Having Trouble Identifying Which Center Caps I Need
Old Jul 12, 2013 | 07:35 AM
cliffhanger1392's Avatar
Hello all. I have a quick question for you. I picked up a set of wheels of Craigslist. They did not come with center caps. As I am doing my shopping for caps, I can't seem to find any that look as if they are the right application. I want to make sure I can get caps for these before I spend the money on powder coating. Have a look at the pic. Any idea what type of caps these take? There are no little holes or metal "tangs", it looks as if it is a cap that just fits into the small space between the wheel and hub or under the lugs. Any help is appreciated. Thanks!Name:  wheels_zpsc9cad4e0.jpg
Old Jul 12, 2013 | 07:37 AM
Re: Having Trouble Identifying Which Center Caps I Need
Oops, I forgot to mention these are 15" wheels.
Old Jul 12, 2013 | 07:58 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
http://www.ebay.com/itm/1988-Camaro-IROC-Z-15-Wheel-Center-Caps-Set-of-4-/290944978211?hash=item43bdac0d23&vxp=mtr
Old Jul 12, 2013 | 08:04 AM
Engine: Lb9
Transmission: M20
I have a used set that someone has put Bowtie stickers on and Iirc one has a crack on the side but still should be usable I would sell.
Old Jul 12, 2013 | 08:33 AM
Those caps are what I keep finding those wont work I don't think. The have the metal tangs, but my wheels have no support for those.
Old Jul 12, 2013 | 08:41 AM
Engine: Lb9
Transmission: M20
The spring tension of the tangs hold the cap on in the hub centric
Old Jul 12, 2013 | 05:09 PM
I appreciate the feedback, however I am pretty sure my wheels will not accept the tangs. I found a similar picture while trolling the forums of my type of wheels, with centercaps on them (Minus the goofy spinner thing). It DOES appear as if the center cap assembly plays a part with the lugs, however I can't find any for sale that look like that on Classic Indutries, Rick's Camaro, etc. HELP!
Old Jul 12, 2013 | 05:17 PM
Engine: Lb9
Transmission: M20
You have the wrong lug nuts !
http://www.ebay.com/itm/82-92-Camaro-Firebird-Black-Lug-Nut-Cover-Cap-NEW-GM-/290942982200?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3ACamaro&hash=item43bd8d9838&vxp=mtrhttp://www.ebay.com/itm/20-12X1-5-DUAL-THREAD-GM-FACTORY-STYLE-LUG-NUT-19mm-HEX-OPEN-EXTERNAL-THREADED/261216949049?_trksid=p2045573.m2042&_trkparms=aid%3D111000%26algo%3DREC.CURRENT%26ao%3D1%26asc%3D15933%26meid%3D9029537640476223510%26pid%3D100033%26prg%3D7611%26rk%3D4%26sd%3D350780222112%26
http://www.classicindustries.com/cam.../10154284.html
Old Jul 12, 2013 | 05:26 PM
Well damn, I found another pic with the caps you were talking about. So you mean to tell me, those caps will snap into the paper thin space between the wheel and the hub?!?! Yikes!
Old Jul 12, 2013 | 05:32 PM
Engine: Lb9
Transmission: M20
Old Jul 12, 2013 | 05:49 PM
Engine: Lb9
Transmission: M20
The center cap is retained in the outer hub lip in the wheel.
Old Jul 12, 2013 | 06:20 PM
Here is my dilemma in a nutshell.....
Old Jul 12, 2013 | 06:21 PM
I could just cut them off I suppose, but if the caps are the wrong ones, I would hate to damage them only to find they won't work.
Old Jul 12, 2013 | 06:54 PM
Engine: Lb9
Transmission: M20
http://www.tacreationsusa.com/camaro_wheels.htm
I believe the 82-84 wheels did not use the alignment pins for the hub caps
Breazlan
Sep 25, 2015 11:20 AM
Linson
Sep 21, 2015 01:08 PM
88HARDTOPIROCZ
Sep 18, 2015 10:30 PM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 6, 2015 06:23 AM
