Who makes good tires for our Camaros? And size??
Old Jul 15, 2013 | 03:06 AM
TrueIroc's Avatar
Car: 1989 IROC-Z 100% Original
Engine: 5.0 TPI
Axle/Gears: 3.08
Who makes a good street tire for a Camaro with 16'' Stock Wheels?
Should I stick with what it came with from the factory which I think was the Goodyear GSC Eagles or is there something better out there?
Also should I keep the stock size of 245/45/ZR16 or should I go a little wider like 255/45 or 265/45. I like the look and feel of the Stock 45 thickness and dont want to go any lower like 40 or 35. You feel the bumps too much that thin, so how wide can I go until I get tire rub or is too wide bad and throw off the cars handling? Let me know what tire set up's you guys have
Old Jul 15, 2013 | 07:38 AM
TPIVette's Avatar
Car: 1991 Corvette
Engine: 383 TPI
Axle/Gears: D44 3.33 gears
Re: Who makes good tires for our Camaros? And size??
FYI, the original size was 245/50/VR16
Old Jul 15, 2013 | 08:31 AM
sweetmelissa's Avatar
Car: 1989 Iroc-Z
Engine: TPI 350
Axle/Gears: 3:27's
I have BF Goodrich,, they handle well !!!
Old Jul 15, 2013 | 11:01 AM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
First of all, you cannot buy Goodyear Gatorbacks in 245-50-16, they haven't made them in over 10 years now.
As TPIvette mentioned, stock size is 245-50-16 (245-45-16 was a Porsche 911 rear size).
Here's the bad news - the only summer performance tire you can get today for your car in 245-50-16 is the BFG g-force sport comp 2, Goodyear just discontinues their overpriced tire and is on closeout at tire rack. Not sure if GY is going to replace it with anything else at this point. Sure you can get the Firestone tire, but the BFG is much better all around in every way.
Good news is that the 225-55-16 tire size fits on stock 16" wheels perfectly, even if they are spec'd 20mm more narrow than 245-50-16 OEMs. There are over 20 different high performance tire patterns in this smaller size. Keep in mind that a 225 tire on a 8" will give a lot more sidewall stability and will be much more predictable than say a 255 width tire on the same size.
The real deal is to upgrade to 17" or 18" wheels & tires - for a few reasons:
1) Massive tire selection in any width and profile
2) Ability to fit most modern big brake kits
3) Optimal sidewall to width ratio (perceived spring rate)
4) The look of less tire with more wheel
Old Jul 16, 2013 | 05:08 AM
TrueIroc's Avatar
Engine: 5.0 TPI
Axle/Gears: 3.08
Thanks thats what I meant. I went to edit it but my phone battery died
Old Jul 16, 2013 | 05:27 AM
TrueIroc's Avatar
Engine: 5.0 TPI
Axle/Gears: 3.08
My car came with 15'' wheels, the previous owner had 235's on there and they didnt have too much grip so Im definitely going with 245 or wider. I was thinking about getting 17 Iroc wheels but they just looked too big on the front. I have a show car with 18,000 original miles so Im trying to keep it as stock as possible. I ended up picking up a nice stock set of 16'' Iroc wheels, had them refurbished, polished, and had the lines painted black so they really pop. Ill post pics on here when the cars ready. So Im looking to put some good rubber on these fabulous wheels. Too bad good year discontinued theres. Ill try and find a set.. But if I cant Ill try out the BFG TIRES instead. Should I keep the stock size of 245/50/16 or go wider like 255 or 265.. Or is that too wide for these cars
Old Jul 16, 2013 | 07:13 PM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
are you just looking for tires that fit, or do you plan on some autocross/road course type stuff?
because i just got a set of 245/50/16 Hankook Ventus V2 tires on my car, and they do a pretty good job of holding the car off the ground and riding nice and quiet with good wet and dry traction... haven't tried any real spirited driving with them since my suspension is worn out, but i've read nothing but good reviews online... and they were only $420 installed at the local Cenex coop store..
