Max tire size with stock 16" rims
Car: 91 Camaro RS
Engine: 5.3
Transmission: Th400
What is the max tire size you can put on a 1992 camaro rs with 16" rims. I tried searching but didn't find a definite answer .
Car: 87 GTA
Re: Max tire size with stock 16" rims
The BFG 295/50R16 is the widest street 16" & a good fit for oue wheels & the car.
The next street tire width down is a 255 & made by lots of manufacturers.
Car: 87 iroc
Engine: 410 sbc
Transmission: tremec 3550
Axle/Gears: 30 spline 3.73
i've seen this size tire mounted before, and honestly i wouldn't drive on it. the sidewall is so bulged because it's too big for that narrow a rim. i would thing it would roll back and forth on the tire and be unstable.
Car: 87 GTA
Did it on my 92 RS with stock wheels & a 8" rim falls within BFG recommended sizes for the 295/50 tire. The 50 series sidewall gives it the "Pro Street" looking bulge. I never once had a problem driving on them.
Car: 1990
Axle/Gears: stock
wait i know we have done this link before! lol.
our stock height is 26 inches. i posted a chart here https://www.thirdgen.org/forums/susp...-pick-out.html with tire heights compared to width. you should down load it for reference.
and here http://www.1010tires.com/TireSizeCalculator.asp is a tire size calculator.
and if you go here http://www.tirerack.com/tires/Compar...=All&x=81&y=10 you can get a comparison of width as well as tread width and max size for your rims. go into specs and you will see the tire size and the max rim size as well as how much rubber is on the road.
i went to 275/60 15 in the rear and it was pushing it - rim size as minimum rim is 7 1/2 inches and im only 7, you are 8 inches and should be able to handle 275 with no problem - maybe even 295 - but i found that 255 was as big as i could go on the front. but others have gone bigger and done it with style.
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Are you wanting the width for the stickiness of a wider tire or the look of a wider tire?
Car: 1990
Axle/Gears: stock
Car: 87 GTA
OH: I was automatically assuming the rears.I ran 255s front/295s rear, on the 92 RS I posted above.
On my 17", I currently have 275s front/285s rear. But for a 16", there is no street tire, between 255 & 295. I wouldn't even try the 295s up front.
Car: 91 Camaro RS
Engine: 5.3
Transmission: Th400
thanks for all the replies , i was looking for wider tires to get more traction. I was looking at mt 295's and didnt know if they could fit. But i could always use the 255's, This is for a street car.
Car: 1991 RS Camaro
you talking about drag traction or cornering traction?
Car: 1990
Axle/Gears: stock
if its traction you want on the rear then firestone, bfg or goodyear is not your best bet, for cornering or drag racing.
there are much better tires for that.
the above 3 are just for street show and go, and the firestone puts a little more tread on the pavement than the other two for the same tire size, but not much.
Car: 1991 RS Camaro
I'd look into some good DRs then. The 295 BFGs aren't a terribly sticky tire. I think they are 400 A B. I've heard alot of good things about the Nitto DRs as a combination street tire/ launch tire
Car: 91 Camaro RS
Engine: 5.3
Transmission: Th400
Car: 91 Camaro RS
Engine: 5.3
Transmission: Th400
Wow i feel really dumb now . I went out and looked to make sure i had 16s like my other 92 camaro rs , but realized this maro has 15" rims , what is the width difference between the two?
Car: 87 GTA
Car: 91 Camaro RS
Engine: 5.3
Transmission: Th400
haha , that would mean these tires are to big then right?
http://store.summitracing.com/partdetail.asp?autofilter=1∂=MTT%2D3753R&N=700+4294923107+4294922134+4294793325+4294839615+4294904676+115&autoview=sku
Car: 87 GTA
SHOULD THEY? No....
Car: 91 Camaro RS
Engine: 5.3
Transmission: Th400
Haha
but im tempted to try it anyway , im mounting it myself . I really may to find a bigger rim , but i dont really have have the cash flow. I really like the mickey thompsons , i have only heard good about them .
but im tempted to try it anyway , im mounting it myself . I really may to find a bigger rim , but i dont really have have the cash flow. I really like the mickey thompsons , i have only heard good about them . Banned
Car: 87 GTA
How about a "stock" 15" x 10"/11"/12" wheel?
Weldcraft Wheels
Car: 91 Camaro RS
Engine: 5.3
Transmission: Th400
what would be more expensive having them widened or just buying new ones to put new tires . And just switch them out when i race.
Car: 1990
Axle/Gears: stock
you will be ok with those but probably not for drag racing. i run 275/60 15 on stick rims and its a little bit of a bulge not a lot. i think it gives me about 9 inches of tread on the ground. you will have 11 inches of tread - that is 2 extra inches outisde of each side of the rim and 10 inches on the dirt.
but it is the correct height 26 inches. make sure your front tires are not taller than that - although that once was the style, back in the day.
Car: 87 GTA
So it depends...Do you like the stock sleeper look (or want a certain wheel that doesn't come in the size you WANT) but have WIDE tires, or do you want custom wheels? $400 (if they charge the same for those stock wheels) vs 4 new custom wheels.
Weldcrafts charge may be higher or lower, depending on the wheel you want widened.
Car: 91 Camaro RS
Engine: 5.3
Transmission: Th400
Well I rarely go to to the track , its for a d.d. but i do the occasional stoplight to stoplight. I love the look of a wide tire , but i want it mainly for traction. It will most definitely be taller than my front.
Car: 91 Camaro RS
Engine: 5.3
Transmission: Th400
Weldcraft wanted $200 per wheel, to widen my 17" x 9" ROH Snypers, up to 3" wider.
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
The widest tire I would stick on a 16" x 8" wheel is a 245-50-16, stock size for the car. Anything bigger will just hang off the wheel and hurt handling and possibly compromise safety.
Car: 91 Camaro RS
Engine: 5.3
Transmission: Th400
ok thats good to know , just so you know i corrected myself earlier in the post its a 15" wheel . I want to be safe about it , but i do like the bulge look.
Car: 1989 Chevrolet Camaro IROC-Z
Engine: 355 SBC
Transmission: TH350 with 3500 stall
Axle/Gears: GM 12-bolt with 4.10 gears
Hey, I have a 295/50-15 slapped on a 7 inch wide rim :P They do bulge out a lot but I've never had any problems with them. And I drive my car hard... Anyhow, I wouldn't suggest the street radials for a daily driver because unless you drive around with your tires at 15 psi on the street it wouldn't give you any real advantage as far as traction goes. They do look real good though.
Car: 91 Camaro RS
Engine: 5.3
Transmission: Th400
thats good to know. i think i will end up running a 275. 295 seems a little extreme to me for a 7in. rim. I will keep the air pressure up until i get the weird urge to set my foot to the floor extremly fast
Car: 89 FireBird
Transmission: AUTO
running a 275 60 15 on rear is 28" and a 235 60 15 on the front is 26" will this cause a problem?
Car: 87 GTA
https://www.thirdgen.org/forums/fabr...l-cutting.html
Car: 89 FireBird
Transmission: AUTO
28" tall rear tires is a bit big. Read this thread to the end & you'll get what I mean.
toronto formula
Nov 10, 2015 06:17 AM
Linson
Aug 21, 2015 02:12 PM
knight72
Aug 10, 2015 09:32 PM
