C5 Wagon Wheels on a Third Gen
Old Jul 2, 2012 | 06:51 PM
PhantomFE3's Avatar
Car: 1984 Z28
Transmission: TCI Streetfighter TH350
Axle/Gears: 4th gen 3.42
this post is more of a reference for people thinking about swapping c5 wagon wheels on their third gen, as i could only find a couple pictures of what they looked like and i had to dig to find them.
springs are stock low mile iroc springs, fronts cut to lower it ~1" or so, rears untouched.
front has 2" wheel spacers from titan wheel accessories, very nice product at a great price btw (also have a pair of their ford to chevy adapters for my v8 datsun, i highly recommend them)
rear end is out of a 2000 camaro SS with LT1 brakes and axles
tires are 255 on the front and 295 on the rear
had to massage the body seam inside the rear wheel well, and remove the bump stops and grind down the bump stop mounts a tiny little bit. i will probably throw the bumpstops back on as it was just the mount that was rubbing
as a reminder these are 17" front and 18" rear. enjoy.
Old Jul 3, 2012 | 05:48 AM
scorp88's Avatar
Car: '92 Angrybird
Engine: 305 TBI the "Leaky Bastard"
Transmission: 700R4 with B&M shifter
Axle/Gears: 3.21 Posi off of '93 Camaro(RIP)
Re: C5 Wagon Wheels on a Third Gen
Mine rub inside front of a wheelwell at full turn. 245x45 with LS1 brake and 2" spacer .... and gap in front quite a bit larger now did I put front springs on the wrong way???
Before
After
Old Jul 4, 2012 | 12:01 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
17/18
18/18
Old Jul 4, 2012 | 11:46 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
I dont really know why, but these wheels seem to fit better on camaros without ground fx and Formula-style firebirds and the like. The 82-84 Z's ground fx dont come down as far as the newer ones do, so it looks good on that car too. Seems like the more ground fx, the worse these wheels look. They can look REALLY bad, but all of these cars look great in them.
Old Jul 9, 2012 | 10:38 AM
BCdawg57's Avatar
Car: '91 Z28, '13 Civic EX-L
Engine: 355 LT1, 1.8 I4
Transmission: T56, 5spd auto
Axle/Gears: 10 bolt 3.42(as long as no breaky)
Before
After
I run LS1 brakes up front with a 1.7" spacer and 265x18's with no rubbing.
Old Jul 21, 2012 | 03:13 AM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Like this?
Old Jul 24, 2012 | 02:31 PM
blackbmagic's Avatar
Car: 1985 IROC-Z
Engine: 355
Axle/Gears: 3.42 10 Bolt Posi
heres mine
Old Jul 25, 2012 | 09:09 AM
Aaron91RS's Avatar
Car: RS
Axle/Gears: 9" for the ladies
see attached
Old Feb 3, 2013 | 09:32 PM
ReEntry Racer's Avatar
Car: '82 TA GT1 Roadracer
Engine: ZZ4 Fast Burn 385
Transmission: TEX101A Dog Box
Axle/Gears: 3.73 4th Gen w/Auburn Racers Diff
18's at both ends with Conti race slicks 275-35.
Old Feb 10, 2013 | 10:14 PM
JamesBond's Avatar
Car: 1991 Camaro
Engine: Freshly cammed 350
I just picked up a set of wagon wheels, but I am kinda intimidated by the modding required to make them fit. Can any give me an idea on what i have to do to the bump stops, bump stop mounts, and wheel wells? thanks
Old Feb 10, 2013 | 10:52 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
...what modding of the bump stops?
Old Feb 10, 2013 | 11:28 PM
NemeSS-TyranT's Avatar
Car: 02 SS
Engine: 408 TT (1108rw-93/m1)6700rpm
Transmission: TH400(slipping)
Axle/Gears: 12bolt/3.42(whines😠)
I had a set of chrome 18s
Front 265
Rear 295
On my 00 camaro. Fit perfect without any mods.
I would like to use em on my rs.
Im gonna be converting to ls1 caliper in the front.
Rear, im using a moser 12bolt also with ls1 calipers.
I know the rear is tbd. But what is the easiest way to fitting them in the front?
Im not really concerned with the tire width in front, the one i need so there is no rubbing or interference on complete turns.
Rear im just gonna have to figure out when i install it.
Old Feb 11, 2013 | 12:14 AM
Third gens with stock width rearends need 2" spacers on all 4 corners.
Put a 4th gen rear in your car the next time it blows up and you won't need any spacers back there. You will need to put in the ARP longer wheel studs with the spacers too. Other than that, you will have no issues at all.
Old Feb 11, 2013 | 12:23 AM
Front 265
Rear 295
I use the 13" Baer 2-piston C4HD and have room to spare everywhere. I use LS1 12" stock 4th gen brakes on a 4th gen rear, again with lots of room. Hoosier race 275/35s all around with no rubbing (although some Camaros fit tighter than some 'birds.
Old Feb 11, 2013 | 09:49 AM
JamesBond's Avatar
Car: 1991 Camaro
Originally Posted by blackbmagic
heres mine
Hey is that lowered at all. Looks great.
