Firebird wheels on my Z28? Need an ID.
Car: 1985 Z28
I bought this 1985 Z28 with the wheels in the picture. I think they are FBird wheels. They are 16" s. I want to get center caps, but am not sure what to order. ebay has a ton of choices so I'd appreciate some input on the right size. does anyone recognize these wheels? I've done a lot of cleanup on them but don't have a pic of them clean.
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
Re: Firebird wheels on my Z28? Need an ID.
Those are Trans Am/GTA wheels 16x8 and they are offset, look on the backside of the rim it will say front / Rear..,.........
Car: 1985 Z28
Thanks for the info. I did notice the front/back difference when I put new tires on. Now I need to find center caps.
Car: '84 Firebird TA & '87 Camaro LT
Engine: 350 V-8 & V-6
Axle/Gears: 3.23 & 3.42
This may say for Camaro whttp://www.ebay.com/itm/NEW-1982-1992-Chevy-CAMARO-Wheel-Hub-SILVER-Center-Cap-SET-/110780652562?fits=Model:Camaro&hash=item19cb0a9c12&item=110780652562&pt=Motors_Car_Truck_Parts_Accessories&vxp=mtrheels, but I believe they will fit the Firebird wheels also:
yoiui can probably check with the seller regarding the center hole diameter and flange, they look to be the same on my camaro and firebird wheels.
Car: 1985 Z28
My only concern is that ordering OEM caps for a Camaro or Z28 may not fit the GTA wheels. I don't really want Firebird centercaps on a chevy. If they are interchangable then it is a done deal. Camaros that year had 15 inch wheels and the Fbird wheels are 16's. Would the centercaps differ?
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
And you can change out the Firebird/WS6 emblems for Camaro ones & your set.
Car: GTA
http://moderndaymuscle.com/exterior1?cmx=163&start=100 next catalog page has more.
Car: GTA
Somewhere I coulda swore I read Camaro wheels & you wanting Firebird center caps for them...Weird.
Ignore my PM. Except that double check the Camaro emblems diameter to match the crosslace wheel center cap emblem diameter.
Car: 1985 Z28
No problem. They are Fbird wheels on a CHEVY. I want centercaps that do not say Pontiac, Fbird, etc. The info you passed on was helpful. thanks.
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
if you want actual GTA caps that say camaro or IROC you will have to make your own. I just made my set last week
https://www.thirdgen.org/forums/fabr...rted-iroc.html
1992rs/ss
Jan 31, 2025 05:10 PM
colton_carlson
Mar 8, 2019 12:21 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
