ZO6 Wheels..
Old Jun 29, 2007 | 05:57 PM
Blakcamaro's Avatar
Car: 86 iroc
Engine: 496ci
Transmission: stock t5
Axle/Gears: stock/323 posi
ZO6 Wheels..
Hey guys, whats goin on? I picked up some ZO6 wheels at the GM nationals in Carlisle PA. They are 17x9 1/2 with the 54mm offset with 275/40/r17's on all four. I have done some checking around and i know i need spacers but i dont know exactly which ones to get. People seem to recommend the 2 inch or the 2 1/4 inch spacers on all four wheels. I just want to make sure i get the right ones. They're going to go on a 91 Camaro RS. Im looking to have the tires come pretty close to the edge of the fenderwell. I was concerned about the 2 1/4 inch spacers making the tires stick out too far, And do i use the same spacers in the rear as i use in the front?
Just some info and some pics would be helpful
THANKS!
Old Jun 29, 2007 | 06:22 PM
Rocksiroc's Avatar
Re: ZO6 Wheels..
I just put a set of replica c6 vette rims on my 86 iroc z and used the 2 1/4 in spacers and they fit great. They stick out alittle bit more than stock but look awesome. The rims are 17x9.5 with a 56 mm backspace and im running 275 tires on all 4 corners. They fit perfect and only rub slightly at full lock, but no big deal. I havent took pics of my car since putting on the new rims but i should have pics tomorow and will post them for u to see if u like.
Old Jun 30, 2007 | 09:56 PM
Blakcamaro's Avatar
Car: 86 iroc
Engine: 496ci
Re: ZO6 Wheels..
Thanks, if you could do that i would really appreciate it.
Old Jun 30, 2007 | 11:29 PM
Rocksiroc's Avatar
Re: ZO6 Wheels..
I just posted the pics, here is the link to the thread tell me what u think.
https://www.thirdgen.org/forums/auto...s-my-iroc.html
Old Jul 20, 2007 | 07:25 PM
Blakcamaro's Avatar
Car: 86 iroc
Engine: 496ci
Re: ZO6 Wheels..
I got my spacers on the other day. the wheels fit great and they hardly rub. i like it. ill post some pics as soon as i can figure out how.
Old Jul 21, 2007 | 02:37 AM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
Re: ZO6 Wheels..
just put smaller tires on the front 245/45's should do away with the rub
Old Jul 24, 2007 | 07:21 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Re: ZO6 Wheels..
As I respnoded to another post, If the 17x9.5 wheels have 54mm offset, use a 2" adapter along with an 1/8" spacer (if you have the factory front brakes),, or use a 1.75" adapter with 1/8" spacer if you have 1LE front brakes),, this will minimize how much the wheel sticks out past the fender and will not rub the tire-rod.
I did a 1LE upgrade on the front end, I am using a 1.75" adapter with 1/8" spacer having 54mm offset 4th gen SS wheels.
On the rear, use a 1.75" of 2.0" spacer. I am using a 2.00" adapter having 58mm offset 18x10.5 wheels.
Old Jul 24, 2007 | 09:55 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Re: ZO6 Wheels..
You'll need 2 1/4" with 17 x 9.5 +56mm wheels, trust me I know. I tried 2" on the front, nope, had to order a set of 2 1/4", the tierods just miss the rim by a few hairs.
Doc, 17x 9.5 wheels are available in different offsets, each requiring a different width spacer. And your 18" setup info is of no use to those with 17" wheels.
I would personally not trust using more than one spacer on a wheel at a time. Although it may or may not be ok
Old Jul 24, 2007 | 10:10 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
Re: ZO6 Wheels..
2 1/4" makes the fronts flush with the rears.
Old Aug 11, 2007 | 09:29 PM
Blakcamaro's Avatar
Car: 86 iroc
Engine: 496ci
Re: ZO6 Wheels..
I finally figured out how to post pics. here are a few. ill put some more up later on after i clean it up a bit.
Old Aug 11, 2007 | 11:53 PM
Rocksiroc's Avatar
Re: ZO6 Wheels..
Looking good im glad i could help u out.
Nice ride
Old Aug 12, 2007 | 04:04 PM
ssean92's Avatar
Car: sold
Re: ZO6 Wheels..
I am glad you posted these pics, have been thinking about puting these on my car inplace of the zr1's, I hadnt seen any maroon cars with them on....... I am still in the air
Old Aug 12, 2007 | 11:36 PM
Blakcamaro's Avatar
Car: 86 iroc
Engine: 496ci
Re: ZO6 Wheels..
I did see another car on this forum with the ZO6 wheels on it, thats what got me to like them so much, plus i got a pretty good buy on mine. i prefer the ZO6 wheels but the ZR1 wheels look great also.
fcorallo
Aug 20, 2015 11:28 PM
Neil
Brakes
Nov 21, 2004 10:23 AM
Ramair21
Aug 20, 2004 10:12 PM
RGS1260
Aug 15, 2002 11:25 AM
magnus
May 18, 2001 12:34 AM
