can i fit 275 tires on the front of my car?
Old Mar 27, 2012 | 01:21 PM
kcaalarcon's Avatar
i have an 88 firebird and i was looking at getting a set of 275/35/18 tires front and rear and i was wondering if there would be any clearance issues on the front. my wheels have an ofset of about 40
Old Mar 27, 2012 | 01:51 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: can i fit 275 tires on the front of my car?
I run 275/40/17 with no probs. Its all in your backspacing...
Old Mar 27, 2012 | 01:58 PM
kcaalarcon's Avatar
idk 4 sure what it is but i also have 1.5 inch spacers on it 2
Old Mar 27, 2012 | 02:04 PM
kcaalarcon's Avatar
what kinda wheels do you have on yours?
Old Mar 27, 2012 | 02:19 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
I've got 275 with stock back space and I get a little rubbing on the liners front and rear near full lock.
Old Mar 30, 2012 | 10:15 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
is this a car for autocross? If not, why do you want a tire that large up front. Tires that wide become very expensive. Would rather do the typical 8 inch front and switch to rims with stickies at an event
Old Mar 30, 2012 | 12:35 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
That's what I do. The roads where I live are really crappy and very wide low profile tires are uncomfortable and try to follow every uneven line they can find. OK if you've got good surfaces.
Old Mar 30, 2012 | 02:32 PM
kcaalarcon's Avatar
its going to be an autocross car buts its also my daily driver, i also want tires the same size front and rear so when i wear out the backs i can swith em around
Old Mar 30, 2012 | 02:37 PM
kcaalarcon's Avatar
the road where i live are also vary crappy and there are alot of gravel roads im sure ill be driving on
1992rs/ss
Jan 31, 2025 05:10 PM
SiCkRs
Members Camaros
32
Jul 1, 2018 04:53 AM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
