20 inch rims could they work
Old 01-13-2010, 09:16 AM
Zyddian's Avatar
Car: 84 Firebird
Engine: V8 383
Transmission: 700 R4
Hi I am a huge fan of Chip Foose... I love his styling and that he always uses the larger rims. I wanted to know if I could get 20 inch rims to fit on my Firebird. 84 Bird by the way. Could someone please give me some info on this, or point me in the right direction?
Thanks Guys!
Old 01-13-2010, 10:16 AM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
Re: 20 inch rims could they work
I'm not a fan of Chip Fooses work honestly. His work on Overhaulin is a bit better because it's what the car owner is supposed to want. I think that keeps him from going too crazy. I think he also goes too large on the wheels and tires. Enough with my opinions.
20's would be difficult to pull off on a third generation car. I don't think the wheel wells are large enough to handle them. With that said I've seen some fairly large wheel and tire combinations fit on these cars, but not nearly as large as what I've seen on newer vehicles. Most cars from the time period can't take them with out a lift kit or some serious changes to the wheel well area. That's why you see all those Buick's and Caprices from the 80's rolling on 20"+ wheels in the ghetto sitting more than 12" off the ground.
Old 01-13-2010, 10:28 AM
Zyddian's Avatar
Car: 84 Firebird
Engine: V8 383
Yeah definately don't want the pimp daddy look that looks like utter crap!!!!!!!!!!!!!! Any suggestions as far as a little bit smaller then 19's? 18's?
thanks!!!
Old 01-13-2010, 12:34 PM
87WS6's Avatar
thanks!!!
I know 18's will work. Not sure about 19's.
Old 01-13-2010, 05:09 PM
firbster's Avatar
Car: 84 Z28,03 GSXR1000,07 RMZ 250
Engine: H.O. L69
Transmission: 5spd
Axle/Gears: 3.73 possie
im putting corvette c6 rims on my car .. 18x8.5 fron and 19x10 rear... check the corvette rim thread for pics
Old 01-13-2010, 05:26 PM
Twin_Turbo's Avatar
Sure 20s will fit:
Old 01-13-2010, 05:27 PM
PorkchopExpress's Avatar
Here are 20's from a member of the forum.
https://www.thirdgen.org/forums/memb...sion-over.html
Personally I like the looks of 17's, but props for the clean job he did with the 20's.
Old 01-13-2010, 06:43 PM
DiabolicalRS's Avatar
Car: '90 Camaro
Engine: 305 tbi
Axle/Gears: 9 bolt posi 373
haha lol yea i totally agree with you on that. what part of tx you live in cause thats all i see are "donks" those cars are stupid... rims cost more than car lol
Old 01-13-2010, 10:14 PM
87WS6's Avatar
Still too much wheel for me, but it looked better than I thought it would. 17 or 18" wheels are about as large as I'd go on these cars.
DFW.
Old 01-14-2010, 07:35 AM
Transmetal's Avatar
Car: 89 Trans Am GTA
Engine: 5.7 350 TPI L98
Axle/Gears: Borg-Warner 3.27
Those 20's look sick on that gta! I probably would do something like that if I could just buy em, throw em on the car and it had that stance. Don't really want to lower my car as it already seems like it's on the ground so I went with a 17x9.5
Old 01-14-2010, 07:41 AM
Zyddian's Avatar
Car: 84 Firebird
Engine: V8 383
Hey thanks everyone really appreciate all the help... Say what year Firebird is that in Twin Turbo's picture? Is that a 92?
thanks
Zyd
Old 01-14-2010, 07:47 AM
Twin_Turbo's Avatar
92 gta
Old 01-14-2010, 08:44 AM
Zyddian's Avatar
Car: 84 Firebird
Engine: V8 383
thank you
Old 01-14-2010, 09:46 AM
87WS6's Avatar
Yeah I looked through that thread. Some of the rim choices look good, others, not so much.
Old 11-07-2010, 08:54 PM
procharger728's Avatar
Originally Posted by Twin_Turbo
Sure 20s will fit:
hi do you know the back spacing on these wheels thank you
Old 04-25-2011, 04:54 PM
DoWork2day's Avatar
Car: 1989 IROC 406 SBC (2012 Fusion)
Engine: 406 Chevy-World Sportsman heads
Transmission: 700R4 B&M, Redline clutches, 2800
Axle/Gears: Australian 9 bolt,I think 3.73
Please respond quickly if you can, I might buy these 20 inch wheels from a Cadillac. They are 600 bucks with 5 tires...... Boss Rims. He says they're 5x120mm so they should not have a problem with the lug pattern....... BUT.....
The thing is I won't be driving my Camaro to test fit them. I have an S 10 pickup. I hope the calipers will clear on the Camaro....... sure I will need backspacers...... but DO YOU KNOW WHETHER OR NOT IF THEY FIT THE FRONT OF MY 1994 S10, DOES THAT MEAN THEY WILL FIT THE IROC?
Old 04-25-2011, 11:28 PM
DoWork2day's Avatar
so I tested the fit on my S10, they fit.
Then, I found a 6 inch crack on one of the rims. They thought I wouldn't notice? Tried to scam me out of 6 hundred dollars. I stayed calm, that kid is going to run into the wrong person. I drove 89 miles one way to go buy them. Craigslist scammer.
Old 04-25-2011, 11:31 PM
90 camaro cj's Avatar
Car: 1990 camaro RS
Engine: 305 TBI
didnt someone have 22s slammed on a z28?
Old 03-02-2019, 12:41 AM
Rudy Medina's Avatar
Sure 20s will fit:
How are you, im wanting to put 20s on my 1987 Formula as well. But I know with the rotors and spindles now on it will not work. What parts did or does you car have for it to work. And what sizes tires as well. If you don't mind. That is a very nice looking Pontiac.
Old 03-08-2019, 09:09 PM
Zach/90\irocZ's Avatar
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
20s work well if you get the stance just right and a good looking wheel
other than that I wouldn’t do 20s
19s is perfect tho
Old 03-08-2019, 10:31 PM
Sure 20s will fit:
This is my 1987 Formula
Old 03-08-2019, 11:43 PM
Engine: 305 to 350
Axle/Gears: 10 Bolt
What exaclty are you trying to say ?
Old 03-10-2019, 04:10 AM
Twin_Turbo's Avatar
Nothing special. It's a set of stock spindles with a j56 brake upgrade using 1le rotors turned into hubs. Wheels are off the shelf ar. They fit just fine. No spacers or anything. They only look ok on gfx cars. I wouldn't run anything over 19s on non gfx cars.
Old 03-11-2019, 02:04 AM
Engine: 305 to 350
Axle/Gears: 10 Bolt
Old 03-11-2019, 02:05 AM
Engine: 305 to 350
Axle/Gears: 10 Bolt
20s done right
Exxon Limited
Camaros Wanted
22
12-21-2015 10:36 PM
kyleb24
08-15-2015 08:24 AM
Randomtask2
08-13-2015 01:57 AM
Ginamariegault
Brakes
08-10-2015 08:33 AM
Exxon Limited
08-09-2015 08:13 PM
Quick Reply: 20 inch rims could they work
