Best way to press wheel studs?
Old Oct 2, 2013 | 12:26 AM
actarnoff's Avatar
Car: 1991 RS/B4C clone
Engine: 355 TPI
Transmission: Probuilt Street/Strip 700r4
Axle/Gears: 7.625 axle with 3.23 gears/TrueTrac
I have one of these presses:
This weekend I tried to press some studs into my rotors (I needed longer studs for my R15s) and I found that I had no way to support the rotor to press in the stud.
Which methods have you guys used to support the rotor?
Old Oct 2, 2013 | 02:13 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: Best way to press wheel studs?
Tap them in with a hammer & drift.
Old Oct 2, 2013 | 07:28 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
This always worked good for me
http://www.harborfreight.com/ball-jo...cles-4065.html
Old Oct 2, 2013 | 05:04 PM
actarnoff's Avatar
Engine: 355 TPI
That does't look like it would work with my rotor.
What I'd like to know is what you support the rotor with in the press. Do you use 2 square press blocks? What do people use?
Old Oct 2, 2013 | 07:12 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Just a good hammer and a drift will do the job.
Old Oct 2, 2013 | 08:57 PM
I usually use a hammer, ginormous punch, large socket, and selection of wood scraps to support the rotor for the socket.
Pretty "low tech" here. But I SURELY HAVE </si robertson> pressed a BUNCH of studs over the years.
Old Oct 13, 2013 | 08:57 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
BFH to "press" out, open end lug nut on backwards to "press" in.
Old Oct 14, 2013 | 02:02 AM
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
This. Except I just use my air hammer and it knocks it right out. Then slide the new stud in, thread an open ended lug nut on backwards and a quick zap with an impact and your done. It's a two minute job.
Old Oct 14, 2013 | 02:40 AM
n2deep22's Avatar
I just put a lug nut on it and tighten down it will suck it in .
Old Oct 30, 2013 | 11:56 AM
dmwracing42's Avatar
Car: 1984 Trans Am
Engine: 355
Axle/Gears: 10 Bolt, Torsen Diff, 3.73's
Yup, 100% the best way. Did it with our circle track stuff all the time.
Old Oct 30, 2013 | 12:40 PM
carattini's Avatar
Car: Pontiac 89 GTA
Engine: 350 TPI 5.7L V8
Originally Posted by midias
I have one of this also an work grate. but I paid $180 for it
Old Oct 31, 2013 | 04:58 AM
Jay_rich's Avatar
Car: 1987 Z28
Engine: 2005 5.3L, LS6 Cam
Axle/Gears: DTS 9" 3.50 TrueTrac
I have always pounded them in part way, then grabbed a bunch of washers and tightened on an open end lug nut until its seated. This time around I will use my press since I have one now
Keep in mind if you ordered the 0.509" arp's they will be a tight fit. I pounded my stock ones out last night and measured the ID. It was I think 0.472. Some guys say the open them up a tad. I know when I installed my last set they were a b**** to get in.
Jay
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
New2Chevy
Sep 28, 2015 12:35 AM
SG91camaro
Sep 5, 2015 10:27 PM
WickedBowtie
Exterior Parts Wanted
Sep 5, 2015 04:58 PM
rudolphschenker
Sep 4, 2015 02:41 AM
