245 and 255 50-16's Whats out there and where to get?
Old Jul 17, 2013 | 11:01 AM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
I noticed that these Sizes are getting harder to find, what are you guy's running and what is out there? I did a search and not mush came up up, I sent E Mails to a bunch of tire companys just waiting on replies.
Where are you guys getting yours?
I have ran this size for over 20 Years, and would like to cont to do so.
245 Front 255 Rear.
I ran mostly BfGoodrich, and Some Goodyears.
Old Jul 17, 2013 | 11:08 AM
Guest
Guest
Posts: n/a
Re: 245 and 255 50-16's Whats out there and where to get?
245-50-16 Uniroyal TigerPaw GTZ
Old Jul 17, 2013 | 11:11 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Bfg and firestone still make the 245 size, there are a couple othrs but most 16" options are drying up.
Old Jul 17, 2013 | 12:26 PM
BLACK Z's Avatar
Car: 86 Z28
This used to be such a Popular size, There are many third Gens out there and other car's still using this size, I have not bought tires for this car in the past ten years, then there were many options.
The Bf Goodrich Comp tires are looking like the ones to get.
E Bay has some different choices but man they are expensive.
Old Jul 17, 2013 | 12:36 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Just checked and the only choices (high performance summer pattern) are the Firestones and the BFG G-Forces. BFG is one hell of a tire, Firestone is a distant 2nd.
You only have one choice in 255-50-16, The same BFG tire.
Everything else is pedestrian all season crap in 245-50-16 - a lot of which are only "H rated", or 130mph max speed.
There is an option, a 225-55-16 tire, of which there are dozens of choices on the market - it was a BMW, MB, and other import size for over a decade. I noticed over 20 summer tire choices in that size, including the excellent Continental Extreme DW, the Dunlop DZ101, and the BFG KDW 2 patterns. For those that frown upon the slightly smaller size, keep this in mind: a third gen on the 225-55-16 Dunlops mentioned above will destroy an equivalent car on all season 245-50-16 tires on a road course by a few seconds, which shows you how much grip you lose with a non summer tire.
Old Jul 17, 2013 | 12:43 PM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
Do you have a set? If so, what do you think of them?
Old Jul 17, 2013 | 01:03 PM
BLACK Z's Avatar
Car: 86 Z28
I try to stay with a quality tire, Don't like going to a off brand, I want the Best Perf I can get Mileage is not a top concern since the ca sees very little mileage per year.
Any Pic's of what a 225-50-16 looks like on our cars? I like the look of a smaller tire in the front by just a touch. MY Car sits quite low as it is now, can't afford to lose to much more ground clearance.
Old Jul 17, 2013 | 01:56 PM
IROCgiraffe's Avatar
Car: '87 IROC-Z | '99 SS
Engine: LB9 | LS1
Transmission: 700R4 | T56
They sell Cooper Zeon RS3-A 245/50/16 97W. Friend has these tires (not same size) on his 3rd Gen Taurus SHO... nice tire.
Old Jul 17, 2013 | 03:59 PM
paul_huryk's Avatar
225-55-16 is the same height as 245-50-16 sized ones - don't bother with 225-50-16, they are 1" smaller in diameter...
Old Jul 17, 2013 | 04:02 PM
paul_huryk's Avatar
I have a set mounted on the GTA wheels the previous owner put on. They ride cushy and are sloppy - way too easy to break the rear tires loose in normal driving. Not for performance use, IMO.
Old Jul 17, 2013 | 05:40 PM
plum92_camaro's Avatar
Car: 92 Camaro RS
Axle/Gears: 10bolt w3.42 Torsen
These should help. All pretty short threads. Won't take long to look them over. Pics in last link.
https://www.thirdgen.org/forums/whee...tire-poll.html
https://www.thirdgen.org/forums/whee...245-50r16.html
https://www.thirdgen.org/forums/whee...nces-16-a.html
Pictures in this one. Post #6.
https://www.thirdgen.org/forums/whee...5-50-r16s.html
Old Jul 17, 2013 | 08:24 PM
jer4251's Avatar
Car: They all sit.
