Rear Question
Old Oct 24, 2011 | 07:08 PM
91 Droptop's Avatar
Engine: 355 Super Charged
Transmission: B&M Streetfighter
Axle/Gears: 4th gen 342
Rear Question
If I put a 4th gen rear in I can run any rims I like with no spacers? sorry if this has been asked but I have a 2002 SS in my yard that is a theft recovery. I can bull the rear before I scrap it
Old Oct 24, 2011 | 07:46 PM
3rd Coast Z's Avatar
Car: 1987 IROC Z / 1999 Suburban 2WD
Engine: Lingenfelter 383 / Vortec 350
Transmission: 700R4 / Built 4L65E
Axle/Gears: Stock / 4.56 Locker
Re: Rear Question
You can run vette and 4th gen wheels without adapters. But the rear end is stronger and depending on your gear it will probably be a step up there too. Keep the rear for sure.
Old Oct 24, 2011 | 07:55 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Rear Question
gearing, maybe, but his 91 will have 28 spline axles too, so no difference in strength.
Old Oct 24, 2011 | 08:10 PM
91 Droptop's Avatar
Re: Rear Question
Thanks I will pull it, there nothing left but the basic shell
Old Oct 25, 2011 | 04:03 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: Rear Question
As mentioned, it's still just a 7.5 10-bolt. No stronger than anything else.
HOWEVER - it may hve the Zexel Torsen posi carrier which is super rad. I'd love to have a 10-bolt with a zexel torsen! So if you junk it at least pull the axles and pull the carrier out of it.
Old Nov 2, 2011 | 01:47 PM
91 Droptop's Avatar
Re: Rear Question
Well it looks like the only only real difference is that the rotors on this 4th gen have a built in spacer, the rear ends are identical. Is this what allows you to run 4th gen wheels on a third gen car, just checking.
Old Nov 2, 2011 | 02:01 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Rear Question
I'm unsure of what spacer you're referring to. Have a pic? The fourthgen rears are, of course, a bit wider.
JamesC
Old Nov 2, 2011 | 03:47 PM
91 Droptop's Avatar
Re: Rear Question
The unit its self looks to be the exact same size, i need to measure it, when I lay the two rotars sisde by side the fourth gen is taller
Old Nov 2, 2011 | 03:50 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: Rear Question
Any pics? Your rotor description sounds like a rotor with the adapter still on it.
Old Nov 2, 2011 | 04:08 PM
91 Droptop's Avatar
Re: Rear Question
I will need to snap ome tomorrow, but the rotor is factory or aftermarket, no adaptor that I can see
Old Nov 2, 2011 | 04:20 PM
91 Droptop's Avatar
Re: Rear Question
Okay maybe it is just a heavier duty rotar, question is I can run the 4th gen wheels on the rear and front with no spacers correct?
Old Nov 3, 2011 | 02:29 PM
91 Droptop's Avatar
Re: Rear Question
with both rears side by side, axle flange to axle flange measurement on the 82-92 car is 61.72” and the axle flange to axle flange measurement on the 93-02 car is 64.72”.
Old Nov 3, 2011 | 03:41 PM
JamesC's Avatar
Re: Rear Question
You may find the following FAQ concerning 10-bolts interesting:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Nov 3, 2011 | 06:03 PM
91 Droptop's Avatar
Re: Rear Question
Yes it was, I was also looking at your pic's, I will be running 4th gen wheels so I will not stick out (though I do like the look) Lots of good info. I measured mine just because I heard so many differant sizes at every way I turned
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
redmaroz
Aug 16, 2015 11:40 PM
