Custom ordering wheels...
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
What spec should i give to have rims fit on a 3rdgen with out spacers? 5.5 front and rear? The rims will be 18x8
Re: Custom ordering wheels...
yes 9 bolt BW
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
18x8 with 4.5bs and 4.75 bolt circle works great, with or without a brake upgrade in the front. Thats what i used for years.
dont want to go a little wider on the rear?
I kinda don't want to run staggered wheels, id like to route them lol
i spouse i could go 18x9 all around but jumps up tire cost...
4.5 backspace is what stock is on 16x8 correct? a custom set order with 4.5 specs should clear ls1 brakes id assume?
Car: 1986 z28 & 1992 z28
Transmission: 700-R4
The backspacing doesn't determine whether or not the wheel will clear your brake caliper. You shouldn't have any clearance issues with ls1 brakes and 18" wheels. With the ls1 brakes, I would go with 4.75" backspacing. I used 4.75" backspacing for my custom 18x8" wheels (c5 brakes), and 6.25" backspacing for the rear 18x10.5" wheels.
Car: 86 Trans Am
yes
both will work fine. not all places make wheels with .25" bs sizes however, so it matters where you get them and what the are
i assume you have a 3rd gen rear, not a 4th gen
