Which size?
Which size?
BF Goodrich G-force sport comp 2
245/50/r16
or
255/50/r16
on stock rims, i'm ordering tomorrow, wanted to see which would work and which wouldnt. thought someone once said the 255's dont work.
245/50/r16
or
255/50/r16
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Re: Which size?
I've had bot sizes on my car. Both sizes worked ok. I prefer the stock 245 size because they fit the wheel well better. From a performance characteristic, I really can't say because when I changed sizes I also changed tire brand, and I attribute that and the age of the older tires to the different feel more so than the size. When the 255s were newer, I don't recall feeling any significant differences in handling compared to the new 245s.
Re: Which size?
i have 245's on the front, which are brand new, i'm not getting rid of those. they get awfully close to rubbing as it is so i dont want to change them up. I have to replace my 2 rear tires and i was thinking the 255's
Re: Which size?
I have a 275 in front with no problems and others have as wide as 295 without any mods.
Re: Which size?
The difference in size is significant enough that it will be visibly apparent. If you like that "I've got air shocks and a big fat pair of Futura Supersport tires" look, then go for it. If you want to keep that balanced look, I'd stick with the 245s. Keeping the 245s will also allow you to rotate the tires down the road for longer tread life too.
Re: Which size?
Pac J
May 17, 2020 10:44 AM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
