem wide for the tires, I would consider a 9" rim with about 5 or 5.25" backspace, if it could be found. I would post a picture but don't know how. Hope this helps.
Richard
fonzie85
Exterior Parts for Sale
39
Mar 16, 2016 07:07 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Omega
Oct 1, 2015 02:20 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
