I want to run 295/50-15 tires on rearof my 83 Z28
Old Aug 7, 2012 | 04:43 PM
83z28er's Avatar
Have a 1983 Z28 Camaro with stock rear and 3.73 gears and a 327 motor in it, I want to run 295/50-15 tires on rear without mods, can this be done on a 15 x 8 or 15 x 10 rim with what backspacing so that the tire doesn't stick out past the outer wheelwell lip
Old Aug 8, 2012 | 05:57 PM
89mulletbird's Avatar
Car: 89 GTA
Engine: 6.0L Procharged
Axle/Gears: 4.10
Re: I want to run 295/50-15 tires on rearof my 83 Z28
I have 315/35/17 on the back of mine. I haven't rolled the fenders yet, but I will as I am getting very slight cutting on the edge of the tread. I have custom offset 10" wheels on back. With the right offset you can do it easily.
Old Aug 9, 2012 | 07:52 AM
83z28er's Avatar
What backspacing it needed for use of 295/50-15 tires on either a 15 x10 rim or 15 x 8 rim?
Old Aug 9, 2012 | 09:09 AM
Car: 89 GTA
Axle/Gears: 4.10
I'll have to remove one of my wheels and figure out the backspacing for you, can try to do it this weekend.
295 is too big in my opinion for 8 inch rims. You should use 9 or 10s.
Old Aug 9, 2012 | 09:23 AM
83z28er's Avatar
Great, thanks guy I really appreciate it
Old Aug 9, 2012 | 09:35 AM
Z28Johnny's Avatar
I have 285 on 9" wide rims at 0 offset and they don't stick out past. I would do 10" wide over 8" for sure. For offset you should be good between 0 and about 15.
Old Aug 9, 2012 | 11:08 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Here's what 295/50r15s looks like on a 8" wheel. A friend had this set and let me take them for a spin. Turned out I did not have the right BS for them so I went back to my old set.The 295s had 10.2" of tread on the ground, got to love that. I talked to my tire guy and he said 5.50 BS on that wheel and the bulge would be flush with the fender flair.You still might want to get that verified .
Old Aug 10, 2012 | 12:07 AM
spicyskater's Avatar
Car: 1987 camaro Z28
Transmission: manual
I want to run 295/50-15 tires on rearof my 83 Z28-img_0503.jpg
I want to run 295/50-15 tires on rearof my 83 Z28-img_0510.jpg there 15x 10 4.1/2 backspace 295s
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