Engine: LS1, LB9, LB9, L98, LT1, LT4, LT4
Transmission: A4, T5, T5, A4, A4, T56, TR6060
ive been looking for tires as well, just stock 245/50R16's. also noticed most are not Z rated. Does it seem that important to get Z rated? big price difference between them. don't see myself going 130 plus in a 305 convertible.
Old Jul 17, 2013 | 09:02 PM
Engine: LB9 | LS1
Thanks for posting your feedback.
Old Jul 18, 2013 | 08:12 AM
BLACK Z's Avatar
Car: 86 Z28
225-55-16 are they not as wide as the 245-50-16?
Friend has the Coopers Zeons on her 02 TA not a huge fan of them, But if you have to run them then I would there are worse out there.
I have contacted all the major companys, so far these companys have gotten back to me.
Goodyear No longer makes either size.
Michielin No longer make them
Toyo No
Nitto No
Pirelli No
BfGoodrich Yes both sizes
Waiting on Dunlop,Cooper,Firestone,Bridgestone I think.
BfGoodrich is the tire I normally run and looks like ill be trying again.
Old Jul 18, 2013 | 11:35 AM
Guest
Guest
Posts: n/a
I do have a set. They are a very good dry weather tire, good grip and and very predictable and smooth when they lose adhesion. Road noise is at a minimum. In wet weather, they will get you killed. Braking distances feel like they are doubled and longitudinally they lose grip like they are on ice. They still have decent lateral grip when it's wet but nothing that inspires confidence. They are a good tire, but I probably wouldn't buy them a second time.
Old Jul 18, 2013 | 12:10 PM
ghost91's Avatar
Car: 1991 Camaro Z28
The BF Goodrich Sport Comp 2 and Super Sport A/S are awesome tires. Ive run both sets and like the Super sport a little better mainly cuz its a great all season tire. Nothing bad to say about them. They lasted me a long time and grip very nicely and look nice. IMO some of the best 245/50 tires available!
Old Jul 18, 2013 | 12:34 PM
Car: 92 Camaro RS
225-55-16 are they not as wide as the 245-50-16?.
No. Noticeably narrower, Slightly taller than 245s.
245-first # is the width in millimeters
50-second # is the side wall height as a percentage of the width. In this case the sidewall height is 50% as tall as the width (245).
R16- the third # is the rim diameter and is identified by a R. I know most people get this one but I put it in here in case it might help a reader in the future.
Old Jul 18, 2013 | 12:38 PM
chazman's Avatar
Axle/Gears: BW 3.45
Thanks.
Old Jul 18, 2013 | 07:25 PM
BLACK Z's Avatar
Car: 86 Z28
Yokohama Nope
GoodYear Nope
Kelsey Tire Nope
www.coker.com Nope
Old Jul 19, 2013 | 02:42 AM
IROZINCO's Avatar
There is another option - 245/50-16 KUMHO tires. They are reasonably priced. I live in Colorado, so summer ONLY tires are NOT an option here. They'll get you killed. It can rain/snow/hail/blow here at ANY time of the year.
Speed ratings are different than they used to be. I have W rated, which is up to 168mph
Symbol Max Speed (mph & km/h)
Q 99 mph & 160 km/h
R 106 mph & 170 km/h
S 112 mph & 180 km/h
T 118mph & 190 km/h
U 124 mph & 200 km/h
H 130 mph & 210 km/h
V 149 mph & 240 km/h
W 168 mph & 270 km/h
Y 186 mph & 300 km/h
ZR Above 300 km/h or 186mph
Old Jul 19, 2013 | 09:51 AM
paul_huryk's Avatar
Q 99 mph & 160 km/h
T 118mph & 190 km/h
You are incorrect about the symbol for "above 300km/h or 186mph" - the proper symbol is (Y) - the parentheses are the difference between 186mph rating and above 186mph...
