275's don't fit. What do I do?
Old Mar 23, 2013 | 12:30 AM
WhiteRabbit's Avatar
Hey guys so today I inherited some Weld Draglites from my dads GTO. Rear is 15x8.5 and front is 15x5. The fronts fit no problem. The rear 275's are too wide and hit the bump stop. The guy at the shop told me to get 235's instead. Isn't that a little narrow for an 8.5" wide wheel? Should I go with 245's or 255's? Any other opinions? Thank you very much guys!
Old Mar 23, 2013 | 12:34 AM
robg91z's Avatar
Car: 1991 Camaro Z28
Engine: 350ci TPI
Transmission: built 700r4
Axle/Gears: 4th gen rear end
Re: 275's don't fit. What do I do?
are you running stock diff? whats the backspacing on the wheels?
Old Mar 23, 2013 | 12:50 AM
Yes it's the stock diff. The wheels came with the GTO that he got a month ago so I don't know what the back spacing is since I didn't purchase them myself.
Old Mar 23, 2013 | 01:53 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Without knowing the BS its hard to guess and the shop should have been able to tell you it.
Some shops will mount a old tire in the size you want on your wheel then just put it on and see how it fits.I run 255/60r15s rear on a 8in. wide wheel and love them.
Here's a way to measure.
Old Mar 23, 2013 | 07:36 AM
Thank you for this. Ill measure them today.
Old Mar 23, 2013 | 07:54 AM
conlinj's Avatar
You have to have a wheels with the wrong backspacing, I've had 255/60-15, 275/60-15 and 295/50-15 on my car without any problems. I'm currently running 295/50-16's with no issue.
Old Mar 23, 2013 | 08:00 AM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
i agree wrong backspacing. i have 275/60/15 on my and they fit perfect
Old Mar 23, 2013 | 01:18 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Yep, wrong back spacing. If you really want to run them, get some spacers.
Old Mar 23, 2013 | 01:19 PM
Car: 1971 Camaro
Engine: 427
And for the guy that said you need 235's IROCS came with 245's from the factory.
Old Mar 24, 2013 | 12:27 AM
Ingram78's Avatar
Car: 1985 firebird
Engine: 360"sbc NA pump gas
Transmission: Th350 manual valve body
Axle/Gears: Moser 12 bolt 4.11:1
Have 15x10" with Hoosier 275 60's and a 5.5" backspace also perfect fit.
1986Z28OWNER
Dec 13, 2015 10:19 PM
hokis
Wheels and Tires
Aug 26, 2015 04:21 PM
slade5612
Aug 11, 2015 07:19 PM
milk
Aug 10, 2015 06:26 PM
