need help on fitting
Old Oct 17, 2012 | 10:12 PM
mack1985transam's Avatar
Car: 1985 trans am
Engine: 355 vortec built 4 bolt main
Transmission: 700r4 w/ shift kit b&m console mega
Axle/Gears: 3.08
I have a 1985 Trans am it came factory with obviously 16x8's I am going to put 18x8 Iroc replicas on it. They have the same bolt pattern and are zero offset. my question is how much would I have to lower the car in order to get it to set right with the 18x8's? Also these rims will clear everything right? Also what brand of lowering could would you recommend also would there be anything I would else need to do in order for these rims to fit?
Old Oct 17, 2012 | 10:53 PM
Car: 1985 trans am
Axle/Gears: 3.08
Re: need help on fitting
Also what size tire would I need?
Old Oct 19, 2012 | 10:11 PM
Car: 1985 trans am
Axle/Gears: 3.08
Anyone?? I would appreciate any help
Old Oct 20, 2012 | 12:23 AM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
A 245/40-18 would yield the same diameter as a stock 245/50-16. The rears will be a bit farther outboard but should pose no problem with those size tires.
Old Oct 20, 2012 | 03:48 PM
Car: 1985 trans am
Axle/Gears: 3.08
So could I lower the car an inch if I put the 18'a on there with no rubing or any problems?
Old Oct 20, 2012 | 04:30 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
An inch lower should be no problem... But check with others who may have done the same thing first!
Old Oct 20, 2012 | 05:01 PM
Car: 1985 trans am
Axle/Gears: 3.08
yes I know that's why I hoped that you had done the same thing IM wanting to do.... But thankfully for all your help brother! IM really trying to achieve that lowered sports look yah know.
Old Oct 20, 2012 | 11:33 PM
watajob's Avatar
Car: 92 T/A 'vert
The pic is with a set of Prokits which lowered the car about 1.5" w/no rubbing issues.
Fronzizzle
Feb 9, 2017 09:31 AM
New2Chevy
Sep 28, 2015 12:35 AM
armybyrd
Carburetors
25
Sep 13, 2015 01:49 PM
BOOT77
Sep 5, 2015 03:55 PM
Formula_88AE
Sep 3, 2015 01:47 PM