Old Jul 22, 2013 | 08:32 AM
blue85305's Avatar
Car: 1984 camaro
Transmission: th 350
Axle/Gears: 3:42
These are the current Firestone offerings, I just took that picture. The only ones on the list that are really available are the Indy 500 wide ovals. I had them on my lt1 car, and they were ok at best.
Old Jul 23, 2013 | 01:14 PM
Copperhead's Avatar
Nitto makes the NT01 in our size, but it's 100 treadwear. If you're only doing autocross and light street driving, they'd probly last you a couple of years; daily driver - - one season, but stick would be awesome.
Old Jul 23, 2013 | 09:06 PM
BLACK Z's Avatar
Car: 86 Z28
Do they Make them in a 255?
Old Jul 23, 2013 | 11:48 PM
3rd gen Will's Avatar
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
IMO the best street tire option in a 245 or 255/50R16 is going to be the BFG Comp 2's. I auto-crossed on a set of 255s and they had pretty awesome grip. I REALLY had to try to lose traction.
Old Jul 24, 2013 | 07:58 AM
KMK454's Avatar
Car: 1991 Camaro B4C
Here's my review of Firestones in 245-50-16...
https://www.thirdgen.org/forums/whee...wide-oval.html
Old Jul 24, 2013 | 08:38 AM
IMissMy86TA's Avatar
Car: 1991 Trans Am Vert
Engine: 5.0 TPI
Transmission: T-5 baby
while most of us like to have some performance tires, many of us do very little driving. I go mostly to car shows so why would I spend a fortune on tires that will age faster than get worn out. more likely to dry rot and have lots of tread
I went for General's Altimax HP and never seen another on here with them.
The are unidirectional and have good grip. they are a bit softer so they ride nicer and my kidneys thank me.
at 97$ a pop they are a steal. I bought them at 81/ea before Obama increased tariffs on tires made outside the USA. They do very well and have good cornering grip.
http://www.tirerack.com/tires/tires....omCompare1=yes
here is my car with them on
Old Jul 24, 2013 | 08:45 AM
BLACK Z's Avatar
Car: 86 Z28
I am leaning toward the BfGoodrich, Price is not a big issue since I put very few miles on my car a year, I don't use it for track day's anymore either. I do Like the tires for there Perf and also there looks, I think the cheaper and no name tires lack both Perf and Looks.
Old Jul 24, 2013 | 09:10 AM
ghost91's Avatar
You can't go wrong with them. One of the best all season tires out there. Which one you thinking on running? Sport comp 2? Or super sport?
Old Jul 25, 2013 | 06:31 AM
BLACK Z's Avatar
Car: 86 Z28
I think just the sport comp 2's come in the 255 size for the rear.
Old Aug 7, 2013 | 10:18 AM
89mulletbird's Avatar
Car: 89 GTA
Engine: 6.0L Procharged
Axle/Gears: 4.10
I put BFG sport comp 2's on my TTA (500+ HP), and am very impressed with them. 255 on back, 245 on front. I got the tires out the door for under $700.
Old Aug 7, 2013 | 04:54 PM
BLACK Z's Avatar
Car: 86 Z28
Can you post pic's of them mounted on your car?
Old Aug 7, 2013 | 05:25 PM
Car: 89 GTA
Axle/Gears: 4.10
I'll snap some pics tonight.
Old Aug 7, 2013 | 06:19 PM
BLACK Z's Avatar
Car: 86 Z28
Cool, If you could try and get a side shot with both tires in it, and a Tread shot and what not. Thanks again.
Old Aug 8, 2013 | 10:37 AM
Car: 89 GTA
Axle/Gears: 4.10
Old Aug 8, 2013 | 10:38 AM
Car: 89 GTA
Axle/Gears: 4.10
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
R13_Braz
Sep 18, 2015 05:00 PM
corey8084
Sep 17, 2015 02:56 PM
zayne0
Aug 24, 2015 07:22 PM
jpearcy1
Wheels and Tires
Aug 9, 2015 10:20 AM