Old Feb 11, 2013 | 01:23 PM
Car: 1985 IROC-Z
Engine: 355
Nope, It wasn't lowered in that photo but it is now :P
There are no mods, just spacers. No need to be intimidated, someone with ZERO knowledge about cars or mechanics can EASILY do this.
BTW. The stock center caps with lug covers are HIDEOUS! Take a look at mine trimmed off the lug covers and cleaned up the edges. 100% better than original.
Old Feb 11, 2013 | 02:07 PM
Car: 02 SS
Man, that looks fn awesome!
Thats the look i had in mind. What springs and struts are u using in front and rear?
Are the wheels 18 all around and tire sizes. i have (6) oe 18 chrome wagon wheels.
Cuz i thought they looked rad on 4th gens. But they look better on 3rd gens
Old Feb 11, 2013 | 02:17 PM
Car: 1985 IROC-Z
Engine: 355
Billsteins in rear and KYB in front.
Dropzone springs, removed Isolators and cut 2 coils in the rear.
17.8.5 and 18x9.5 staggered set
Stock C5 tire sizes. 245/45/17 and 275/40/18
Old Feb 11, 2013 | 02:21 PM
68Strat's Avatar
Car: '83 Sport Coupe
Engine: 360
Transmission: TKO-500
Axle/Gears: 12 bolt 3.73 TrueTrac
Love the center cover mod.
Here is my 83... Currently lowered on an Eibach Pro Kit... No issues so far with 2" spacers all around.
http://www.flickr.com/photos/53106660@N03/7292445268/
http://www.flickr.com/photos/53106660@N03/8451322678/
http://www.flickr.com/photos/53106660@N03/8465967950/
Old Feb 11, 2013 | 08:47 PM
JamesBond's Avatar
Car: 1991 Camaro
Man that's awesome, I love that. It just so happens my 91 camaro is also red. I'll be ordering my 2inch adapters ASAP! Very inspired by the way that looks. And thanks for the help!
Old Feb 11, 2013 | 09:25 PM
dads old blue 9's Avatar
Car: 1990 z28
Engine: 5.0
Transmission: t-5 wc
Axle/Gears: 4th gen 3.42 posi
I have a set that have been sitting in a barn since 1987 with 0 air pressure paid 250 and took them home caps included . wasn't sure how they would look was going to sell them , but now that I see them on a finished car I'm keepin um !
Old Feb 17, 2013 | 10:04 PM
Car: 1985 IROC-Z
Engine: 355
Thats odd, because they only started making them in 1997.
If you get your adapters pay close attention to the front of my car. It would look much nicer with a 2.25 or 2.5 inch adapter in the front, or a 1.75" instead in the rear with a 2.0" in the front. This will bring the wheels more parallel to each other.
Old Feb 17, 2013 | 10:54 PM
ChrisC's Avatar
Car: 1983 Z28/2000 ZR2
Engine: CFI to carbed 305/ 4.3
Transmission: Built 700r4/4L60e
Axle/Gears: 3:23/3:73
Better late than never I guess...Here's mine when I still had my wagon wheels:
Attached Thumbnails C5 Wagon Wheels on a Third Gen-camaro.jpg   C5 Wagon Wheels on a Third Gen-83-z.jpg
Old Mar 3, 2013 | 04:35 PM
lonesomeloser's Avatar
Car: 1983 Z28
What brand of tires?
Old Mar 3, 2013 | 05:11 PM
Car: 1985 IROC-Z
Engine: 355
Stock C5 tires.....
Goodyear eagle F1 GS EMT
They are almost 400$ a piece, and if you bought all four they are the worst 1600$ someone could ever spend. EMT or "run flats" are the worst tires period.
Old Mar 6, 2013 | 02:16 AM
Car: 1992 Camaro RS
I retract this statement. Every car in this thread looks fantastic. Im almost sold on buying a pair. What size tires do you guys run? 245/45/17s and 275/35/18s seem to match well, but I hate to go with stock width on the front. 255/40/17s are .4 taller than 275/35/18s and 275/40/18s seem like they're just too much taller than stock, enough to be noticable. I'd feel better if I knew what you guys ran, because clearly it looks right... I always planned to stay with 17's, but as good as these look and as cheap as you can sometimes find them....
Old Mar 6, 2013 | 09:20 AM
Car: 1985 IROC-Z
Engine: 355
Old Feb 22, 2014 | 02:50 PM
Mrbanados's Avatar
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
Where did you guys get your spacers
Nvm I re read...found them
Old Mar 2, 2014 | 08:58 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
When I ran these wheels and used the same size tires and 2" spacers. I had plenty of room in the front. I since bought a different set so I could run wider fronts, even with a 275 tire on a 9.5" rim a 2" spacer still works adequately.
Old Mar 3, 2014 | 07:05 AM
Here's mine.
Ignore the "gaps"; the ground it's sitting on is uneven. Sits about level on level ground.
These are w 2" spacers all the way around.
Old Mar 7, 2014 | 10:48 AM
Mrbanados's Avatar
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
Here's mine.
Did you have to use extended studs or are the stock ones ok?
And where did you get your spacers? I'm thinking about ordering them from titan wheel accessories
1992rs/ss
16
Jan 28, 2016 09:58 PM
cam-mike
Aug 24, 2015 07:23 AM
