Are spacers bad?
Car: 86 Z28 Camaro
Engine: 5.7 Vortec
Are spacers bad?
I've read that putting a 2" spacer on the front is a bad idea for a few reasons.
1. Extra stress on ball joints.
2.bad for performance handling.
Any truth to these??
Thanks for any info guys
Re: Are spacers bad?
A spacer has nothing to do with 1 and 2. The thickness of the spacer is meaningless without knowing the backspacing on the wheel. If for example you put a wheel with 2" more backspacing with a 2" spacer but the same width as stock you would have the same thing as a stock wheel.
Car: 1991 Firebird
Engine: 3.1L V6
Agreed. May need to clarify what you mean by ".....2"more backspacing" than what? 0" backspacing? Will confuse some.
Car: 86 Z28 Camaro
Engine: 5.7 Vortec
Let me reword that. If you had a 86 Camaro that was stock with stock rims. Then you take that same Camaro and put 2 inch spacers with Z06 rims would the extra force on the ball joints be a problem?
I appreciate the fast responses!
Car: 1991 Firebird
Engine: 3.1L V6
No, it has been done for years and no problems.
Car: 1991 Firebird
Engine: 3.1L V6
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
Car: 1988 GTA
Engine: 400 CI
I've been running 4th gen wheels for over a year now with 2" spacers and have not had any problems. I don't see a difference in handling either.
In reality, between the myriad of federal, state, and local laws, you are likely breaking some law just sitting in your house. Forget about modifying your car in any way.
You just have to live your life and find ways around them at this point.
Car: 1988 GTA
Engine: 400 CI
[ON] 9 Bolt Axles Partout
6speedIROC
16
Mar 15, 2023 08:33 PM