Old Jul 16, 2013 | 10:19 PM
T/Atime's Avatar
Car: 91 GTA
Axle/Gears: 3:73
I'll try and post some pics of the Firestone firehawk tomorrow. There a great tire at 245/50/16. The tread pattern looks killer too.
The iroc wheels are always a good choice if the price is right.
Old Jul 16, 2013 | 10:53 PM
i88aGT's Avatar
Car: 1988 IROC-Z
Engine: 5.7L TPI
Axle/Gears: No G92
I'd be weary of the Michelin tires that fit. 2 years ago I bought the Michelin Pilot Sport AS Plus 245/50ZR-16 because they were the best rated performance tire in Consumer Report, but had a bad experience this year when the tires started "chunking." They turned out to be defective. Supposedly now they've fixed the defect in future batches, but I haven't driven my warranty replacements enough to tell if they're better.
Old Jul 17, 2013 | 10:15 PM
T/Atime's Avatar
Car: 91 GTA
Axle/Gears: 3:73
Great looking tire IMO
Old Jul 17, 2013 | 11:30 PM
TrueIroc's Avatar
Engine: 5.0 TPI
Axle/Gears: 3.08
Its just for everyday driving, but I drive aggressive. I only take the car out when its dry
Old Jul 21, 2013 | 12:13 AM
TrueIroc's Avatar
Engine: 5.0 TPI
Axle/Gears: 3.08
Looking into a set of the BF Goodrich g force sport comp 2 or Firestone Firehawk wide oval indy 500 tires.. BFG is rated #1 and Firestone is at #3, so they're pretty close. The BFG tread looks like it might handle better in wet conditions and in cornering. I can't argue that the Firestone tread does look a little more aggressive. I looked at the Goodyears there's only 7 left at tire rack. The tread to the Goodyears didn't appeal to me. It would be cool if they could come back with their Gatorback's with a newer version. Hear that Goodyear get back to work!!!
Old Jul 21, 2013 | 03:02 AM
Dakota W.'s Avatar
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
#4 is subjective. The tires are offset, the fronts are smaller than the rear. You should be able to stretch a 235/60/16 to fit the front though. I have sumitomo all-seasons on my back tires because I drive in the sun/rain/snow, and they handle the rain and snow well for a tires that's less than $100/ea. My 305 could break them loose in 1st, chirp 2nd, and 3rd though. In the wet, I could spin through first and second, but I could only spin through second if I was stopped on a steep enough incline. I have Toyo Proxes 2 on the fronts and they've been an astounding tire, and I got them well used, they're starting to hydroplane, now that the belts are nearly showing. I'm going to be getting sumitomo HTR Z II's based on the reviews.
Old Jul 21, 2013 | 08:30 AM
T/Atime's Avatar
Car: 91 GTA
Axle/Gears: 3:73
Firestone
Attached Thumbnails Who makes good tires for our Camaros? And size??-image.jpg
Old Jul 21, 2013 | 10:11 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
As long as BFG keeps making their tire, I'll keep buying them. I've used the G Force Sport tires on all of my cars, and they're a fantastic tire.
Old Jul 21, 2013 | 11:37 AM
85 ZXX's Avatar
Car: 85 Z28 T-Top 36mm sway & wonderbar
Engine: TPI L98 350 W/85 Vette Stage II ECM
Transmission: W/C T-5, alum drive shaft
Axle/Gears: 9 bolt posi, 3:27, PBR's, BB LS1's
My Firestone Firehawk Wide Oval Indy 500's work great for me. 245/50-R16
Attached Thumbnails Who makes good tires for our Camaros? And size??-rim00059.jpg   Who makes good tires for our Camaros? And size??-rim00066.jpg   Who makes good tires for our Camaros? And size??-rim00063.jpg
Frozer!!!
Jan 19, 2024 04:55 PM
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
Linson
Aug 21, 2015 02:12 PM
Fronzizzle
Aug 9, 2015 01:15 PM
jpearcy1
Wheels and Tires
Aug 9, 2015 10:20 AM
